leejax02
Joined: 6/29/2004 From: jacksonville, FL, USA Status: offline
Zacko, the V2 is good, but the head and tail designs are not as smooth as an XL and it doesn't carry thr 325mm blades due to the previously stated shorter boom. Also, does not come in CDE(3 point swash linkage set-up). A V2 is still very capable, but it is probably easier to sell and buy an XL as you see fit. Had one, and opted for the XL. Iceman101, it is 10"x26" and 8" tall...case dimensions. ckoelliker, what pinion/tooth count are you running? Sounds like you can drop a tooth or two to get it where you need. Most ESC's governor mode does not hold a steady rpm...unless you opt for a Kontronik Jazz or something like it. Are you in St. Simoms Island? I was up there a while back and saw a hobby store right by the airport...think it was called Grays Hobboes or something like that. Been over 3 years ago.
< Message edited by leejax02 -- 1/21/2006 6:56:22 AM >
