wind junkie
NY, USA Status: offline
quote:
ORIGINAL: diamondave well over all it went well, i need to move the cg back some more for sure, more importantly my rudder geometry is wacky, i thought it was going to be okay but its not, i think that aluminum arm has too much offset for what i need, if i snug the wires up at center, its way too tight at throw, i could riff out a slide solo if i were dicky betts , and if i snug them at throw then its slopy at neautral, i am going to get a different arm, i guess the offset one right? we dont use strait ones anymore on a set up like this do we? my horns at the rudder are close to the hinge line, maybe a little behind but no more than a 1/4, looks like less actually, anyway a guy at my field who has set up many big planes said my set up is way off, that arm i used with the kit is more than 3/4 offset from the servo screw, hopefully just replacing the arm and cables(mine may be too short now) should fix the problem, will call tbm tomorrow, other than that i was impressed, i only flew it 2 times cause of the loose rudder, but it was good, flat spun upright and inverted nice(even with the forward cg), lots of power, very stable in a hover and excellent pull out with the menz 26-8, i will try my vess 26b next time out too for the heck of it, this has the poetential to become my new favorite plane just need to do some adjustments, any ideas on the rudder? If you cross the cables, you need to mimic the geometry you have at one end exactly on the other end. If you want to keep that servo arm, then you need to figure out how to get the 3/4" offset at the rudder. Conversely, you could measure what you have at the rudder, and then mimic it at the servo. Of course, measure the distance between the pivot points too as they should be the same. Just get a piece of sheet aluminum from K&S or use some G10 layered to give you strength to mount the ball link bolts in there and you'll be all set. It pays to be precise. Even 1/8" makes a difference in the cable tension.
_____________________________
Arguing with an engineer is like wrestling a pig. Everyone gets dirty and the pig likes it.
