huttcraft
NS, CANADA Status: offline
The spec sheet for the Angell (above) show a weight max of 75 kg, about 165 lbs. It also shows a top speed of 25 km/h, or about 15 mph. That's about as fast as a person out for a jog. Personally the Angell might be a fun toy, but I think your money's better spent on a used conventional sled. Even a 10 year old machine will typically have very low mileage, since snowmobiles are seasonal and recreational. Many only get a few days' use a year. And with almost any sled built since 1990 you'll have no trouble going 100 mph, even if you weigh more than 165 pounds. My thoughts. Now back to the New Bright rc machine. I've seen lots of references to modding the track and ski suspension to make them truly functional. I've cut out the faux-limiter straps in the track suspension which seemed to improve it but haven't done anything else. What's next? Also, has anyone found parts or material that will replace the spindles in the ski assemblies? The entire set-up is extremely flimsy. I'd like to find a way to make the skis behave more like a real sled, turn reasonably well and hold together for a little while. Dave
