RE: Aviation Models 33% Yak Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
Great Planes Giant Aeromaster ARF - ARF
Seller:  JSZ
Details:   $600.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Aviation Models 33% Yak Build Thread
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Aviation Models 33% Yak Build Thread - 1/4/2006 9:40:42 PM
Columbo
Status: offline
The plane is built light yet strong. The interior construction is top knotch. All the pieces appear to
be laser cut and all the joints have an excellent fit. There is plenty of room inside the fuselage to
work and place all of your components. The rudder servo bay is pre-cut for those who want to use
the pull/pull system.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Columbo)
       Post #: 26
RE: Aviation Models 33% Yak Build Thread - 1/4/2006 9:52:31 PM
Columbo
Status: offline
The plane comes with what appears to be fairly complete heavy duty hardware set. I plan
to use most if not all of it. It also comes with two nice large wheels, spinner, fuel tank and
wheel pants as I have already mentioned. It even comes with a large rudder servo arm for
the pull-pull system. The only other hardware I might need to buy are some push rods and
switches.
Click for fullsize
Click for fullsize
       Post #: 27
RE: Aviation Models 33% Yak Build Thread - 1/4/2006 10:00:11 PM
Columbo
Status: offline
The plane really grows as you assemble it. When I first removed the fuselage it looked like it belonged on
a 30% plane. I couldn't wait to see how the plane looked, so I did a partial assemble. In person, the wing
area looks huge on this plane. A wing area of 1740 sq in for a plane that will weigh only 20 lbs should produce
a serious 3D floater. I am going to have my cowl custom painted. The cowling is very high quality and will be
painted to match your plane unless you specify otherwise. You will also have the option to have the canopy
trimmed in black.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Columbo -- 1/4/2006 10:05:24 PM >
       Post #: 28
RE: Aviation Models 33% Yak Build Thread - 1/4/2006 10:05:00 PM
erjpilot
Status: offline
Columbo,
Any chance you can weigh the bare airframe and hardware pack. I am interested in getting one of these planes, but I am curious if it will really finish at 19.5 lbs with a ZDZ 80 RV. Also I thought the new planes were coming through with the canopy frame areas painted to match the fuse top covering. It appears as though your canopy is totally clear. From your pictures it looks nicely built.
Thanks, Travis
       Post #: 29
RE: Aviation Models 33% Yak Build Thread - 1/4/2006 10:06:44 PM
Columbo
Status: offline
Travis,
The canopy frames will be matched if you specify. I'll try to have a bare weight posted
sometime this weekend.
Greg
< Message edited by Columbo -- 1/4/2006 10:09:56 PM >
(in reply to erjpilot)
       Post #: 30
RE: Aviation Models 33% Yak Build Thread - 1/4/2006 10:18:20 PM
Columbo
Status: offline
Notice the fit of the wings within the fuselage socket. No big spaces or gaps . Also the control
surfaces come pre-hinged and include heavy duty plastic hinges with a metal connecting rod.
So far, I am very impressed with the model. I plan to start constuction tomorrow and will post some
more pictures Friday. I contacted Gerhard at AI, and he reaffirmed that the engine should be here
by mid January. If that is the case, I should be able to maiden by the third or 4th week of January
weather permitting.
Greg
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Columbo -- 1/4/2006 10:19:12 PM >
       Post #: 31
RE: Aviation Models 33% Yak Build Thread - 1/4/2006 10:27:13 PM
jrjohn
Status: offline
The plane looks very nice, it would be good to know what the kit weighs if possible
John
< Message edited by jrjohn -- 1/4/2006 10:28:32 PM >
_____________________________
If we all think and say the same things, only one of us is necesary.
       Post #: 32
RE: Aviation Models 33% Yak Build Thread - 1/4/2006 11:49:14 PM
SpaceW
Status: offline
Thank you Colombo!
Is the stab attached to the fuse in this way : http://image.rcuniverse.com/forum/upfiles/25855/Hn61101.jpg ?
Why ther are no holes in the the foam? The other toc1 yaks have holes!
(in reply to jrjohn)
       Post #: 33
RE: Aviation Models 33% Yak Build Thread - 1/5/2006 12:53:13 AM
Columbo
Status: offline
Not sure what you mean by holes in the foam. The stab attaches with
an aluminum tube. The elevator servo fits inside the stab.
Greg
(in reply to SpaceW)
       Post #: 34
RE: Aviation Models 33% Yak Build Thread - 1/5/2006 1:54:55 AM
PowerPlay
Status: offline
Are the ailerons set up for 1 or 2 servos?
       Post #: 35
RE: Aviation Models 33% Yak Build Thread - 1/5/2006 5:21:29 AM
Columbo
Status: offline
The ailerons are set up for 2 servos.
Greg
(in reply to PowerPlay)
       Post #: 36
RE: Aviation Models 33% Yak Build Thread - 1/5/2006 11:39:26 AM
SpaceW
Status: offline
holes in the foam means like that :http://image.rcuniverse.com/forum/upfiles/25855/Ri70301.jpg
Thanks for the pics!
       Post #: 37
RE: Aviation Models 33% Yak Build Thread - 1/5/2006 2:28:02 PM
