STG
WI, USA Status: offline
quote:
ORIGINAL: dynasel My 120AX WILL BE DELIVERED TO ME IN ABOUT A WWK TIME. I AM EAGER TO KNOW WHAT PROP WOULD BE THE BEST TO POWER UP MY SUKHOI SU-26. CURENTLY IT HAS 108FX WITH PROP APC 15X6. AIRPLANE WEIGHT 11-LBS SO I DO NOT GET UNLIMITED CLIMB. HOW ABOUT USING 160-FX WITH THIS APC 17X8 ? I think the Skorepa wood 17x6 will be the prop for the 120ax. Depending on how restrictive the exhaust system is I think it will pull between 9,200 and 9,500 RPM and deliver about 16 pounds of thrust and immediate spool with the light wood prop. My guess is that it will pull a 18x6, but be in the lower 8's and thrust will be about the same. A 17.5x6 would probably be optimum if you could find one. Of course this is only a guess....we will see. ____________ The 160FX will do a good job on your 11pound (to be 11.5pounds with 1.6--cg will go forward). The 17x8 is a good prop, but I think on the SU-26 your best APC prop if you are looking for good unlimited vertical is the 18x6W. You will still have more than enough forward speed with that airframe(big round cowl). ____________________ I have found that the 15x6 is not enough load for the 108. Infact, my .91FX almost pulls the 15x6 as hard as the 108. But when I start to load the motor with bigger props the motor shows its place.... Well today was not a good fly day—too rainy and windy, but I did go out and get some thrust figures. The test was with a F90 with OS 108FSR , Jec pitts muffler, restrictor sleeve removed from the carb and VP30 pump. Fuel used was Cool Power 15%. Temp 51° Humidity 76% and dupoint was 44°. I used a Rapalla fishing scale that calibrates within 1oz at 10 and 15 pounds. Elevation is at about 300 feet. I tried six different props and to my surprise max thrust was very close between them. The props are shown below in the picture and are ordered left to right lowest to highest thrust. My measurements were rmp at 10 pounds (about hovering rpm) of thrust and rmp at max rpm/thrust. Prop RPM at 10 pounds Max RPM& Thrust 15 x6 apc 8,900rpm 10,600 – 13.7 pounds 16 x6 zing not measured 9400- 14.6 pounds 18x8n apc 6,400 8200- 14.9 pounds 16 x5 c zing 7,900 9800- 15.1 pounds 16 x6 apc 7,700 9520- 15.2 pounds 17 x6 apc 7,100 9,200- 15.5 pounds All these peak readings are about a 1.5 pounds better than I expected. Not sure why this is? I am extremely happy with the way the motor runs and transition is outstanding. I made a recording of it at the end when I had the 16 x 6 zinger on. Anyone curious to how fast this 2 stoke transitions please email me and I will send the wave file to you.
< Message edited by STG -- 1/5/2006 2:18:37 PM >
_____________________________
Good Flying to you! See Blog for RCU Video's
