Monocote or ultracote??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Monocote or ultracote??
Page: [1] 2   next >   >>
Login
Monocote or ultracote?? - 12/14/2005 7:18:22 PM
heavythumbs
Status: offline
I am just about ready to cover my GP ultimate and am wondering which one to go with. I have used monocote on previous planes but havent tried ultracote before. Which one is better or easier to work with? It seems to me that ultracote has more color options. Thanks for any thoughts.
Heavythumbs
       Post #: 1
RE: Monocote or ultracote?? - 12/14/2005 7:31:11 PM
Sport_Pilot
Status: offline
Ultracote is easier to work with and is lighter. Monocote is thicker and a bit more durable.
(in reply to heavythumbs)
       Post #: 2
RE: Monocote or ultracote?? - 12/14/2005 7:58:53 PM
Edwin
Status: offline
I thought it was the other way around, but it dont matter. Ultracoat. Once you use it you wont go back to moneykote.
Edwin
(in reply to Sport_Pilot)
       Post #: 3
RE: Monocote or ultracote?? - 12/14/2005 8:39:36 PM
bhole74
Status: offline
...until you get a roll that wrinkles everytime the sun comes up. The blue Ultracoat I used on my Seniorita needs reshrunk every time I fly it and I must be very careful not to have the seams lift while doing it. It is much easier to apply than Monokote, so I would say it is a draw. Money wise they are about the same, avg. $11-12/ 6ft. roll, which Monokote is 3" wider (more covering). Monokote wins the color selection by a long shot.
_____________________________
Had I known that flight was going to cost me $100 per second, I wouldn't have flown 30 seconds!
(in reply to Edwin)
       Post #: 4
RE: Monocote or ultracote?? - 12/14/2005 9:06:57 PM
spuck5644
Status: offline
Both are excellent coverings. MonoCote is actually a bit lighter in weight, despite the "feel". UltraCote works at much lower temps so it is easier to apply. I much prefer Ultra, but Mono does win the "shine" competition by a mile. Both are very strong and durable. If you are happy with your application using MonoCote, You'll LOVE Ultra.
My .02 worth after covering over 100 planes. :-)
AMA#4939
(in reply to bhole74)
       Post #: 5
RE: Monocote or ultracote?? - 12/14/2005 9:21:01 PM
Mods-R-Me
Status: offline
I used exclusively monkote for years, until I tried ultracote. Now I use strictly ultracote. Mono goes over curves easier, but if you plan your covering process well; ultra is just as good IMHO.
Kelvin "Mods" Verrett
www.MRM-RCModels.com
(in reply to spuck5644)
       Post #: 6
RE: Monocote or ultracote?? - 12/14/2005 9:45:07 PM
MinnFlyer
Status: offline
I haven't met the curve that MK does better than UC.
Here are my obsevations:
MK has more colors.
UC is more durable (It's a bit more "Rubbery" and less prone to breaking, where MK is more brittle and will pop open easier)
Trim Solvent works on MK, but not on UC
I don't care what anybody says - BOTH COVERINGS WRINKLE - get used to it
If there's a difference in shine, I sure don't see it.
The next two are the BIG differences:
UC beats MK hands-down when it comes to applying it. It shrinks more and it stretches more.
MK's adhesive is more permanent than UC. This is a pro and a con for BOTH.
Example. If you iron down a wrinkle in MK, it will be there forever - unless you replace the covering - But removing MK can be a bear if it's been on for a while. In this situation, this is not good
With UC, you only have to add heat, and it will peel right off. In this situation, this IS good
But if you are trying to tighten an area near the edge of the covering by heating it, MK's adheasive will not allow the edge to be pulled in as easily as UC.
So you see how the different adhesives can be good or bad.
My preference is to use Ultracote because it is SOOO much easier. If I need to heat close to a seam, I just protect the seam with a wet paper towel.
< Message edited by MinnFlyer -- 12/16/2005 3:35:51 PM >
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to Mods-R-Me)
       Post #: 7
RE: Monocote or ultracote?? - 12/14/2005 9:51:59 PM
50%plane
Status: offline
quote:
ORIGINAL: Edwin
Edwin
Really? MONOKOTE is WAY better than ultracroak. Here's the two most recent planes I've covered. The Kaos is all MONOKOTE and the Telemaster is all MONOKOTE except for the gold. When I was putting on the Ultracroak, it would distort on me. It lost most of it's ability to stick quickly, and it was just a major pain. It shrunk so much that I couldn't keep it's shape when spanning a hinge gap. There's NO way that Ultracroak is better.
Woops
Click to see fullsize image.
Click for fullsize
Click for fullsize
Model Airplanes don't kill people. Chuck Norris kills people.
Christopher A. Todd AMA# 637636
(in reply to Edwin)
       Post #: 8
RE: Monocote or ultracote?? - 12/14/2005 9:59:23 PM
MinnFlyer
Status: offline
woops, your name says is all.
Your iron was too hot.
UC uses a lower temp than MK
Mike B.
(in reply to 50%plane)
       Post #: 9
RE: Monocote or ultracote?? - 12/14/2005 11:10:29 PM
BBW Walt
Status: offline
They both are a PITA....
(in reply to MinnFlyer)
       Post #: 10
RE: Monocote or ultracote?? - 12/14/2005 11:24:43 PM
Test005
Status: offline
I like Ultracote, or "oracover" as it's named here in Europe.
I also tried Monocote, but as a beginner builder I just find Ultracote more forgiving and easier to apply...
The paperbacking is also good imo because it's good to draw patterns on and also it comes off very easy. The Monocote's plastic backing can sometimes be hard to peel off.
So far, I'm all Ultracote/Oracover
(in reply to BBW Walt)
       Post #: 11
RE: Monocote or ultracote?? - 12/15/2005 1:00:35 AM
50%plane
Status: offline
quote:
ORIGINAL: MinnFlyer
What temp do you use? With or without a sock?
Woops
       Post #: 12
RE: Monocote or ultracote?? - 12/15/2005 1:38:39 AM
BobbyGee
Status: offline
quote:
ORIGINAL: woops
Woops
I've just done my first application of UltraCote and simply followed the instructions:
Apply to the frame at the 200 degree temp at which the adhesive activates. With a sock add 10 degrees.
I shrunk with the iron at the 300 degree temp. that shrinkage is supposed to begin. It shrunk as I moved the iron over it. With a sock, ditto, add 10-15 degrees.
Really an easy covering to apply. I bought a thermometer for the iron so as to be able to get accurate temp. readings. This stuff works as advertised. I've enjoyed the process of working with it.
Instructions also say that if it starts to sag, reshrink at a slightly higher temp. than before. This I won't know until the plane goes to the field.
Folks in the know say you do have to watch shrinking near seams because they can pull back. My covering scheme hasn't had me face that issue yet.
BobbyG
       Post #: 13
RE: Monocote or ultracote?? - 12/15/2005 1:58:44 AM
heavythumbs
Status: offline
Sounds like I will give that ultracote a try... to apply a stripe or one color over another can I use the windex method?
(in reply to BobbyGee)
       Post #: 14
RE: Monocote or ultracote?? - 12/15/2005 2:02:20 AM
bhole74
Status: offline
This is very true. However, in MY experiences, I have found Monokote wrinkles after a day in the sun, Ultracoat wrinkles just sitting in my hangar. I can iron it out every day (UC), sitting in a conditioned office, then have to do it again in the morning. BTW, there is more MK in a 6 ft. roll, another + for MK.
       Post #: 15
RE: Monocote or ultracote?? - 12/15/2005 3:16:58 AM
PilotFighter
Status: offline
It seems for the first few season changes, my models, (covered with Monokote) will need a little touch up ironing. But once the models are two or three years old, the coveing seems to stablize or something. Every now and then I will notice a few wrinkles and take out the iron. But for the most part Monokote is very stable.
turn left, your other left
       Post #: 16
RE: Monocote or ultracote?? - 12/15/2005 3:57:06 AM
blw
Status: offline
