servo glitching normal?
Tower Hobbies
Logged in as Guest
  Printable Version
Futaba 12ZAP 72mhz/FASST complete plus...
Seller:  sevans16
Details:   $1,200.00   |  9/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> servo glitching normal?
Page: [1]
Login
servo glitching normal? - 11/15/2002 5:30:15 AM
petergordon
Status: offline
I have the following setup being tested for my 30% edge.
Futaba 6XAs
HITEC 5625 x 4
HITEC 805
6V battery
I understand that the buzzing is from the digital servos - fine.
I plugged one of the 5625's into my retract port and it gives me a glitch that affects all of the other servos every few minutes, or when the retract servo is loaded up a bit. Is this normal? I don't plan on running retracts obviously (edge 540, but that'd be cool!) but it isn't out of the question to use a digital servo for retracts since it is full programmable.
Thoughts?
Peter Gordon
_____________________________
Peter
       Post #: 1
servo glitching normal? - 11/15/2002 10:49:42 PM
MikeMayberry
Status: online
There should not be any feedback from any of the servos. Are you using a regulator?
Mike.
(in reply to petergordon)
       Post #: 2
servo glitching normal? - 11/16/2002 7:31:33 PM
petergordon
Status: offline
No, I'm not using a voltage regulator. But how many people actually do? I'm just using a 5 cell sanyo pack.
Peter
Peter
       Post #: 3
servo glitching normal? - 11/18/2002 10:23:32 PM
MikeMayberry
Status: online
I don't know... I would suggest you send it to us so we can check it out.
Mike.
       Post #: 4
no difference - 11/19/2002 2:26:14 AM
petergordon
Status: offline
That is the thing though. It doesn't seem to matter which servo I plug into the retract port. All of my new 5625's make the jitter occur. Otherwise, they seem to work just fine. Only when plugged into the retract port is there a glitch.
Oh well...
Peter
Peter
       Post #: 5
servo glitching normal? - 11/19/2002 2:31:21 AM
MikeMayberry
Status: online
That's kind of like when you go to the doctor and you tell him it hurts when I do this... and the doctor says "Don't do that then!"
Mike.
       Post #: 6
servo glitching normal? - 11/19/2002 7:07:19 AM
petergordon
Status: offline
Mike,
Are you telling me not to use Hitec Digital servos in my retract port?
Peter
Peter
       Post #: 7
servo glitching normal? - 11/19/2002 9:57:13 PM
MikeMayberry
Status: online
Well, since I see no reason to use a digital servo for retracts and there apears to be an issue with your particular set up then it might be easier to just not use the digital if everything else is fine.
Mike.
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
