txaggie08
TX, USA Status: offline
Like i said in the pm....aparently mounting a brushless ESC under the receiver was a dumb idea, cause it was causing the motor to reset as it spun up. I got mad and took out the motor, then took apart the wiring and hooked it up to the receiver only(receiver out of the heli). Flipped the radio into acro(no curves that way) and reversed the throttle channel......bingo bob, It throttles up and down instantly, almost no hesitation. Im still not shure on hwo to program it for battery cutoff etc(leejax said he can help so we'll get that done LOL), but the motor now functions properly(ran it for aprox. 5 mins throttling up and down rapidly and slowly, no splutter, no restarts.). I messed the collective servo up, but once i get one of the other 9g's(i have a bunch ive been using in planes and cars) on my collective ill be good(collective IS the right term for up/down pitch(vertical) correct...... Making shure ive got the right term with the right function here.....) to reinstall the motor and see if i can get the gyro to work(im thinking thats why my gyro was working when i tested it with no motor on.....but then when i got it to spin up to a flight speed, it freaked out and started spinning in a circle(right before the motor promptly shut back off......) I will also get the wires with proper connectors in a few.....I bought wire today.
< Message edited by txaggie08 -- 1/13/2006 2:38:24 AM >
_____________________________
Proudest member of the Fightin Texas Aggie class of 08 Beat the h*** outa TU A-A-A-A-A!!!!. Fire fran and Torbush!!
