manumenzella04
Joined: 7/30/2007 From: Santa Fe, ARGENTINA Status: offline
Hi there, Helismith: thanks for your suggestion. I took them out, and put some CA on them: they are now as new! I am now facing another problem. After only three and a half minutes of flying, the 430XL motor is HOT, so hot that the bottom part will burn your finger if you hold it there for more than a few seconds. I do not know the exact temperature to post it, as I dont have a laser thermometer, but I will try to get one ASAP and post the results here. The ESC is warm to hot, but i believe it is predictable since I am using the internal BEC to power 3x 65MG, 1x9650, and a 401 gyro. I checked the belt tension, and the gear mesh, and both appear to be alright. I also tried other |
