RE: Aviation Models 33% Yak Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
Composite-ARF Extra 260 3m - RTF
Seller:  snobird
Details:   $4,900.00   |  8/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Aviation Models 33% Yak Build Thread
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Aviation Models 33% Yak Build Thread - 1/7/2006 7:48:33 PM
Columbo
Status: offline
Maxun,
The color on my plane is flame red ultracoat. The 33% won't be much more expensive to build than the 30%.
The difference is mainly two exra servos, a slightly more expensive engine and a slightly more expensive airframe.
So if you are willing to spend ~$400 more, I would go with the 33%.
Greg
(in reply to maxun)
       Post #: 76
RE: Aviation Models 33% Yak Build Thread - 1/7/2006 10:23:35 PM
plaster93
Status: offline
Thanks for the pics Greg,hope to be ordering one in a few weeks.
(in reply to Columbo)
       Post #: 77
RE: Aviation Models 33% Yak Build Thread - 1/8/2006 6:00:19 PM
jrjohn
Status: offline
Greg, hows the build going, any surprises so ? Quality and fit still up to par? I was wondering how the horizontal stabilizers are secured to the fus. Same as the 37.5%?
john
_____________________________
If we all think and say the same things, only one of us is necesary.
(in reply to maxun)
       Post #: 78
RE: Aviation Models 33% Yak Build Thread - 1/8/2006 11:42:37 PM
Columbo
Status: offline
No suprises so far. Everything is pretty straightforward as far as the assembly goes.
Matter of fact, I haven't been using a manual. Construction is light and top notch with
excellent fit of the parts. The stab mounting is straightfoward. Just cut the ultracoat
from the screw sockets and mount onto the wing tube with the incluced screws and
washers. Ultracoat also needs to be cut from a secondary hole in front of the wing tube
for the servo leads. Securing the servo inside the stab is a little tricky, but not bad.
Greg
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to jrjohn)
       Post #: 79
RE: Aviation Models 33% Yak Build Thread - 1/8/2006 11:45:47 PM
Columbo
Status: offline
For those using cans, the exit for the can exhausts can be seen in this photograph.
Just cut the ultracoat from the rectangular area.
Greg
Click for fullsize
       Post #: 80
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 12:08:10 AM
cope
Status: offline
Greg, what size servo arm are you using? are u using du-bro arms, thanks Brian
       Post #: 81
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 12:30:48 AM
Columbo
Status: offline
Yes,
I am using the Dubro heavy duty large servo arms.
Greg
(in reply to cope)
       Post #: 82
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 1:18:03 AM
RVBlack
Status: offline
what are you useing for servo's ?? and rudder?? 5955 ?? thanks, RV
       Post #: 83
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 1:21:33 AM
jrjohn
Status: offline
I wonder if we can get away with one servo on the rudder, say a 5955?? Guess we won't know till somebody tries it
john
(in reply to RVBlack)
       Post #: 84
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 2:09:00 AM
cope
Status: offline
John, I am only going to use one servo for the rudder 8611a 320oz of torque should be enough
       Post #: 85
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 2:16:45 AM
jrjohn
Status: offline
Looks identical to my EF Yak!
(in reply to cope)
       Post #: 86
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 2:20:38 AM
Columbo
Status: offline
One servo on the rudder should be fine as long as you stick with something like the JR 8611a or Hitech 5955
which are both metal gear, high torque servos. Not sure what the equivalent futaba servo would be. I am using
the 8611a on all control surfaces.
Greg
(in reply to cope)
       Post #: 87
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 4:20:31 AM
hobdean
Status: offline
Say carrol,
How was it shipped?
Cant wait to see it fly.
Let me know when you get it flying.
(in reply to Carroll-RCU)
       Post #: 88
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 12:40:17 PM
TooLy
Status: offline
quote:
ORIGINAL: Columbo
S9152 maybe ? it's a little bigger then standard servo but use bigger gears, Chief aircraft recommend this for the rudder of the 35% yak.
~Roei~
       Post #: 89
RE: Aviation Models 33% Yak Build Thread - 1/9/2006 2:08:10 PM
Carroll-RCU
