acebusa
KS, USA Status: offline
Well I did some more experimenting with my tail motor problem, and I found the problem to be in the rx, I kept trying to fly it after putting the stock tail motor back on, and when I lifted off, It spun out of control, and crashed. So I deiced I would build a stand to put the heli on that would allow free rotation, Well it worked, and I fired up the heli with my old rx (remember my new one had a bad channel 1 for the servo) It was erratic as usual, So I decided sense I couldn't fly my heli with the new rx, I would try it on the stand and see how the tail motor works, Well It stayed steady for a bit, than it spun all the way around and stopped again, than started being erratic with tail wag, It corrected the peaky problem with the old rx, but I found it odd that it was so spastic, so I disconnected the main motor and fired up the tail at 50%, and gave a little tap on the rx, guess what Same problem as my old rx, If you slightly tap the rx it caused the tail to go crazy, The vibrations from the main rotor head Even though small was enough to cause the new rx to go erratic. I am tired of the cheap electronics from walkera! I am going to search out another option. This is crazy.
_____________________________
Is it fly time yet?
