RE: Walkera 22E Lets Talk
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera 22E Lets Talk
Page: <<   < prev  455 456 [457] 458 459 460 461 462 463 464   next >   >>
Login
RE: Walkera 22E Lets Talk - 4/29/2008 10:25:43 PM
phillyD
Status: offline
bro E_HEli
I have the motor heat sink, but I turned it sideways so i could get the battery more forward and it was still tail heavy plenty, even before I extended the tail boom by 1/4 inch, extra from factory set. That 1/4 inch really made a big difference in reducing the work of the tail motor. I had to turn the limit right down, rudder trim 3/4 way to the left and still have to hold a little left rudder. Less work for the tail motor(more life). I'll see how it works above 4ft. Will try the battery swap a little later.
Cheers
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Belt CP Carbon, DX6i, Logictech, 9257 tail servo, HS65MG cyclic servos, Esky CNC 7075 pro tail, King cool CNC 7075 head
(in reply to E_Heli)
       Post #: 11401
RE: Walkera 22E Lets Talk - 4/30/2008 12:17:09 AM
RobBeach
Status: offline
PhillyD.... as far as I am concerned the battery receiver swap
is a done deal. All your balancing problems will go right out the window.
Almost perfect after the swap. With the receiver I use rubber bands
to hold it in and two small t-ties attached together to hold the rear of
the receiver snug, ie: two small ties in place of one 7inch tie to wrap around
the frame and the receiver.
Personally I find popping off the canopy and replacing the battery easier
than the original battery position when in the field. There is still enough
wire on the battery connector to get it out the side of the canopy if you
want to charge the battery still inside the canopy.
Keep the receiver vertically positioned. Try to push it back away from the motor
on the frame.
Also.. maybe I am wrong or it's just temporary... but shouldn't your training gear
be spidered downwards. The main round center joint thusly should be flipped.
Maybe I'm wrong and it's just personal preference. Also... the ties securing the
the struts of the training gear.... I use two ties crossed on each of the four corners.
(in reply to phillyD)
       Post #: 11402
RE: Walkera 22E Lets Talk - 4/30/2008 12:48:34 AM
phillyD
Status: offline
Dear Rob
I'll go flip the training gear connector right away and see the difference. It spiders down when the heil eases the weight. How do you anchor the batt in the nose. It may be a little long to fit without modifying the canopy?
Cheers
Just checked the connector for the training is correct. Cone pointing up with support downward for the rods. if it is spun The rods will go up in the groove. So that one is right
Now to check battery length
(in reply to RobBeach)
       Post #: 11403
RE: Walkera 22E Lets Talk - 4/30/2008 1:37:29 AM
RobBeach
Status: offline
Just rubber bands. Same place the receiver went.
If its it either the 800 or 900 MaH stock battery it will fit no problem
Just for the heck of it in the top of the canopy I drilled a hole
to push air down on the battery in the canopy.
I put electric tape on the canopy where the hole would be
drilled to keep the plastic from shattering (don't really know if
it made a difference.. but it didn't shatter or crack).
I made about a 1/2 inch hole.
My canopy is black where the "glass window" would be... so I figured
it would keep the heat down in the summer sun.
Yours is orange... so it's a cosmetic choice... I haven't heard of anybody else drilling
a hole in the canopy.
I think if your training gear is secured with two ties on each corner,
tightly, it won't sag like it is and the helicopter will sit on the ground
like an agile spider.
       Post #: 11404
RE: Walkera 22E Lets Talk - 4/30/2008 2:51:14 AM
phillyD
Status: offline
Dear Rob
I am ordering a new training gear. I think this was for the helimax. Will try the tie. Oh white reflects sun(raidiant heat) Dark colors absorb. the hole should do. Oh Rob Post a pic to let me see how you run your wires to the servo to avoid the heat from the motor and the main gear.
Cheers
       Post #: 11405
RE: Walkera 22E Lets Talk - 4/30/2008 3:42:16 AM
heliaction
Status: offline
phillyD, nothing wrong with your training gear. If you buy a new set it will only do the same thing. Im basing this on 4 sets that i have seen, they all sat like yours. Mine did and it worked a dream.
Nices paint BTW, make it real easy to see
       Post #: 11406
RE: Walkera 22E Lets Talk - 4/30/2008 4:08:40 AM
RobBeach
Status: offline
Well.. this ain't pretty boys !!!
The training gear... on closer inspection I have just noticed yours is different than mine.
Your center connecting piece is different.
Yours is a flat disk with inserts for the struts.
Mine is shaped like a more like a fat upside down cone... with the holes
for the struts angled up into the unit... thus angling the struts down lifting
the heli off the ground.
Here's a pic... it's not set up to be pretty...
Click for fullsize
< Message edited by RobBeach -- 4/30/2008 4:27:08 AM >
       Post #: 11407
RE: Walkera 22E Lets Talk - 4/30/2008 4:20:07 AM
heliaction
Status: offline
From what i can see Rob it looks like your training gear struts are thicker, maybe off a bigger heli.... Who really cares they all do the same job. ummmm interesting looking heli LOL.
