Ah Clem -> RE: Walkera 22E Lets Talk (1/24/2006 5:40:51 PM)
Ace, I flew (hovered) the Shogun with the Spectrum in it. It was very solid. I am still tuning, so I do not have the pitch/throttle curves anywhere near right, but the radio is solid. I suspect that the S75 servos would be a huge improvement over the stock Walkeras as well. I never got more than 10 feet away from the helicopter, so this was not a valid test. People on the RC Groups forums are raving about the Spectrum so it seems to be doing well so far. I got it because my Optic 6 likes to just stop working after about 10-15 minutes or so. I dorked my Shogun a couple of times when I was attempting to isolate the problem. The last time, I flew the pack out, landed, and as I was carrying the helicopter back to the pits the radio died. The TX is now relegated to simulator duty! The Spectrum does support CCPM, so you will be fine there. You will need a separate gyro and two ESC's, one for the main motor and one for the tail. Somewhere I think I have bookmarked a website with instructions for hooking up "separates", but I have not tried this. I just finished flight number 27 on the VNR3D. I have had, in all these flights, only one glitch (which may have been my thumbs). The radio is very solid. I have been flying up and around, so it is not just at "hover distance". I do have the antenna routed through a rubber grommeted hole in the lower front of the canopy, through a plastic tube tie-wrapped to the landing gear struts, and taped to the tail fine at the back. I have never cared for the way most of the factories wrap the antenna around the landing gear struts. Again, the Radio and 4-in-1 on the Venom, look just like Walkera, but they work well. I cannot swear that they are identical and will work together, but I would bet on it. I do not want to lead you astray here (i.e. spend your hard earned money for you). Venom does state that their radio is proprietary and will not work with other brands, but this is another similarity to the Walkera. On the RC groups forums, people are complaining about set screws not being tight, the seesaw and flybar control tray (flybar cage) breaking, but I do not think anyone has mentioned a radio glitch.
