acebusa -> RE: Walkera 22E Lets Talk (1/18/2006 7:31:00 AM)
evan the stock piece is weak, when I realized mine was broke, I repaired it my self. I have many tools at my disposel, This repair can easliy be done with a drill, and a vise. take off the lock collar, drill a small hole in the aluminum collar about 3/4 of the way down on the inside, than drill at the same offset, and the same size drill bit into the flybar cage. Now what I did, I had a very small drill bit, and one slightly bigger. I drilled the holes like we just talked about, and than cut a piece of the bigger drill bit about 1/4 long, than press it in the lock collar hard. You can do the same thing using a needle, or paper clip, or something like that, just dill the hole slightly smaller than the object you are using. (you must keep the broken plastic piece in the center of the lock collar for it to still fit on your flybar.) than insert the lock collar back on the flybar, and insert new locking pin into the flybar cage. Repeat on other side, and no more breaking of that part.[:D]
