MinnFlyer
MN, USA Status: offline
I haven't met the curve that MK does better than UC. Here are my obsevations: MK has more colors. UC is more durable (It's a bit more "Rubbery" and less prone to breaking, where MK is more brittle and will pop open easier) Trim Solvent works on MK, but not on UC I don't care what anybody says - BOTH COVERINGS WRINKLE - get used to it If there's a difference in shine, I sure don't see it. The next two are the BIG differences: UC beats MK hands-down when it comes to applying it. It shrinks more and it stretches more. MK's adhesive is more permanent than UC. This is a pro and a con for BOTH. Example. If you iron down a wrinkle in MK, it will be there forever - unless you replace the covering - But removing MK can be a bear if it's been on for a while. In this situation, this is not good With UC, you only have to add heat, and it will peel right off. In this situation, this IS good But if you are trying to tighten an area near the edge of the covering by heating it, MK's adheasive will not allow the edge to be pulled in as easily as UC. So you see how the different adhesives can be good or bad. My preference is to use Ultracote because it is SOOO much easier. If I need to heat close to a seam, I just protect the seam with a wet paper towel.
< Message edited by MinnFlyer -- 12/16/2005 3:35:51 PM >
_____________________________
Mike B. AMA# 42400 www.gettingairborne.com "Those are my principles. If you don't like them, I have others." - Groucho Marx
