GTX SlotCar
ME, USA Status: offline
Dodgem, the EF Sabre (like JD has or had), Venom NR2, Exceed Falcon 40 and Twister are all Walkera DF4 clones. The Esky HoneyBee FP is a little different. It has a much better 4in1 and it's compatible with upgraded radios. It also has a 12" tail boom instead of 10 1/2". We all have our opinions. What I like about the FPs is that they're cheap, they don't always break when you crash them, and if they do break, they're fast and cheap to fix and setup again. In the time it takes me to change the feathering shaft and set the blades on my Belt CP, DF36 or HBK2, I can build an entire FP. In our office we have a 12' wide path between the desks and conference table. I can fly circles in that space because they'll fly slow and still be under control. I wouldn't try that with my larger helis or my Blade CP, HB CP2 or 22E. I just think that for learning, you spend more time flying the FP than fixing it so it's less frustrating. At this point, I wouldn't want one as my only heli, but I have a few and still enjoy flying them. Tommis, congratulations. You were so excited in your post that it actually made me feel good. Nice flight map, too, but I hope they don't catch on and start replacing video For me, nose-in wasn't that hard for the left and right part, but it was (and is) for forward/back. Screwy, huh? In some of my videos where I'm hovering nose in, you can see the heli rocking back and forth a little. When I've had enough and feel like I'm getting ready to lose it, I make a turn and go back to tail-in so nobody sees I'm having trouble. Outdoors where there's more room it's easier, but I still have trouble sometimes with forward and back. When it happens, I add throttle and make a turn. If there's enough wind to blow the heli off course, I don't nose in at all (except for circles). I guess I'll get it right some day. Anyway, thanks for sharing the exciting moment.
_____________________________
Gary SuperSkids® www.super-skids.com
