RE: OFFICIAL Redcat Racing TRUCK thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: OFFICIAL Redcat Racing TRUCK thread
Page: <<   < prev  99 100 101 102 103 104 105 [106] 107 108   next >   >>
Login
RE: OFFICIAL Redcat Racing TRUCK thread - 4/24/2007 5:38 AM
mashn76
Score: 100
Last Login: 5/30/2007
Status: offline
here is a pic of the one for the tornado bb.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to ehroof)
       Post #: 2626
RE: OFFICIAL Redcat Racing TRUCK thread - 4/24/2007 5:59 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
bro, i checked all the sites i know of and i dont see it, email clermontmotorsports.com, allaboutfunhobbies.com and try redcats live help on their page, i dont have the sv, sorry bro.
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to mashn76)
       Post #: 2627
RE: OFFICIAL Redcat Racing TRUCK thread - 4/24/2007 3:57 PM
mashn76
Score: 100
Status: offline
thanks for the help ehroof. i will try contacting redcat. worst case i guess i will have to get the aluminum ones.
Hide Signatures
       Post #: 2628
RE: OFFICIAL Redcat Racing TRUCK thread - 4/28/2007 9:33 PM
mashn76
Score: 100
Status: offline
anyone know where to get tsunami wheels. i had a flat and took it apart and the foam crumbled.
Hide Signatures
       Post #: 2629
RE: OFFICIAL Redcat Racing TRUCK thread - 4/28/2007 9:35 PM
rclynx
Score: 100
Last Login: 7/25/2011
Status: offline
Most everybody just upgrades the wheels in sets I think
Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
Hide Signatures
       Post #: 2630
RE: OFFICIAL Redcat Racing TRUCK thread - 4/28/2007 9:49 PM
mashn76
Score: 100
Status: offline
do you know any that would be about the same size?
Hide Signatures
(in reply to rclynx)
       Post #: 2631
RE: OFFICIAL Redcat Racing TRUCK thread - 5/5/2007 3:51 PM
diddlfs
Score: 100
Last Login: 11/26/2007
Status: offline
Hi there
Is it normal that my engine is hardly putting out blue smoke?
I run it as rich as possible, tried different fuel's and nothing seems to make it smoke.
Is there an explanation for this?
Frank
Hide Signatures
       Post #: 2632
RE: OFFICIAL Redcat Racing TRUCK thread - 5/5/2007 5:49 PM
ehroof
Score: 105
Status: offline
you should have some blue or white smoke, do you have a temp gun, if its running over 250, it too hot. if you dont have a temp gun do the spit test, put a little spit or water on the head, if it sizzles and evaporates almost immediately your too hot, if it evaporates in like 5 seconds your ok.
Hide Signatures
(in reply to diddlfs)
       Post #: 2633
RE: OFFICIAL Redcat Racing TRUCK thread - 5/6/2007 2:42 AM
diddlfs
Score: 100
Status: offline
it is running around 270 but if i richen it any more, it will not run.
the truck had this problem right from the get go.
i do not know why that is.
any help is appreciated.
thanks
Frank
Hide Signatures
       Post #: 2634
RE: OFFICIAL Redcat Racing TRUCK thread - 5/6/2007 4:15 AM
ehroof
Score: 105
Status: offline
you may have and air leak, make sure the fuel cap is sealed, also the base of the carb. Make sure the fuel line is free by disconnecting it from the car and diconecting the pressure line from the tuned pipe, then blow in the pressure line, it should be fairly easy to blow into and should have air coming out of the carb side of the fuel line. if not check and make sure the fuel nipple is not clogged. Also make adjustments to the tuning needles in small incriments, like a 1/16 to 1/8 turn
Hide Signatures
       Post #: 2635
RE: OFFICIAL Redcat Racing TRUCK thread - 6/18/2007 9:55 PM
Damide
Score: 100
Last Login: 7/18/2007
Status: offline
Does anyone have any ideas to look at or check to see if all 4 wheels are spinning with the same speed or even if at all?
It really appears that the back 2 tires have all the power and the front two tires seem to only spin at a fraction of the speed of the rear ones.
I do have a Redcat Volcano and it appears it's been doing this from day one. Thanks for any advice/feedback.
Hide Signatures
(in reply to kosty83)
       Post #: 2636
RE: OFFICIAL Redcat Racing TRUCK thread - 6/18/2007 10:09 PM
Chubbysdad
Score: 100
Last Login: 12/22/2009
Status: offline
put it up on a block of wood or a stand
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake, Redcat Drifter
Hide Signatures
(in reply to Damide)
       Post #: 2637
ehroof
Score: 105
Status: offline
sit it on a block and start it, give it a little throttle and make sure the front wheels are spinning too. dont rev it alot since you can blow the engine if there is no resistance and you rev it high. if for some reason the fronts dont seem to be moving much maybe your axle holders are loose, you may need to tighten the grub screw in them, it would be the one that goes from the front of the trans to the front diff.
Hide Signatures
       Post #: 2638
RE: OFFICIAL Redcat Racing TRUCK thread - 6/18/2007 10:18 PM
Damide
Score: 100
Status: offline
Yes, I've picked it up, and looked at it while holding it in my hand (just like up on a block of wood). It does appear the rear tires rotate at a much much much faster rate than the front tires.
Possibly just tightening down the axle holders will fix this? no tinkering on the rear tires, just the front?
As always thanks for the help guys!
Hide Signatures
       Post #: 2639
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 9:01 PM
05mustang05
Score: 100
Last Login: 1/18/2008
Status: offline
Hey guys, just a quick, general question here, when I clean the air filter with warm water and soap, do I need to saturate it in oil afterward and then squeeze out the excess oil? If so, what kind of oil? Thanks in advance...
< Message edited by 05mustang05 -- 6/21/2007 9:04 PM >
Hide Signatures
       Post #: 2640
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 9:14 PM
ehroof
Score: 105
Status: offline
dry it, and put air filter oil on it and rub it in, sometimes i will put it in a plastic bag and kneed it around and work the oil in. then install it into the holder, dont oversaturate the filter, put enough to work into the whole filter. OHH, air fitler oil, your hobby or auto shop will have it.
< Message edited by ehroof -- 6/21/2007 9:15 PM >
Hide Signatures
(in reply to 05mustang05)
       Post #: 2641
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 9:29 PM
05mustang05
Score: 100
Status: offline
Thanks ehroof, you have been nothing but helpful!
Hide Signatures
       Post #: 2642
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 9:35 PM
ehroof
Score: 105
Status: offline
your welcome bro, anytime
Hide Signatures
       Post #: 2643
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 9:44 PM
05mustang05
Score: 100
Status: offline
I'm sittin here at work, and I can't wait to get home and run it. I'm planning on building a ramp for it today and maybe taking the car to some baseball fields near my house. I can't wait to get off work! haha
Hide Signatures
       Post #: 2644
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 9:48 PM
ehroof
Score: 105
Status: offline
lol, i know what you mean, today is my birthday, i am waiting for my kids to get home so i can open my presents, i am pretty sure one is a tremor car!!!!! I left the jobsite early today, figured what the heck.
Hide Signatures
       Post #: 2645
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 10:05 PM
05mustang05
Score: 100
Status: offline
Haha, well happy birthday my friend!!! Those little Tremors look like a lot of fun! Tell me what you think of em... well, that is IF you get one...
Hide Signatures
       Post #: 2646
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 10:08 PM
ehroof
Score: 105
Status: offline
thanks, i have the truck and truggy and i love them, alot of fun and suprisingly fast for their size. I have a video of them. i am pretty sure its a the car too, lol, i will let you guys know with a post.
http://s163.photobucket.com/albums/t288/ehroof/?action=view¤t=tremorsinstreet.flv
Hide Signatures
       Post #: 2647
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 10:11 PM
Damide
Score: 100
Status: offline
So I figured out my question from above....as far as why all 4 of my tires do not rotate at the same speeds.....Go figure I'm completly missing the linking arm on my front right tire.
now the big question what exactly is this part "called" It's a long slender bar that runs from the inside tire to chassis of the car, fits like a ball and socket connection. Obviously I'll need to replace it and was curious if anyone knew the exact name so I could look it up and order one (or 2 or 3!) just so I have some spares. The thing that concerns me is if my truck even had one to start with? That doesn't seem like a piece that could easily just fall out.
As always thanks in advance!
Hide Signatures
       Post #: 2648
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 10:24 PM
05mustang05
Score: 100
Status: offline
Have you ever tried jumping them? Just wondering how such a small car would take a jump... but then again, My Volcano is incredibly durable so far, so I'm sure it would be too. I might just have to get me one of those...
Hide Signatures
       Post #: 2649
RE: OFFICIAL Redcat Racing TRUCK thread - 6/21/2007 10:25 PM
ehroof
Score: 105
Status: offline
its called a dogbone and i am sure clermontmotorsports.com (clermonthobby) has them, drop him an email for the part to make sure you get the right one, there has been a mix up with the redcat dogbones.
Eddie
Hide Signatures
       Post #: 2650
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
