RE: Draganflyer Navigation Lighting Systems
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Draganfly Innovations Products >> RE: Draganflyer Navigation Lighting Systems
Page: <<   < prev  1 2 3 4 5 6 7 [8]
Login
RE: Draganflyer Navigation Lighting Systems - 5/9/2007 8:13:20 AM
Sky High
Status: offline
I already did show my UFO flying in post #176! Nope. My DF couldn't stand to lift any more weight.
_____________________________
Up there, you don't have time to think, if you think, you're dead!
Never mess with a pilot having more rotors than you!
(in reply to hiaber)
       Post #: 176
RE: Draganflyer Navigation Lighting Systems - 5/9/2007 8:22:51 AM
tend2it
Status: offline
quote:
ORIGINAL: Sky High
I know ... I meant with the chase light stick version ...
--Eric--
(in reply to Sky High)
       Post #: 177
RE: Draganflyer Navigation Lighting Systems - 5/10/2007 8:01:37 AM
tend2it
Status: offline
Here is a lighting test of the madean chaser light addition with my mods added to my alu-tweety X-3D X-UFO ... it actually fit perfectly inside with some coaxing. I couldn't flight test it yet ... too windy outside ... but the 20g extra weight is lighter than the FlyCamOne camera ... so it shouldn't be a problem lifting it.
http://www.youtube.com/watch?v=QIB5-oudL_o
--Eric--
(in reply to tend2it)
       Post #: 178
RE: Draganflyer Navigation Lighting Systems - 5/11/2007 2:58:41 AM
Sky High
Status: offline
That was really cool! Can you slow the chase rate down? Where was that music from?
       Post #: 179
RE: Draganflyer Navigation Lighting Systems - 5/11/2007 5:43:01 AM
tend2it
Status: offline
quote:
ORIGINAL: Sky High
Thanx ...
I think that was the slowest setting (I wanted it a little slower too) ... but you can speed it up ... the music is a live concert excerpt of The Cybermen by Murry Gold from the great new Doctor Who 2005 series
--Eric--
       Post #: 180
RE: Draganflyer Navigation Lighting Systems - 5/13/2007 12:23:55 AM
BB_DF
Status: offline
I'm sure this has been thought of before, but it's easy to mount a 9V battery near the C.G., even on the SAVS. A strip of Velcro is attached to the battery & open space on top of the lower board. A cheap battery might be better because it's lighter, and the LEDs don't use much power. A small strip of Velcro on the back of the 9V plug secures it when not being used.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 181
RE: Draganflyer Navigation Lighting Systems - 5/13/2007 5:44:42 AM
Sky High
Status: offline
BB_DF, are you aware of the regulated multipin 5v tap underneath the flight board providing power from the lipo? The 9v is alot of unnecessary weight to be carrying.
(in reply to BB_DF)
       Post #: 182
RE: Draganflyer Navigation Lighting Systems - 5/13/2007 6:02:29 AM
BB_DF
Status: offline
quote:
ORIGINAL: Sky High
Thanks, I'll look for it. I guess it's documented on the Spectrolutions web site. Is that a standard connector I can get in a hobby shop? I can use that space now to carry small animals .
       Post #: 183
RE: Draganflyer Navigation Lighting Systems - 5/13/2007 6:56:18 AM
Sky High
Status: offline
It's the long multi-pin next the 3 pin underneath the flight board. You can get the pre-made adapter from DFI or get a pinout diagram and do it yourself. I like the custom adapter myself because it has standard connectors that fit accessories. The third wire is the control wire for servos and accessories.
Click for fullsize
Click for fullsize
< Message edited by Sky High -- 5/13/2007 7:21:56 AM >
(in reply to BB_DF)
       Post #: 184
RE: Draganflyer Navigation Lighting Systems - 5/13/2007 7:06:41 AM
BB_DF
Status: offline
Thanks, Sky High - very helpful as always.
       Post #: 185
RE: Draganflyer Navigation Lighting Systems - 5/13/2007 10:29:28 AM
kokomiko
Status: offline
BB_DF
You can find it here: http://spectrolutions.com/pdf/pinouts.pdf
(in reply to BB_DF)
       Post #: 186
RE: Draganflyer Navigation Lighting Systems - 5/13/2007 3:58:18 PM
BB_DF
Status: offline
Kokomiko,
Thanks. Any reason to pull the 5V off the long connector rather than the short one?
- BB
(in reply to kokomiko)
       Post #: 187
RE: Draganflyer Navigation Lighting Systems - 5/13/2007 10:03:32 PM
Sky High
Status: offline
quote:
ORIGINAL: BB_DF
Kokomiko,
I'm not sure but I think the 3 pin is 11.1v. You may want to put a meter on it. Other than that, you can use accessories like servos and nav lights while using the camera system.
(in reply to BB_DF)
       Post #: 188
RE: Draganflyer Navigation Lighting Systems - 5/14/2007 6:32:53 PM
kokomiko
Status: offline
The "cam" 3-pin connector and the first 3 pins on the multi connecter are actually the same.
+5V - this is a regulated 5V source used with the ground pin
Vbat - this is unregaluted battery voltage used with the ground pin , 11,1V (not sure if the voltage equals the battery power...and maybe there is not the restriction to the 150/250mA limit as on the +5V...)
GND - Ground = negative battery terminal
For lights use +5V and GND on the multipin so you still can connect your cam on the 3 pin
