fred685
VA, USA Status: offline
I did a lot of testing a few years ago between my OS, Saito and YS 91's. The YS outperformed both by a bunch, but weighed almost as much as a 120. The Saito and OS turned almost identical PRM's on all the props I tried that a 91 would normally use. Both engines ran flawless during the testing. The only prop I found a difference on was an APC 16-8. Too much for both engines, but I was only testing on the ground at this point. Both engines could turn it at the same RPM, although I don't remember what it was. The Saito took about 8 seconds to get this prop going at full RPM, the OS got it going in about 3 seconds. Now I'm not an engineer, but I think the engines were equal in horsepower, but the OS was stronger in torque to get the bigger prop up to speeed faster. So this lead me to believe the OS was better. Then I flew the engines and the Saito performed better in the air, although not by much. So what does all this mean? Means ground testing with a tach is worthless. Performance in the air is what counts, not what a tach says. Fuel used for the testing was S&W 25%, and the OS was a non-pumped version. Fred
