RE: Walkera 22E Lets Talk
Tower Hobbies
Logged in as Guest
Users viewing this topic: Atzanik
  Printable Version
Align T-REX 450SA ARF
Seller:  Erick Royer
Details:   $150.00   |  6/13/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera 22E Lets Talk
Page: <<   < prev  460 461 [462] 463 464 465 466 467 468 469   next >   >>
Login
RE: Walkera 22E Lets Talk - 5/11/2008 5:15:48 AM
haroman145
Status: offline
Hi...my walkera 22e has been flying fine...then all of the sudden...not so fine...i charge the lipo battery and plug it in then I try to get it to spin up....the rotor spins around a couple times the shuts off along with all servos and everything! i dont know what could be wrong with it...i just bought it like 3 days ago...please help me...
(in reply to consultjdm)
       Post #: 11526
RE: Walkera 22E Lets Talk - 5/11/2008 4:20:02 PM
heliaction
Status: offline
Sounds like the 4 in 1, is the battery swollen like it has air trapped inside the cover? Can you be sure it isn't the battery? I mean before it shuts off are you getting to the point where it will lift off, does it die slowly or suddenly?
(in reply to haroman145)
       Post #: 11527
RE: Walkera 22E Lets Talk - 5/11/2008 5:18:10 PM
haroman145
Status: offline
i think i found the problem....my charger sez to use 15-18 volts dc...i think i lost the adapter and im stuck with 12v and 19v ...i was mistakingly using the 12v...would the 19 volt hurt it?
(in reply to heliaction)
       Post #: 11528
RE: Walkera 22E Lets Talk - 5/11/2008 5:38:39 PM
GTX SlotCar
Status: offline
It might hurt it, or it might not. It could depend on how accurate the 19v label is. Some transformers will actually put out more or less than the voltage on the label. So, if it's putting out 18.5v you're probably all set. If it's putting out 20.5v, it might be risky.
If you don't have a multi-meter to test the voltage, it's something you should invest in. You can get cheap ones for 15 bucks that'll work fine. You can test the transformer outputs, and also the battery to see if it really has a full charge.
Aside from the voltage on the transformer, you need to know the current. It should say something like 19V 1.5A (or 1500ma). My guess is that you'll need at least 1.5 amps to run the charger properly. Having a higher amp rating is fine. But, if it's too low, even though the voltage it right, it won't charge the battery all the way (or at all).
_____________________________
Gary
SuperSkids® www.super-skids.com
       Post #: 11529
RE: Walkera 22E Lets Talk - 5/11/2008 7:10:09 PM
haroman145
Status: offline
haha....i found the right cord...left it in the car...lol i just put it on charge
(in reply to GTX SlotCar)
       Post #: 11530
RE: Walkera 22E Lets Talk - 5/11/2008 7:26:39 PM
Hotrcair
Status: offline
Are you using the charger that came with the Heli?? That is a 120 Volt charger that should be OK. You should also be able to attach it to your car battery or any 12 Volt battery like a car battery. Li-Poly batteries charge to a voltage, they can go bad if overcharged or if they are run down to far. Also overcharging can cause a fire.
       Post #: 11531
RE: Walkera 22E Lets Talk - 5/11/2008 11:31:12 PM
tommis85
Status: offline
GTXSlotcar....I must second all that! Back when I bought my charging station I was hunting around for a suitable transformer at home. I have so many of them lol, from modem transformers to sound system ones and the biggest one which is for the cordless drill. I was surprised to find that all these put out a higher voltage than what it says on the label! For example, the cordless one is rated at 18V and in reality it puts out around 24.5V! In the end I hooked up my car battery charger to my BC6 charging station...it works a treat.
Guys if you ever need a adapter and you have a car battery charger use it lol...it runs at 12V (15V on multimeter) and puts out 2.0amps....a nice round figure for the lipo charging station to play with (and some room for error and adjustment etc). I wouldn't hook it up to your little balancer though lol....only the charging stations!!!
Hmm I think I may have hijacked the thread oops lol!
(in reply to Hotrcair)
       Post #: 11532
RE: Walkera 22E Lets Talk - 5/13/2008 3:47:28 AM
tommis85
Status: offline
Hey all! This thread seems to have died over the last couple days
I got all my spare parts today for my 22E and Belt CP! I'll get straight onto repairs when I get home from work and hopefully I'll be flying in the morning! Time flies: I haven't flown in nearly 3 weeks but I've been on the simulators every night which has really helped my cross-over issues I had with proper flying. How many of you are still try to avoid flying nose-in or am I the only one
Well guys I don't wanna jinx myself now, but, stay tuned for some spectacular crashes (as I try to do some nose ins and side-to-side flights) haha!
Cheers,
Tom
PS - what other materials, apart from aluminium pipe and CF, have you used to extend the 22E's tail boom???
(in reply to tommis85)
       Post #: 11533
RE: Walkera 22E Lets Talk - 5/13/2008 4:02:40 PM
consultjdm
Status: offline
Tommis,
We'll be waiting for your next installment, LOL.
JD
       Post #: 11534
RE: Walkera 22E Lets Talk - 5/13/2008 6:30:11 PM
cenracer1
Status: offline
nothing yet.. maybe I missed that part... how much extention to the boom and what will that accomplish? I know its to make the gyro more stable, but will it prevent the Heli from wandering to the left.. (tail right) I have all but given up solving this issue..
