RE: TIPS for Beginners on the Walkera DF #4
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: TIPS for Beginners on the Walkera DF #4
Page: <<   < prev  1 [2]
Login
RE: TIPS for Beginners on the Walkera DF #4 - 5/11/2007 8:30 AM
Kevinator9
Score: 100
Last Login: 11/8/2009
Status: offline
Oh! I have something useful to add, i feel proud to help with this one
Here it is...
Many people have asked how to hook up a Walkera Dragonfly #4 to FMS (Free/Flying Model Simulator). I have personally used these exact steps and it works perfectly although I cannot vouch that it will work with other helicopters (I have heard that it may work with other 4 channel fp's like the Dynam Hughes 300). If you follow these steps with a DF4 TX then you should be ready to use FMS in no time.
First you will need PPJoy (Click Here). (I am expecting you to have FMS and the Walkera DF4 TX already...)
You will need this cord
The circle end of the cord plugs into your DF4 TX, and the square end plugs into your PC's serial port (The one it matches up with).
Now here are the steps to setup PPJoy so it will work with FMS.
Download ppjoy.
When it is downloaded go to the "ppjoy" folder. In there is "setup.exe". Open that and it will install the folder "parallel port joystick".
Then go to control panel and open "parallel port joysticks" which is a "configuration utility for joysticks that plug into the machines parallel port". Open that.
Click "add".
It will open the "configure new controller" window. Then change the "parallel port" drop down from "LPT1" to "virtual joysticks".
Plug in and turn on your transmitter then click "add".
Then ppjoy will go through downloading whatever it needs to and it may take a while.
After that to use your transmitter on fms you need to do this.
Open "ppjoycom" in the "ppjoy" folder and change the "serial protocol" to "zhen hua 5 byte protocol" then turn on (and plug in) your transmitter. You will see the "waiting for stream int..." change to "reading serial stream...".
Then open fms (leave ppjoycom open reading the serial stream) and go to the "controls" tool bar then in that go to "analog controls".
Then change from "no interface" to "joystick interface".
Then click mapping calibration.
Change everything so that the screen looks exactly the same as the picture below (numbers and ticks) and then click "calibrate" and follow the instructions given. (It will ask you to move your sticks around a little in big circles so it can adapt the range, then when they are moving smoothly, click next and it will ask you to center all the sticks, then click finish, then the OK button and you're away flying!)
_____________________________
Kyosho Caliber 6
Kyosho Caliber 3 in Fun-Key Agusta 109A .50 Scale Fuselage
Hide Signatures
(in reply to GTX SlotCar)
       Post #: 26
RE: TIPS for Beginners on the Walkera DF #4 - 9/6/2007 8:47 PM
Ctreble
Score: 100
Last Login: 10/12/2007
Status: offline
Re: Kevinator9
Thank You Thank You Thank You!! You helped me so much. The whole setup works for the saber transmitter adaptor as well.
Thanks again
1
Hide Signatures
(in reply to Kevinator9)
       Post #: 27
RE: TIPS for Beginners on the Walkera DF #4 - 9/7/2007 7:39 AM
Kevinator9
Score: 100
Status: offline
Glad I could help!
Kyosho Caliber 6
Hide Signatures
(in reply to Ctreble)
       Post #: 28
RE: TIPS for Beginners on the Walkera DF #4 - 9/7/2007 1:05 PM
MiniCwik
Score: 100
Last Login: 4/14/2009
Status: offline
Great tips! and a bump for a great guy!
Nitro Trk - Himoto Eldorada 1:10 4WD (w/bling)
EP Helis - T-Rex 500 CF (401/9257) & 450 SE V2 (Scorpion -8V2/401/9257)
Hide Signatures
       Post #: 29
RE: TIPS for Beginners on the Walkera DF #4 - 9/7/2007 3:58 PM
USHobbySupply
Score: 100
Last Login: 11/3/2009
Status: offline
Indeed, gary knows his stuff
Michael Bernstein, President, USHobbySupply
Please PM me if I miss your question in a thread
Hide Signatures
(in reply to MiniCwik)
       Post #: 30
RE: TIPS for Beginners on the Walkera DF #4 - 10/30/2007 10:43 PM
jmhh
Score: 100
Last Login: 6/20/2008
Status: offline
Hi Kevin..hope you are still around...have tried to follow your
steps to the letter and understand them all, but not working...
what seems to be the problem is that when I start PPJoy with my
Walkera TX on, it is set at Virtual Joy Stick and the Zhen Ha 5
protocol and it says "reading serial bits"....but the Baud,
Data Bits , Parity,and Stop Bits are "grayed out" and there
doesn't seem to be any data actually going through...in FMS
have settings like you state, but FMS can't see my TX for some
reason...I take it we don't need to run Smart Pro Po...any ideas?
...do I need to do "mapping" in the Parallel Port Joy Stick in
Control Panel?...tried that but nothing seems to happen or work
....thanks for any help....John H.
Hide Signatures
       Post #: 31
RE: TIPS for Beginners on the Walkera DF #4 - 10/31/2007 4:18 AM
Kevinator9
Score: 100
Status: offline
I cannot remeber if this is what is meant to happpen but I think greying out of other parts may be normal, not sure as I haven't used FMS in a while sorry. I will reinstall fms and ppjoy on my pc and see what is going wrong...
Kyosho Caliber 6
Hide Signatures
(in reply to jmhh)
       Post #: 32
RE: TIPS for Beginners on the Walkera DF #4 - 10/31/2007 4:46 AM
Kevinator9
Score: 100
Status: offline
Those parts are meant to be grey when virtual joystick is selected. Maybe you are not using a serial port? If you are, then chek your connections and make sure your tx is turned on.
Kyosho Caliber 6
Hide Signatures
       Post #: 33
RE: TIPS for Beginners on the Walkera DF #4 - 10/31/2007 12:50 PM
jmhh
Score: 100
Status: offline
Hi Kevin...thanks for the prompt response and all the hard
work reinstalling FMS....I am using the serial port as the cable
you recommend fits it..also checked in "My Computer" and
found serial port working...its something, as FMs just doesn't
see the VJS when it is runing and with TX on (sure of that)
and PPjoy running...have used PPJoy before with Clear View, but
not on this computer...oh well, may have to buy an Eflite TX
that I know works with FMS..thanks for all your help and cheers
to you in the "Land of Outdoor Adventure"...I hope to visit NZ
sometime...John H.
Hide Signatures
       Post #: 34
RE: TIPS for Beginners on the Walkera DF #4 - 11/1/2007 6:01 AM
Kevinator9
Score: 100
Status: offline
Very sorry that it hasn't worked, if all has been done then I am not sure why it wouldn't work. Very sorry about that...
EDIT: Maybe you are not using a dragonfly #4 TX or it is a new dragonfly #4 2007 tx model? I can only promise this works with dragonfly #4 2006 tx model.
Glad to help as much as possible
Kyosho Caliber 6
Hide Signatures
(in reply to jmhh)
       Post #: 35
RE: TIPS for Beginners on the Walkera DF #4 - 11/16/2007 12:32 PM
seb p
Score: 100
Last Login: 12/6/2007
Status: offline
hi, your post says "make sure it looks the same as the pic below" yet there is nothing below?? thanks!!!
seb
Hide Signatures
       Post #: 36
RE: TIPS for Beginners on the Walkera DF #4 - 11/16/2007 1:09 PM
seb p
Score: 100
Status: offline
dont worry, found it!!!
for those interested, here it is
[URL=http://imageshack.us] [/URL]
i also followed your steps, and it worked without a hitch!!!
Hide Signatures
(in reply to seb p)
       Post #: 37
RE: TIPS for Beginners on the Walkera DF #4 - 11/16/2007 4:08 PM
jmhh
Score: 100
Status: offline
Hi Guys...thanks for the additional responses...ugh...in meantime I
bought a used Eflite BCX2 TX off eBay to use with FMS , as I know how that works
...but I still have a Walkera TX (WKMH04) and the serial cable if anyone would like
it...just PM me...John H.
Hide Signatures
(in reply to seb p)
       Post #: 38
RE: TIPS for Beginners on the Walkera DF #4 - 11/16/2007 9:59 PM
Kevinator9
Score: 100
Status: offline
Thanks Seb P
I did have it up there but the pic must have expired or something.
I think I will create a pack that you can download to use.
EDIT: Oh Dear, I can't do that :P, I lost paint from my pc which I use for pictures...
Also that picture needs to be set out like this...
(x means tick the box and a blank means leave unticked.)
Mode 1
                 Channel     Inv     Exp
Rudder:             4         x       x
Elevator:           2                 x
Aileron:            3         x       x
Throttle:           1         x       x
Tail:               4         x       x
Nick:               2                 x
Roll:               3         x       x
Pitch:              1         x       x
Mode 2
                 Channel     Inv     Exp
Rudder:             4         x       x
Elevator:           3         x       x
Aileron:            2                 x
Throttle:           1         x       x
Tail:               4         x       x
Nick:               3         x       x
Roll:               2                 x
Pitch:              1         x       x
< Message edited by Kevinator9 -- 11/16/2007 10:24 PM >
Kyosho Caliber 6
Hide Signatures
(in reply to jmhh)
       Post #: 39
RE: TIPS for Beginners on the Walkera DF #4 - 4/7/2008 5:54 PM
zagith
Score: 100
Last Login: 5/5/2008
Status: offline
Newbie here!
I have a Walkera #4 (Dragonfly) . I charged the batteries up, turned on the remote and then hooked up the battery in the helicopter. I heard a quick, PSSSTT. sound like a air actuator enabled. Anyway, the helicopter LED light blinks red, the remote has full power (in the green), but the helicopter will not respond.
I have made sure to turn on the remote first then hook up the battery in the helicopter. I made sure the Throttle and throttle switch are OFF (in the down position). I have removed and reseated the crystals in both the remote and the helicopter in hopes it was a loose connection and verified all the other connections were secure in the helicopter. Still it will not respond.
The dip switches are set to factory default:
1 - ON
2 - OFF
3 and 4 - ON
5-8 - OFF
Can anyone provide some helpful insight as to what could be the problem or am I screwed!? I would greatly appreciate any other troubleshooting ideas or if I am doing something incorrectly, the manual this thing came with is a joke.
My
-Zag
Hide Signatures
       Post #: 40
RE: TIPS for Beginners on the Walkera DF #4 - 4/8/2008 6:04 AM
Kevinator9
Score: 100
Status: offline
You may get a better answer on this topic: http://www.rcuniverse.com/forum/m_2833333/tm.htm As this is more frequently visited. Hope they can help more than I can
Kyosho Caliber 6
Hide Signatures
(in reply to zagith)
       Post #: 41
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.922RCU1
