diamondave
AZ, USA Status: offline
got some good flights today, new pull pull works like it is supposed to , going out again tomorrow, today was dialing in cg with velcro on my batts, i was going for hands off inverted, ive done that with other acro planes, so little by little moving batt back, flying inverted, trying flat spins, and seeing how it slowed for landings, thats how i tell my cg also, inverted spins were great from the start, upright got a little flatter with less throttle as i went back with cg, and the landings got nice and slow, but heres whats wierd, i dont know if it was my imagination or the increasing winds throughout the day, but it seemed like it got squrrlier in a hover and trolls, i know aft cg can effect the elevator making more sensitve but it shouldnt make hovering less stable should it?? i ended up where the nose will slighty drop inverted, close enough for me, barely any down needed to hold it, so i know built a little tray and wire tied in nicely, but i am curious to try in the morning again when its calm, i thought that was odd with the hovering thing, it was incredibly stable when i started, then got more twitchy with the cg back farther, like i said it was getting windier so i wont know until i try again with calmer weather, but any opinions on that? if it does seem worse i may move it slightly forward again and see if it gets stable again, the only drawback would be upright flat spins may not get as flat(unless i give more throttle) and the landing may be a tad quicker, by no means hot, just quicker, i do know i enjoyed the stable hovers early in the day more than the flatter spin at the end, if that makes sense
