malswift
FL, USA Status: offline
I am trying to finish up my TREX 450 SE but have some remaining questions: 1 - Where is the best place to mount the ESC (Phoenix 35) and what do I use to mount it (velcro, double sided tape, tie wraps???)? Will operating temps be so high that velcro or tape are out of the question? 2 - Do I need to insulate (shrink tubing, etc) the connectors from the motor (AON 2815-3500) to the ESC? When I soldered the connectors to each wire I put shrink tubing over those joints.......I just don't know if I have to insulate the connectors from each other to prevent contact and frying my electronics??? 3 - I am using HS-56 servos and a Futaba 9650 on the tail.......I hooked everything up electrically to check out my radio but noticed on the HS-56s there is not a lot of throw in either direction off center??? This is my first electric micro-heli..........is that normal for these micro servos? 4 - Any suggestions on how best to hide, stash, or tie up the maze of wires so this bad boy doesn't look like a airborne bundle of wires? Currently have the receiver aft of the motor as far back as possible........maybe move it to the front above the battery? I searched the gallery but didn't find any pics that were helpful. If you have some photos you can post that would help! Thanks for helping a newb and safe flying! Ed
< Message edited by malswift -- 1/29/2006 2:36:37 PM >
