CG for Extra 330 PANZL
Tower Hobbies
Logged in as Guest
  Printable Version
Hangar 9 46% TOC Ultimate 10-300
Seller:  wardie
Details:   $8,000.00   |  10/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> JTEC / RADIOWAVE Support >> CG for Extra 330 PANZL
Page: [1]
Login
CG for Extra 330 PANZL - 1/1/2006 11:16:35 PM
bep
Status: offline
Does anyone know the CG on the 35% Extra 330 PANZL? If so, please post................. Thanks, BEP
       Post #: 1
RE: CG for Extra 330 PANZL - 1/2/2006 2:24:25 AM
al
Status: offline
the CG is right on the wingtube.When you go to balance the plane pick up the fuselage only by placing your fingers in the wing tube socket, set the balance to be level or slightly nose down to start. This is the best way to balance it.
Al
JTEC/RADIOWAVE
_____________________________
JTEC/RADIOWAVE
FUTABA
(in reply to bep)
       Post #: 2
RE: CG for Extra 330 PANZL - 1/2/2006 3:30:28 AM
sillyness
Status: offline
Just to clarify this, since it is a new idea to some (it was to me)... you balance it with the wings OFF. When you bolt the wings on, the CG will actually shift aft a little, but this is accounted for. It works perfect.
If you think about it, the plane is really well designed!!! If the wings are supporting themselves in flight (they do), and the fuse balances on the wing tube, then the wing tube is carrying all of the fuse's weight in flight... this means that there is little stress on the wing bolts. If the CG was well behind the wing tube, then aft wing bolt would be pulling up and the forward wing bolt pushing down in flight. Kewl, huh?
Don't Sweat the Petty Things, Pet the Sweaty Things.
(in reply to al)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
