Hitec Digital Servo / Best Speed and DB
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Hitec Digital Servo / Best Speed and DB
Page: [1]
Login
Hitec Digital Servo / Best Speed and DB - 12/21/2005 3:29:41 PM
zzw26n
Status: offline
Michael,
Where would you go to get good numbers to Program in for Servo Speed and DB for ;
HS-5925 on Throttle = super fast , speed # ?? and DB should be?
HS-5955 single on Rudder = speed ? and DB?
HS-5945 singles on Ailerons = speed? and DB?
thanks, Ward
       Post #: 1
RE: Hitec Digital Servo / Best Speed and DB - 12/21/2005 4:00:39 PM
mglavin
Status: offline
Ward,
I set up all my servos for the lowest possible deadband 1:1. Some open up the deadband when servos are hard linked/ganged, I never have I simply make sure the linkage is setup correctly and use an inline volt/amp meter to assure there is no binding anywhere throughout the travel arc (I use these devices on single servo installations for the same reasoning).
Factory default "Speed" settings are the fastest possible, I don't see a need for slowing anything down, mine are all programmed for the fastest possible speed.
_____________________________
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to zzw26n)
       Post #: 2
RE: Hitec Digital Servo / Best Speed and DB - 12/21/2005 4:05:35 PM
zzw26n
Status: offline
Michael,
That was super fast, thanks.
On Speed, for the HS-5925, is 28 faster than 40 ?? ( range is 28-62 ??)
thanks again, Ward
(in reply to mglavin)
       Post #: 3
RE: Hitec Digital Servo / Best Speed and DB - 12/21/2005 4:12:40 PM
mglavin
Status: offline
Ward,
The higher number is faster, some early servos show a default value of "40" this is purported to actually be a range of 16-64. See the programmer manual for more info on early servos and variables for same.
Michael Glavin
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
