kotuku
Joined: 2/9/2007 From: Blenheim, NEW ZEALAND Status: offline
Hi I have a 40 Mk II ARF still in the box, and have ordered a Saito 62 four stroke. I have and intended to run a Super Tigre GS40, but would prefer the cleaner and better sounding four stroke. So much that I fly smaller electric planes and E Gliders, rather than the messy GS40. I think it's a nice plane and would look better with the four stroke. I went for the Saito as the recommended OS 52 is now discontinued, and the Saito is better valve in New Zealand, from RCBandit.co.nz. My question is about prop size and ground clearance. Fly from rough grass strips will be using the recommended larger wheels without wheel spats. The Saito 62 recommended prop range is 11x7-13x7. If I went to 12 inch will I leave enough ground clearance? Not after too much prop, as I don't want to hover it 3D style. Just looking for clean smooth flying sports plane. Perhaps a 11x7 will be enough?
