cenracer1 -> RE: Walkera 22E Lets Talk (7/7/2008 2:09:56 PM)
DashC... I have the same head and my links were tight as well.. I kind of worked them around a bit on the balls to loosen them up.. they are better, but still not as loose as the stock plastic ones.. I don't know how tight yours are, too tight will slow the response and possible damage the servos... The disc on top, don't know if it makes any difference, mine was on tight, but had to loctite eveything else on the heli.. I had the same vibration that you were talking about at 1/4 throttle thru liftoff.. don't fly it that way!!!! I found out that while the vibration wasn't too bad to fly, it effected the gyro causing loss of control and thankfully a light crash.. the cause of the vibration turned out to be bad bearings on the mainshaft.. mine were original.. caused a bit of play that you can feel and really comes out when flying.. also the blade grip bearings were crap... don't make the grips too tight to the t-bar holder.. just snug up, feel for binding, back off a bit and loctite in place.. works better than new that way.. lastly, check your main shaft.. It could be bent.. they are made from a soft metal and pretty easily bent.. If you need the main shaft bearings, they are 3x6x2.....
