diamondave
AZ, USA Status: offline
cool, i may have to get one, i think i will try the b though, i didnt like the 23a on my zdz60, too flat imo, the b worked nice, closer to a 23-8 menz that i liked also, not sure if the same will hold true on this set up, but thats my thoughts anyway, i like the 26-8 i am running on my 80 now just how bad is the stock landing gear on this thing? i heard you should not even use it on any of the size yaks from sd models, is it that bad? my buddy has an aeroworks 100cc yak and his gear was spreading out even on soft landings, he strung a thin metal cable between the gear a few inches down from the fuse, nice and tight, it helped alot and isnt that noticable, anyone try anything like that with this one?? i may still order the cf gear cause i like carbon fiber anyway but just curious if its a must or not
