Fuelman
NY, USA Status: offline
quote:
Hi all: I have just moved to Cyprus from the US (Indiana) and have just finished up a model and will be running in the engine (ASP .52 2 stroke) this week. The manual (actually a magnum .52 manual) says that for run-in you must use 20% castor and no more than 5% nitro fuel. The trouble is that here in Cyprus, I can not find 20% castor oil. It's very frustrating, and everyone in the USA ought to take a minute and appreciate the very low prices there and the availability of products (I have been doing this since I got here). I have found some Wildcat fuel, but its 5%nitro and 16% oil, of which 80% is synthetic and 20% is castor. Shall I add some castor oil? How much? Any ideas are very much appreciated -- thanks much. The wildcat mix you mention would be fine with a touch of oil added to it as suggested above, if you can find the oil. Even though the instructions state 20% castor oil fuel, I firmly believe that 20% (especially all castor) in a modern engine is not truly needed. If you could find some pharmacy castor oil that would be fine for adding a couple ounces per gallon. Better yet, find a motorcycle or scooter shop (last time I was in Cyprus, I saw several) and pick up some castor or suitable methanol soluble synthetic such as motul micro or something similar as long as it is methanol soluble. If you truly can not find any castor or other lubricants to add to the fuel, do not abandon the hobby, just run and enjoy your engine on the fuel you have with carefull attention to the tune. If you can find suitable lubricants for methanol based fuel, then you may want to start your search for methanol and start making your own fuel there. Please keep us posted on how you are making out. and feel free to e-mail me direct if you have any questions.
_____________________________
Fuelman Cooper Fuels LLC
