RE: Draganflyer Navigation Lighting Systems
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Draganfly Innovations Products >> RE: Draganflyer Navigation Lighting Systems
Page: <<   < prev  1 2 3 4 [5] 6 7 8   next >   >>
Login
RE: Draganflyer Navigation Lighting Systems - 4/7/2006 3:04:51 AM
Hooch
Status: offline
Don't forget the dime!
(in reply to madean)
       Post #: 101
RE: Draganflyer Navigation Lighting Systems - 4/7/2006 3:59:24 AM
Sky High
Status: offline
I have been using these light sticks from Wal-Mart for a few flights now and they are really cool looking but they are kind of big. They are very affordable at 2.50 each and light in weight but I think their size and collective weight is slightly affecting the way my DF flies. I have also found that they are permanently sealed so you can't change the batteries. What kind of crappy design is that?! I'm going to cut mine open to change the batteries when they get weak. What a waste to throw away perfectly good assemblies and LEDs just because the batteries go dead. One other important thing if you get any of these. Make sure that you prevent them from pivoting upward into the travel area of the rotors due to aggressive maneuvers. The stiffener rods will pivot during flight because of the offcenter weight of the light sticks. If this happens the lghtsticks will block the rotors' clearance and the rotor could jam and you know what happens next.......... I will post video of them in use shortly.
http://www.garritylites.com/site/retail_details.php?recid=87
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Sky High -- 4/7/2006 4:57:11 AM >
_____________________________
Up there, you don't have time to think, if you think, you're dead!
Never mess with a pilot having more rotors than you!
(in reply to Hooch)
       Post #: 102
RE: Draganflyer Navigation Lighting Systems - 4/7/2006 4:57:44 AM
Sky High
Status: offline
Here is another source for custom lighting products that seems to have more components for making your own system. madean, they apparently own VoodooFx or they are their supplier. I found that Jupiter 2 chase light ring for $85.00. It has around 32 LEDs on it. They also sell something called Laser Laces for shoes or whatever. I had seen these a while back but forgot about it. They are only $14.95 for two 36" fiber lines available in 8 colors. As far as price, low power requirements (3 small button cells) and weight, that seems like a great deal for fiber optic lighting. Scroll all the way down the page to see it all, it is unbelievable how many applications they offer!
www.fiberopticproducts.com
www.fiberopticproducts.com/Laserlaces.htm
Commercial
www.laserlaces.com/60.wmv
Click for fullsize
Click for fullsize
< Message edited by Sky High -- 4/7/2006 7:06:15 AM >
(in reply to Sky High)
       Post #: 103
RE: Draganflyer Navigation Lighting Systems - 4/7/2006 12:37:16 PM
madean
Status: offline
Sky, Where did the picture of the round circuit board come from? I'd like to check out that site.
Mike
       Post #: 104
RE: Draganflyer Navigation Lighting Systems - 4/7/2006 1:19:05 PM
targit
Status: offline
Will you be fitting a subwoofer?
       Post #: 105
RE: Draganflyer Navigation Lighting Systems - 4/7/2006 4:34:29 PM
Sky High
Status: offline
quote:
ORIGINAL: madean
It's on this page but go to the bottom for a list of links to every component and circuit you could think of.
www.fiberopticproducts.com/Models.htm
       Post #: 106
RE: Draganflyer Navigation Lighting Systems - 4/7/2006 5:10:59 PM
madean
Status: offline
Thanks for the link. Nice unit, but $85 +shipping.
       Post #: 107
RE: Draganflyer Navigation Lighting Systems - 5/1/2006 9:28:01 AM
Dreddy
Status: offline
hi Sky,
just found out my SAVS has passed bordercontrol in brussels!!
Shame its a holiday today ,but will have it before my birthday lol
i was wondering wich setup from flitelites you are using on your SAVS??
thx Dreddy
p.s. do you have a stocknumber for the cable @ DF,then i can command that as well?
       Post #: 108
RE: Draganflyer Navigation Lighting Systems - 5/1/2006 11:04:38 PM
Sky High
Status: offline
I just have the standard 5 light kit with the controller and chose my colors and how many of solids or strobes that I wanted. There is only one power cable from DFI so just ask for the multi to 3 pin servo/power adapter cable. I hope you don't want any custom work done because he doesn't do that anymore.
(in reply to Dreddy)
       Post #: 109
RE: Draganflyer Navigation Lighting Systems - 5/2/2006 12:13:24 AM
Koop
Status: offline
SkyHigh,
Don't forget to mention ElWire from vibelights.com The laser laces are pretty cool, but weight wise they aren't the best option. Check out my new lighting configuration, the LED in the center is an RGB disk configuration diode, the ones on each arm are blue, and the surrounding frame is lime green (ElWire).
Click for fullsize
       Post #: 110
RE: Draganflyer Navigation Lighting Systems - 5/2/2006 2:35:34 AM
Sky High
Status: offline
Well, I did order a couple of sets of laser laces, blue and white, and they are very light weight and have self contained power. They also have three profiles, solid, single and double strobe. I have two sets on my DF and when the strobe patterns fall out of sync it is rather interesting looking. You also can't beat the $14.95 price for a turn key solution. You really have to be in total darkness to see the full intensity of the light though. I bet that each fiber run with the battery capsule weighs less than the El Wire. I will post pictures of this set up soon. What made you think the laser laces were so heavy?
< Message edited by Sky High -- 5/19/2006 3:57:43 AM >
(in reply to Koop)
       Post #: 111
RE: Draganflyer Navigation Lighting Systems - 5/2/2006 5:52:19 AM
Koop
Status: offline
SkyHigh,
It was an assumption judging by the pictures and the fact that you have two power sources with batteries. ElWire uses a very small dc to ac inverter and the whole kit weighs less than 1.5oz If the laces are indeed lighter than I apologize for misinforming anyone. The great thing about ElWire is the simple fact that you have a continuous bright light that is visible for miles. I haven't seen the laser laces in action so I guess that my information regarding them should be disregarded.
Koop
       Post #: 112
RE: Draganflyer Navigation Lighting Systems - 5/2/2006 6:07:12 AM
Sky High
Status: offline
No need to appologize. I have to agree that I was concerned about the weight judging by their product pictures too. I was very glad to find just how light they really were. One of the three sequences is solid continuous light. They are just not as bright as I would want them to be.
(in reply to Koop)
       Post #: 113
