kwiktsi
NY, USA Status: offline
This is the New Bright Ski Doo? Mine had a 14 tooth stock. I wonder if they changed the gearing. I actually cut the top off the housing (where the motor mounts) and rivited an aluminum plate to the back side with slotted holes for the motor so that I could adjust it for different sized gears. Joe quote:
ORIGINAL: tman52806 I put a cheap 17 turn motor in mine, but I came across alittle snag. If I use a 14, 16..whatever size pinion other than the stock 9 tooth, I will have to slot out the gear housing in which the motor mounts to in order to get the proper gear mesh. I feel this will dramatically weaken the gear housing, so I'll need to reinforce it will alumimum or something. I have a 14 tooth pinion on order and a 16 pinion ready to go, guess I'll get the dremel out and make the adjustments I need, just need to pick up a thin piece of aluminum plate. I wonder how well it would run with the stock 9 tooth pinion and my upgraded motor, esc and 7 cell 3300 pack?
