diamondave
AZ, USA Status: offline
i have a question about the top plate for the engine box, do you think it would be okay to cut it short from the front, like back to the 1st notch or so? i need access to my mixture screws, and i was thinking then i could get at my motor bolts easier too, i have lock nuts so need to get inside incase changing thrust or whatever, i will have 3 "U" shaped notches, 2 for the bolts and one for the carb settings, or just cut the entire thing about 2 inches or so back, i am thinking it would still be strong cause the main firewall it self is right there, and most of the side support would be there middle to back, make any sense??, i could cut notches in the side panels instead for bolt access, but the top need to be cut either way for cabr adj., thought about glueing some rails in and screwing it in place, but i think epoxing in is stronger, even with some cut away, any thoughts??
