RE: What I've learned about life by building a Carden
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: What I've learned about life by building a Carden
Page: <<   < prev  1 [2]
Login
RE: What I've learned about life by building a Carden - 1/21/2006 7:36:01 PM
OnTheEdge
Status: offline
quote:
ORIGINAL: budgetdude
Do you have to vac bag or can you just put alot of weight on the cores?
Weight is just fine. Most guys probably do the weights as apposed to the vac bagging. Just make sure the surface you lay up the foam pieces is perfectly flat! Also, make sure the surface remains perfectly flat as you put on all the weight (Some guys will set 400 lbs on the wings).
_____________________________
Avoid zen aerobatics...when the ground........and the plane.......become as one.
(in reply to budgetdude)
       Post #: 26
RE: What I've learned about life by building a Carden - 3/28/2006 7:08:08 PM
MarkShapiro
Status: offline
Also very important to remember that the weight be dispersed evenly. I use a piece of particle board to put on top of the wing chucks and then put on cement blocks evenly over the entire top of the board. DO NOT put weights directly on the foam chucks or you will assure yourself of a warped wing/tail/rudder. Don't ask how I know this.
(in reply to OnTheEdge)
       Post #: 27
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.172RCU1
