Blindsides
NE, USA Status: offline
Well I ended up going with OS .46's. They were on the shelf and I did not want to wait for the TT. Just for everyones benefit. If you choose the newer OS .46 with the remote needle valve, you have to modify the engine mounts that come with the kit. You can not put the engine 11.2 cm from the firewall if you use the OS. Since the mounts that come with the kit are quite beefy I modified the mount by taking half the surface off the part of the engine mount where the needle valve hits the mount, with a band saw. You can also relocate the needle valve or use differant engine mounts, I figured it was easier to modify the mount. I did not have a camera charged so I do not have any pictures of the mount yet.
