bfrunner
Joined: 10/24/2003 From: Mooresville, NC, USA Status: offline
quote:
ORIGINAL: micropotato Fisrt of all, let's clarify the model you have, the NO.5 has 2 models, the older one and the newer one called No.5 ver4 which has a open top compartment for the gyro & motors, vise versa the old one has a closed one, means you can't see the electronics from outside, but they are all at the same size. see my first 3 attached pictures. There are 5 versions of the #5: #5, #5, #5-2, #5-3, #5-3 Apache gunship, #5-4 The #5, and 5-2 were basically the same except for the canopy, and transmitter. The 5-2/Housefly added the Lama style canopy, the now familiar Walkera 4ch TX, and the later on a carbon fiber outer shaft replaced the steel outer shaft. The 5-3 was a complete redesign with real servos, and a swash plate, much better than the previous versions. The 5-3 Apache Gunship is essetially a step back to the old #5-2/Housefly platform with a full Apache Gunship body in Desert Camo. The 5-4 another redesign of the #5 which closely matches the Esky Lama2 is even better than the old 5-3.
