RE: Monocote or ultracote??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> RE: Monocote or ultracote??
Page: <<   < prev  1 [2]
Login
RE: Monocote or ultracote?? - 12/15/2005 7:12:52 PM
bhole74
Status: offline
If you can't find it here, chances are you won't find it.http://www.horizonhobby.com/Search/Default.aspx?SearchTerm=Ultracote&OverallCatID=&CatID=&BrandID=HAN&SearchType=Standard&SortBy=CatDESC&SortDirection=ASC&Page=1
_____________________________
Had I known that flight was going to cost me $100 per second, I wouldn't have flown 30 seconds!
(in reply to MikeFreas)
       Post #: 26
RE: Monocote or ultracote?? - 12/15/2005 7:20:56 PM
JNorton
Status: offline
I happen to like Monokote. Both have slightly different application methods. Best bet is find someone whose planes you admire to teach you how to apply the stuff. It's more of an art. Take your time and either will work.
John
Have desk ... Will Fly....
Saito Member #467
(in reply to bhole74)
       Post #: 27
RE: Monocote or ultracote?? - 12/15/2005 8:23:32 PM
P47 Thunderbolt
Status: online
quote:
ORIGINAL: bhole74
Hey, thanks. I looked on Horizons web site but couldn't find it the first time. I probably wasn't searching correctly.
       Post #: 28
RE: Monocote or ultracote?? - 12/15/2005 9:26:50 PM
bhole74
Status: offline
Why you have to do an extensive search for it is beyond me. I couldn't find it myself because I typed in Ultracoat instead of Ultracote, stupid me!
(in reply to P47 Thunderbolt)
       Post #: 29
RE: Monocote or ultracote?? - 12/15/2005 10:23:44 PM
50%plane
Status: offline
quote:
ORIGINAL: bhole74
Horizon's sight is a nightmare. I've gone through the same things and don't visit it much any more.
John
THat's the best advice I've read on this subject.
Woops
Model Airplanes don't kill people. Chuck Norris kills people.
Christopher A. Todd AMA# 637636
       Post #: 30
RE: Monocote or ultracote?? - 12/16/2005 3:32:19 PM
tychoc
Status: offline
quote:
quote:
ORIGINAL: bhole74
John
Excactly. I find their site to be not very user friendly and go to Tower instead. Plus, it's kind of boring.
Good judgement comes from experience. Experience comes from bad judgement.
(in reply to 50%plane)
       Post #: 31
RE: Monocote or ultracote?? - 12/16/2005 3:43:13 PM
MinnFlyer
Status: offline
quote:
ORIGINAL: woops
What temp do you use? With or without a sock?
To tell you the truth, I have no idea.
I just set the dial on my iron to one position for tacking, The numbers are so small I never bother to read them, and then I usually use a heat gun for shrinking.
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
       Post #: 32
RE: Monocote or ultracote?? - 12/17/2005 3:51:53 AM
adstott
Status: offline
[/quote]
there is more MK in a 6 ft. roll, another + for MK.
[/quote]
I just bought two rolls of Ultracote and it came in 8 foot rolls.
-Tower Trainer .46 AX: -Twist 50sx: - Sukhoi .46ax:- Futaba 9c radio: Northern IL, Freeport
       Post #: 33
RE: Monocote or ultracote?? - 12/17/2005 7:01:31 AM
Mods-R-Me
Status: offline
Yep, I can confirm this. You even get more Ultacote for less money. Looks like Ultracote in leading the way.
Kelvin "Mods" Verrett
www.MRM-RCModels.com
(in reply to adstott)
       Post #: 34
RE: Monocote or ultracote?? - 12/17/2005 11:55:10 AM
JNorton
Status: offline
Mods-R-Me,
There really isn't a right answer. It's not a contest. Both have their supporters, both work well. It's what your local hobby shop has in stock. Personally fiberglass and paint beats both hands down for durablity and gloss. Then there are the fabrics. There are many different methods of covering a ship even using brown paper and glue!
John
Saito Member #467
(in reply to Mods-R-Me)
       Post #: 35
RE: Monocote or ultracote?? - 12/17/2005 3:28:15 PM
bhole74
Status: offline
They must have added 2 ft from the last time I bought some.
Just measured a 2M roll of UC, 6' 6-1/2" x 23" 5/8". MK: 26" x 72"
That comes up to
UC 1852 sq. in.
MK1872 sq. in.
Edit for measurements
< Message edited by bhole74 -- 12/17/2005 3:38:50 PM >
       Post #: 36
RE: Monocote or ultracote?? - 12/17/2005 9:56:42 PM
sebo
Status: offline
Horizon carries ultracote. I just got 3 rolls of yellow.
I didn't like ultracote when it first came out. This is the first time in 10 years that I have tried it.
I like it. I like the old monokote too. Haven't tried the new stuff.
I'm probably going to stick with ultracote. This stuff is really nice for going around curves.
I am using the trim iron to work a strip of covering into the hinge gaps before doing the main covering of the elevator, rudder and ailerons. Just extend the control surface to the max and iron the covering in.
< Message edited by sebo -- 12/18/2005 9:53:10 PM >
       Post #: 37
RE: Monocote or ultracote?? - 12/20/2005 12:17:35 AM
mrbigg
Status: offline
Both!!! Ultracote has the nice checker patterns and such. Monokote the nice shine.
As far as adhesion goes, I think they both stink. My Ultracote covered plane sags worse than any Monokote one I've covered. So on my latest project, I'm taking "Rolling Circle"s suggestion of using Sig Stix It or Coverite for Film. the LHS had the Coverite so that is what I used. Man what a difference! I'll NEVER cover a plane without using this stuff again.
This plane has both Ultra and Mono on it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by mrbigg -- 12/20/2005 12:20:35 AM >
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
(in reply to sebo)
       Post #: 38
RE: Monocote or ultracote?? - 5/15/2008 5:13:20 PM
oldflyer123
Status: offline
I have used both extensively. I have been using monkote since the 1970's and ultracote (oracover) since it came out from goldberg in 1980's.
Monokote has more colors and distributers plus more trim sheets and paints to go with it.
Ultacote is easier to use. I primarily use it for the wrinkle problem. Monokote is horrible for wrinkles and gas bubbles (I use a paper tiger to get rid of the bubbles). I have to reshrink my monokote planes continually.
My ultacote planes I touch up a few wrinkles in the spring and it is good for the whole season.
The only time I use monokote now is because I need a color that I really want, which is about half the time.
Oh, and Utracote is like magic around curves. And if you want to strip a plane, and I do because I keep my planes a long time and recover them after a few years, the Ultracote comes off much better than the Monokote.
< Message edited by oldflyer123 -- 5/15/2008 5:16:42 PM >
If you love to build you have to pay the price
(in reply to skrez)
       Post #: 39
Jump to:
