Rex Rutledge
TX, USA Status: offline
Michael, I have the same aircraft and servos as thevirginian. I did not notice any issues with the 5625's when setting up my ailerons until I used the Y's to test the finished wings together. I have two installed aileron servos that obviously need to be updated and one of my elevator servos (yet to be installed) is marked V 1.04 without the X'd garbage can. I telephoned Hitec Service, and they informed me of the upgrade required. I plan on removing the installed servos and sending all the V1.04 servos for update. I am a little frustrated with this, but I am concerned with the fact that you stated that V1.04 servos must be programmed with the V1.04 programmer. During my phone call to Hitec Service I mentioned the fact that I am unable to locate a programmer to purchase, but I have 2 friends that have earlier version programmers. I ask if I would be able to set center and endpoints with the earlier version programmer and the reply was yes. ?????? I purchased these servos late October through my LHS. I prefer supporting the LHS and they have been trying to get a programmer for me. I have been searching other sources myself, and nobody has an idea when they will be available. Do you have any idea when the next batch of V1.04 programmers will be available? I understand that a small shipment has been received, but it looks like they all vanished! Thanks in advance, Rex Rutledge
