RE: Ziroli F6F Hellcat Builder's Diary    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Ziroli F6F Hellcat Builder's Diary
Page: <<   < prev  17 18 19 20 21 22 [23] 24 25 26   next >   >>
Login
RE: Ziroli F6F Hellcat Builder's Diary - 6/18/2010 9:28 PM
mirce
Score: 152
Last Login: 6/19/2013
Status: online
Hi Dudde, grate Hellcat...
Best regards
Mirce
_____________________________
Rivets, Screws, Panel lines, Detail & Finish Sets, Paint Masks and other equipment for scale warbirds - www.nsmodelers.rs
Hide Signatures
(in reply to AntonioE)
       Post #: 551
RE: Ziroli F6F Hellcat Builder's Diary - 6/18/2010 9:37 PM
Nickrc3
Score: 100
Last Login: 5/8/2012
Status: offline
quote:
Final weight is 33 pounds with NO lead added for balance.
quote:
RCdude13, think you scale needs recalibrating, especially with you using a Robart retractable tail wheel assembly.
Hide Signatures
       Post #: 552
RE: Ziroli F6F Hellcat Builder's Diary - 6/19/2010 2:08 AM
RCdude13
Score: 100
Last Login: 6/17/2013
Status: offline
I'll re-check the weight of my Hellcat, but I'm pretty sure it is close. I used pretty much all contest grade balsa behind the CG, and added lots of lightening holes in the formers. I think not using fiberglass over the sheeting really cuts down the weight too. The tail wheel is a mechanical unit so it does not have the air cylinder. The bbi pilot has a pink foam and pipe cleaner body. I was hoping someone would ask how I balanced it without any lead...I used 3 - 3600 mAh sub-C NiMh battery packs behind the dummy radial. I figured I might as well add milli-amps instead of dead weight. The 3 packs weigh 24 ounces. My balance point is 5 1/2 inches behind the leading edge with the gear retracted.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Nickrc3)
       Post #: 553
RE: Ziroli F6F Hellcat Builder's Diary - 6/28/2010 12:25 PM
warks62
Score: 110
Last Login: 6/14/2013
Status: offline
Mrice, here is a pic of one side of my exhaust. Sorry for not posting sooner but I waited till I was going to do some work. 1- I wanted to see how things were looking like checking the bolts or anything coming loose. 2- I was ready to install a C&H electronic ignition conversion on the motor. I have converted my 3 G-62's with his kits and the result has always been great. Ran the engine after the install and the idle was stable and much lower. I forgot to put the tach on it but I could almost count the prop as it ran. Will see how it goes in the air maybe next week.
Click for fullsize
Randy, Enjoying Warbirds
Hide Signatures
(in reply to mirce)
       Post #: 554
RE: Ziroli F6F Hellcat Builder's Diary - 6/28/2010 4:06 PM
AntonioE
Score: 100
Last Login: 4/17/2013
Status: offline
It´s wonderfull.
Very, very nice job warks.
Hide Signatures
(in reply to warks62)
       Post #: 555
RE: Ziroli F6F Hellcat Builder's Diary - 6/28/2010 4:27 PM
mirce
Score: 152
Status: online
Randy, what is big box under engine?
Hide Signatures
       Post #: 556
RE: Ziroli F6F Hellcat Builder's Diary - 6/28/2010 6:13 PM
warks62
Score: 110
Status: offline
quote:
ORIGINAL: mirce
That is a box I welded up out of 1 1/2" steel to hold my weight for balancing. The weight is out at the end of that box. The weight ends up being just behind of the dummy engine.
Hide Signatures
(in reply to mirce)
       Post #: 557
RE: Ziroli F6F Hellcat Builder's Diary - 6/29/2010 8:09 PM
warks62
Score: 110
Status: offline
It was brought up before on a twin that would fit with more power and still be able to fit in Horiz. This one would fit with a prop extension and have a lot of power being able to spin a nice 3 blade not scale but a lot more power than the GT-80. If I had to do over I would of went with this instead. Now I do say that the GT-80 gives me more than enough speed but the vertical is not how I am used to and have to treat more in a scale manor. Thought I would share it gives all the specs in the manual but cap to cap is 10.5" or 267mm.
http://www.rcaer.com/userfiles/file/RC%20Aero%20YD-A%20112cc%20%20Operations%20Manual%202010.pdf
http://www.rcaer.com/store/Results.cfm?category=2
Hide Signatures
       Post #: 558
RE: Ziroli F6F Hellcat Builder's Diary - 7/10/2010 2:25 AM
mirce
Score: 152
Status: online
Today I made few experiments... In last few weeks my friend made for me new exhaust system. There are no any silencer inside, both are empty inside... Interesting is that they are not much louder than previous exhaust.
On first flight I have Xoar 24x10 and with Tony Clark exhaust plus my scale exhaust, GT 80 have 5900 rpm.
Now, with this exhaust I get 6100-6200 rpm, 200-300 rpm more than previous...
I try today with few more propellers and here is resultas:
- XOAR 24X10 - 6100 - 6200 rpm - 12,4 kilograms of thrust
- XOAR 23X 8 - 6600 - 6700 rpm - 13,8 kilograms of thrust
- XOAR 22x10 - 7200 rpm - 13 kilogram of thrust
So, conclusion is, when I have 5900 rpm with my early exhaust system, on my first fly, I have less than 12 kilogram thrust!!!
For model heavy more than 20 kilogram that is very under power...
Yesterday I get my new engine for Hellcat, Evolution 80 GX, so in future no more problem with under power motor...
This engine with 26x10 XOAR prop on 6350 rpm give 17,8 kilogram of thrust, and with 27x10 on 5750 rpm - 17,5 kg...
With Mejzlik 27x10 Evolution have 6200 rpm (I buy that prop)....
Does somebody know a measure of Evolution "pitts style" muffler for this engine? I need diameter and lenght... Thanks in advance...
Hide Signatures
       Post #: 559
RE: Ziroli F6F Hellcat Builder's Diary - 7/10/2010 2:55 AM
warks62
Score: 110
Status: offline
Mrice, I would look into maybe a Brison or Slimline muffler for the Evolution. I have had bad experiences with there 26 cc and the 35 cc muffler. They were very quiet but were very restrictive and it reduced the power by a lot unless the 80 is different. Also if you have a 26 inch prop you might put it on your plane and then check the clearance to the ground. When I flew mine with a 26-8 I touched the prop on the ground when landing maybe a 25-12 might work better overall.
Hide Signatures
(in reply to mirce)
       Post #: 560
RE: Ziroli F6F Hellcat Builder's Diary - 7/10/2010 3:30 AM
mirce
Score: 152
Status: online
Randy, thanks for answer...
I need some dimensions for start and my friend will made me exhaust here. It depend of space in to the cowl also... Here noise is no problem.
I am looking at Krumsheid, and some other sites and find some dimensions... They have some exhaust for engine up to 90 ccm, and it is 350mm lenght and 75mm diameter, but so long exhaust I can't put under cowl... Maybe some shorter but more mm in diameter... I will see...
G-Pete you know answer for all questions, help...
26" propeller is not so much shorter, maybe some three blade 25x10 or 24x10. This two are diameters which MVVS (Evolution) propose for 80 GX...
Mirce
Hide Signatures
       Post #: 561
RE: Ziroli F6F Hellcat Builder's Diary - 8/5/2010 12:46 PM
mirce
Score: 152
Status: online
In last few weeks I changed engine and yesterday make first engine start. Propeller is Metts (same as Xoar) 24x10, exhaust is MVVS. I must made all new engine mounts because holes from Zenoah GT 80 and MVVS are not on same place.
To eliminate dead weight, batteries for flaps (JR matchbox), lights and ignition are under cowl.
My first impression is that MVVS have more thrust but until now no any measure and, comparate with GT 80.
Few photos...
Regards
Mirce
Hide Signatures
(in reply to mirce)
       Post #: 562
RE: Ziroli F6F Hellcat Builder's Diary - 8/5/2010 6:28 PM
warks62
Score: 110
Status: offline
Mirce, that is looking good. Good choice on the 24-10 3 blade prop. That 27-10 would of touched the ground on landing sooner or later. There just is not enough ground clearance with the Robart gear. Looking forward to your flight with the new engine.
Hide Signatures
(in reply to mirce)
       Post #: 563
RE: Ziroli F6F Hellcat Builder's Diary - 8/10/2010 12:12 AM
navyt28
Score: 110
Last Login: 5/7/2013
Status: offline
Hallo Mirce,
Congratulation to this outstanding workmanship !
With this engine you will have power more than enough.
My Hellcat is also finished now and I am looking for a suitable Engine too. In order to the nois regulation and the better motor- sound I will use a four-stroke Gas-engine like the new Roto 85 FS . First Flight will be next year. (2 Fotos of my Hellcatat at moment).
Regards, Franz
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 564
RE: Ziroli F6F Hellcat Builder's Diary - 8/10/2010 2:11 AM
mirce
Score: 152
Status: online
Franz, your Hellcat is very nice... Can you give us some more details, weight, which engine you want to use...
Hope maiden will be fine...
Regards
Mirce
Hide Signatures
(in reply to navyt28)
       Post #: 565
RE: Ziroli F6F Hellcat Builder's Diary - 8/12/2010 12:35 AM
navyt28
Score: 110
Status: offline
Hallo Mirce
the weight of my Ziroli Hellcat is 9,9 Kg incl. Retracts, but without engine, servos, receiver and accus etc..
A club member of mine is designing a new V- Type-four Cycle gas-engine to use in my Model.
The Roto Engines, Roto 85 FS and the Roto 70V2, see www.rotomotor.cz , are worth having a look at.
It will take half year or longer, until I have news about my decision which Motor I will have in my Hellcat.
As soon as I have news, I will send pics again.
I´m looking forward to hearing and seeing news about your outstanding Hellcat !
Regards to you and your team !
Franz
Hide Signatures
(in reply to mirce)
       Post #: 566
RE: Ziroli F6F Hellcat Builder's Diary - 8/12/2010 10:57 PM
Detlef Schmidt
Score: 100
Last Login: 12/30/2010
Status: offline
Hi Franz,
congratulations for your superb HELLCAT.
Where do you live in Germany ?
I am living near Regensburg / Passau and if we are not too far away it would be nice to fly together with our HELLCATs once.
best regards
and "Servus" , Detlef
...and always happy landings !
Hide Signatures
       Post #: 567
RE: Ziroli F6F Hellcat Builder's Diary - 8/13/2010 1:03 AM
navyt28
Score: 110
Status: offline
Thank you Detlef !
You are invited to fly with your Hellcat this weekend 14/15 Aug. at "Volksfestfliegen in Dachau" !
It is every year a great event with many well-known "WB- Forum members "
Last year I had a Hellcat building report at Warbird-Forum , (my User Name, Yat-28E).
I hope to see you and your "Jadged " Hellcat this weekend! Anmeldung, mfc-dachau.de
best regards,
Franz
Hide Signatures
(in reply to Detlef Schmidt)
       Post #: 568
RE: Ziroli F6F Hellcat Builder's Diary - 8/27/2010 5:50 PM
mirce
Score: 152
Status: online
Yesterday I was finally made flight with my Hellcat with Evolution 80.
In fuselage I change position of servos for elevator so, they are now as forward as possible. As I wright early, new position of batteries for flaps, light and engine (under cowl) give me CG on the same place like in first two flights without add any weight. Hellcat is now 20,5 kilogram, without fuel. My tank is 0,7 litter and that is more than inaf for 10 minutes flight.
Before...
Now...
Hellcat with Evolution GT 80 engine is grate model.
Taking off is very safe, model is going strait with minor working with rudder. It need 60-70 meters (we have here grass airfield) before get in the air...
In the air it is flying excellent. For flying half throttle is inaf, but for all maneuvers Hellcat need full throttle. I am flying 13 kilogram heavy Top Flite Thunderbolt with G 62, and my impression is that Hellcat is all doing slower... But Hellcat is big and heavy and that give dimension of reality... I am so satisfied with this model...
Landing is very easy, down flaps, throttle on 1/4 and before touch down throttle on idle, little up elevator... No any filling that model is so heavy...
All in all, I am so happy with flying performance in this Hellcat - Evolution combination...
Mirce
Hide Signatures
       Post #: 569
RE: Ziroli F6F Hellcat Builder's Diary - 8/27/2010 7:20 PM
Scott Prossen
Score: 106
Status: offline
Congratulations Mirce!!! That's one heck of a great looking aircraft. How about a 120" version next ???
Thats fantastic news. Now get good on the sticks and brinng her over for Top Gun 2011.
All the best,
Scott
Hide Signatures
(in reply to mirce)
       Post #: 570
RE: Ziroli F6F Hellcat Builder's Diary - 10/25/2010 5:04 AM
WARBIRDRCER
Score: 118
Status: offline
wULF190,
Can you tell me from your building and flying experience how the heat and stick method holds up under the use and longevity test of time and airborne cycles?
I am wanting to try this on my AD-5. A friend whom I also inherited a Z F6F short kit from told me of your method, so I have spent the last few nights reading your F6F build thread to see if I could acquire an answer to the question. By the way, great thread. When ready to start the F6F, would you mind if I tap in on your thread?
WARBIRDRCER
Steve - Flight Leader - Warbirds Over Oklahoma
Spitfire & P-40 Brotherhood #1
Hide Signatures
(in reply to wulf190)
       Post #: 571
RE: Ziroli F6F Hellcat Builder's Diary - 10/25/2010 6:21 AM
wulf190
Score: 105
Last Login: 6/15/2013
Status: offline
So far so good on the several birds I've used this on...out in sun, engine runs, etc..all not a problem. The bond is not gummy at all, so it seems to hold up quite well. I would rec. just practicing a little on some test pieces first to get the "feel" of the iron and how speed of movement is necessary...and be ready to sacrifice the iron to the building shop, as some glue will inevitably find it's way onto the surface and wreck it for future clothes ironing tasks it seems (don't ask me how I know that ).
The thread did turn out to be very profitable for info, from several awesome models and builders, so by all means, use it to it's fullest extent. I really enjoyed building the 'Cat.
Hide Signatures
(in reply to WARBIRDRCER)
       Post #: 572
RE: Ziroli F6F Hellcat Builder's Diary - 10/25/2010 7:24 AM
WARBIRDRCER
Score: 118
Status: offline
Wulf190,
Thanks for the iron tip. I will hit some OJT spare parts before moving to the real deal. I just bought a new iron for some fabric work, so I will add the old to the build shop as stated. What is on your build table now?
Hide Signatures
       Post #: 573
RE: Ziroli F6F Hellcat Builder's Diary - 10/25/2010 12:30 PM
AntonioE
Score: 100
Status: offline
Mirce, navit28, why the dirference weigh 9.9kg w/e in front of 20.5 kgs?
I think is so much diference.
Hide Signatures
       Post #: 574
RE: Ziroli F6F Hellcat Builder's Diary - 10/25/2010 1:42 PM
navyt28
Score: 110
Status: offline
Hallo Antonio,
I mentioned that the Model weight is 9.9kg without Engine -Servos- Accus ectr..
< Message edited by navyt28 -- 10/25/2010 6:27 PM >
Hide Signatures
       Post #: 575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
