leejax02
Joined: 6/29/2004 From: jacksonville, FL, USA Status: offline
Tom J, I see you are in Fl. and check www.gravesrc.com which is Graves rc in Orlando. They stock most parts and if ordered by 2pm will go out the same day. Seeing your in Florida, it will go out FedEx Ground which is Next Day in the same state. Bemyself, the Hs-56 is not digital, but is has better gears(Karbonite actually) that ride on a bearing (top only)which gives it more precise centering,movement,holding power and durability. It is probably the best servo for the cyclic positions right now. A digital servo like the Futaba 9650, when used with a gyro with digital mode, operates at a higher precision and keeps the tail steady which SHOULD eliminate tail wag, drifting and should keep the tail more stable in 3-d manuevers. If you have the hs-55's then use them until you feel you need better and have the money. if you use a 56 on the tail, then hopefully you have a great gyro like the GY240 or the Gy401(which has the digital mode for future use with a digital servo when you get one). Does anyone have any pics they can post with the canopy on or off, just to show components and set-ups? Of course the bling shots are always great to see too .
