Blade CP = Expensive!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Blade CP = Expensive!
Page: [1] 2   next >   >>
Login
Blade CP = Expensive! - 12/29/2005 5:26:33 AM
03fatboy
Status: offline
They sure do market this thing well, make it sound rather affordable.
After 2 days I realize it might not be for some.
So far about $20 or $30 per hour is what I'm having to coming up with.
Anyone know where all the $5 blades are? $15 for blades is OUTRAGEOUS!!!
I know the dough has to be made somewhere but doesn'e every dealer know you gotta hook'em first?
I'll go broke in a week if
A) I can't find blades for about $5.
B) I don't learn to fly this thing pretty quick.
Looks like 25 years of fixed wing R/C piloting and 3Ding foamies in the front yard hasn't helped much. I need to stick w/plan A and hope for the best.
Any ideas?
TIA
       Post #: 1
RE: Blade CP = Expensive! - 12/29/2005 5:30:05 AM
E_Heli
Status: offline
You need SIM!
Crashing without hurting your wallet.
Free FMS: http://n.ethz.ch/student/mmoeller/fms/index_e.html
(in reply to 03fatboy)
       Post #: 2
RE: Blade CP = Expensive! - 12/29/2005 5:44:55 AM
Truggies
Status: offline
You should have bought the Blade CX and learned how to fly it first. Then move to the Blade CP. The blades for the CX are only $3.99 for a pack of 4 bottom and $3.99 for a pack of 4 top blades. I have one and love it. I tought myself to fly with it very quickly and am now looking at getting the CP to go to the next level. The CX is so new I'm having a hard time finding other parts though. But I still love my Blade CX Its a blast!!!!!!!!!!! and cheap parts so far.
_____________________________
Xray XT8, OS Speed Tuned, Spectrum.
(in reply to E_Heli)
       Post #: 3
RE: Blade CP = Expensive! - 12/29/2005 5:52:30 AM
reiffron
Status: offline
i know how you feel, when i first started i felt like i would never learn to fly this thing! then i took it apart and built it like it says in bdavidsons build thread and it hovered much better! and now i can hover thru several battery packs with no crashes!! do you have the training gear? it is a must for learning. just make sure it is set up correctly and take your time. try a simulator a cheap way is to download fms for free and you can buy a game pad at wal mart for 20 bucks its not great but its cheap. just stick with and soon it will just click!!! and the rush is awsome!!!!!!!!!!
       Post #: 4
RE: Blade CP = Expensive! - 12/29/2005 6:07:28 AM
dj6666969
Status: offline
quote:
ORIGINAL: Truggies
Why waste money on the cx? If you buy it and then move up to a better heli your gonna have to learn most of it all again. The cx doesen't have a tail motor, gotta learn that. Also with the cx u can go right into a hover with not move trouble keeping it still, you move to the cp you gotta work harder to do it. Better choice to move to the cp and buy the training set and yes you will need to buy blades if u crash and wreck them but that is the part with flying a heli. fixed wing's are much easyer to fly while helis are the hardest to fly. If you think replaceing blades are bad try trying to fly it for the first time and hit a tree and get it run over causeing over 150 bucks worth of damage!
For that flight sim why do you all like it? I downloaded it and it taught me NOTHING. you pull back on it and it will stay in that position, it doesen't return to center. Landing you have to be perfect its retarded! I bought the G3 and it is the closest ive seen to the real thing! It has saved me from alot of really bad crashs and helpt my fear of crashing go down.
rc pro during the day.... street racer at night
(in reply to Truggies)
       Post #: 5
RE: Blade CP = Expensive! - 12/29/2005 10:58:31 AM
HeliHacker
Status: offline
Buying a CX depends on what someone wants to do with these things. If someone is interested in playing in their front room with little danger of crashing, then the CX is okay. If someone is more interested in learning what a CP type heli can do, then the CX doesn't get it. The money for the CX is far better spent on one of the top simulators which will teach many of the aspects of flying.
(in reply to dj6666969)
       Post #: 6
RE: Blade CP = Expensive! - 12/29/2005 1:16:37 PM
wfo
Status: offline
Buy or make training gear and stay on the ground!
(in reply to HeliHacker)
       Post #: 7
RE: Blade CP = Expensive! - 12/29/2005 1:54:42 PM
tripodrod
Status: offline
Blade is my first heli. Yes rotor blades are $15 and i have gone through three sets learning to hover in a very small space. Good news is after just two weeks of a battery here and there and I am now on to side in hovering.
Are you fixing crashed blades when you can? The leading edge is all that usually gets smashed up. Sometimes I flatten the edge back and C/A glue the white edge back down or use scotch tape to keep it down. I also put scotch tape along the entire leading edge and this helps from keeping the blade coating from splitting and ripping off. MAKE SURE you use equal amounts of tape or you will shake the heli to death!
And then when you really screw the edge up, you can cut the edges on a band saw or whatever tool u find fit. THEY MSUT be cut equall. I flip them over on the flat side and tape them together and then cut them together. You can cut about 1/2 inch (.5) into the blade before contacting the lead weight. Cutting too much into the weight will alllow it to dislodge during flight, which depending on what you like, you may or may not find exciting. They make great projectiles is what I am saying--so be careful.
So really I say that I went through three sets during learning stages, but I bet I fixed each set over 5 times, giving me about 15 really bad hits for $45.
I tried .30 nitro before (add up the cost of a boom strike. I had many due to the extra weight of a .30 nitro) and believe me $45 is cheap for what I put the poor Blade CP through. Rotor blades is all I ahve broke and I have hit the cement basement walls, steel support poles, water heater and furnace. Some of these crashes were with a good amount of speed too.
And don't give up. At first it seems like you will go through many parts, but you will "just get it" one day all of the sudden and the parts count/cost comes way down after that.
       Post #: 8
RE: Blade CP = Expensive! - 12/29/2005 2:36:06 PM
Norrmannen
Status: offline
Any heli = expensive !!!!
The counterrotating stuff is super for indoor winter activities and good for complete beginner (just forget Walkera stuff). I got one after having flown esky FP and Rexes for abt a year, great.
Sim is vital...
(in reply to tripodrod)
       Post #: 9
RE: Blade CP = Expensive! - 12/29/2005 3:38:08 PM
gsilver
Status: offline
Learning to fly a heli takes time. If you don't have the discipline to learn in the needed fashion, then save yourself a TON of money and stress and sell the heli while it still has value.
Heli's are expensive. You need to be able to swallow the cost of broken parts. Even the BEST heli people out there crash. Everyone... EVERYONE crashes. Its going to happen. Not once, not twice, but many times.
The reason I say this is..... The amount of money that you will save from getting a !QUOT!real!QUOT! sim (G3, Reflex, etc) will be in the truck loads. BUT, you must be disciplined again in that you dont treat it like a game and you fly in the sim as if your flying your $heli$.
The next thing is... for ALL of you people out there flying in your 700sqft apartment (I did this once, then realized I was stupid), get outside and into some soft grass that has enough area to where you're not going to hit yourself, cars or even the innocent spectator. The amount of time, and again money you will save from just being in an area that has space to allow you to be 3' above the ground and sliding out of control, yet having enough time to correct.... priceless.
Now, I am by now means an expert... I am actually a newb to helis. My only advantage is that my father has been flying them since before I was born. So i know just enough to be really dangerous. Yet, I have replaced 1 set of blades (yesterday) on my blade, which was due to stupidity and loss of discipline flying in gusty winds, 3!QUOT! off the ground while taking off a wind came and smacked the heli to the ground. I don't feel that I have anything more then anyone else, except discipline and a trust within myself that one day I will be good enough to crash during a fantastic 3D show, because a bee stung me or something. (You will crash.)
Sorry for the rant.
(in reply to Norrmannen)
       Post #: 10
RE: Blade CP = Expensive! - 12/29/2005 3:44:36 PM
rwthomas1
Status: offline
I own a Blade CP and an X400 and trained on a Sim. My buddy has a Blade CP and trained on a Sim. There are pros and cons to everything. The Blade CP is much more difficult to fly than the X400. You constantly have to work the tail to keep it in line as the battery discharges. It is also very touchy. I have watched my buddy crash his Blade so much I just had to get one myself to see if it was him. Its not. My heart was in my throat but he flew my X400 no problem. I should define "fly" we both just hover around..... Sims are very important but limited. They are excellent for teaching control input and orientation but thats it. I find that things happen much faster with the real thing and the Sim doesn't hold a candle to real stick time. Yes the blades for the Blade are not cheap and they are made cheaply. I have had good luck reinforcing the leading edge with 3M "scotch" type tape and then a full wrap of 2" wide clear packing tape on the end of each blade when then are NEW. This makes them more crash resistant from the getgo. That cheap white covering splits when you look at it. The tape reinforces and keeps this from happening too easily. The cheapest heli is one you don't crash. So practice carefully, use the Sim and don't do stupid things like flying in to confined a space, in a breeze, etc. Things we all do because we all want to fly but conditions aren't the best. I have flown in an indoor basketball court, once, and it was great. It made flying much less stressfull and easier with all that space, minimal obstacles and no wind. If you can get access to space like this, do so! I think a large open field with fairly tall grass on a windless day would be ideal also. RT
       Post #: 11
RE: Blade CP = Expensive! - 12/29/2005 4:29:02 PM
03fatboy
Status: offline
OK, parts problem solved (somewhat). Ordered blades from helidirect.com at $8/pr (5 for $40). Grabbed a set of sym blades to boot. I'm betting that will carry us thru the learning curve. Yes, I did say us. My 2 sons and myself.
Here's what we've done and learned...
First thing we did was balance the blades before the first flight which was needed! We run the blades rather loose (like a finger snap will send them 4+ inches).
Next we took a 3' x 1/8 CF rod, cut it in half and tye wrapped them to the skids. Once I wore off a tye wrap and didn't replace it, broke a skid, won't do that again. No ping pong balls, just sharp edges for minimal drag.
Swapped out the stock pinion using a gear puller and replaced it w/a 11T from the micro car parts collection for the half dozen or so 2 cell li-pos we don't use much anymore from the aircraft parts collection. Times range from 10 to 20+ minutes. Everything seems to run way cooler than compared to aircraft temps.
Adjusted the mains and found 75% throttle was required to hover, added some pitch to get her light at 50% (which I know is a bit low in the throttle dept, but the main motor still runs only warm). The gain and proportional adjustments are probably all screwed up now that we screwed w/them.
The flying area is about 30x30 fenced w/6', 8' wood privacy fence and 4' rought (sp) iron fence. We found after and hour or so moving 3 cars off the driveway is better for us - which might be part of the problem now - no cars to hit so we've gotten brave. The fences are actually heli magnets.
For the first 3 hours (or should I say about an hour for each of the pilots) the CP runs around looking more like a car than a heli. Gotta learn some of the sticks somehow. All the strikes have been minor doing it this way but once the leading edges of the blades get bent up and tips torn up the performance and stability goes to, well you know where. The tail strikes have been eliminated by adding fuel line tubing to the boom stake and extending the length a half inch. This might be a problem w/liftoff, but we don't know the difference and seemed to overcome it if that's the case.
The leap past ground effect has been a major jump with more sticks to learn and more movement with the ones we have a little experience with. "Landing" on the rotor head once or twice cost a main shaft. Perhaps it could have been straightened but at this point our best bet is to keep everything as well balanced as possible, again stability, vibration etc has considerable impact on performance and learning, right?
After 3 sets of blades now my youngest son can hover well if the nose is pointed in the right direction - he "backs" up well. Highest hover is 6 or 7' and a couple times over the 4' fence to land in the grass/yard (coming back is another story).
I've done better at the 1' height running around in 20' circes while keeping the nose pointed in the center. I have had a couple 3' hovers take place without incident.
By the time my oldest son gets to try his fingers the blades have a few scars so he does need more time w/pristine blade to catchup to our skill level (or lack of).
Helis react slower than aircraft so we all have a tendency of over reacting.
The gyro doesnt hold the tail as well as I would have guessed and seems to be effected by dropping voltage requiring constant, one click only trim to fly "hands free" (which BTW, I'm coming to the conclusion isn't real practical w/a heli). Only a few occasions have we acheived this hands free status in a few hours combined.
5+ mph wind whipping around combined with flat bottom blades and GE makes your knees knock.
The adjustments of the 4-in-1 has been hit and miss at best with no real concept of the best practice for adjustment.
These things like to jump a foot or 2 up for reasons beyond our comrehension (the head isn't sticky from what I can tell). Perhaps ground effect in combination with efficient lift or drop or???
After 3 or 4 hours we should be in better shape than today.
Overall, for 3 guys that never even looked at a heli, let alone understand how it can ever get off the ground and fly around, it's great fun - as we stand around scratching our heads.
Keep your wallet handy.
(in reply to rwthomas1)
       Post #: 12
RE: Blade CP = Expensive! - 12/29/2005 4:37:47 PM
HeliHacker
Status: offline
