RCV 1.20 for my Mustang
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> RCV 1.20 for my Mustang
Page: [1]
Login
RCV 1.20 for my Mustang - 11/20/2002 6:02:48 AM
FalconWings10
Status: offline
I'm planning on using a RCV 1.20 engine on my TF P-51 so that I can swing a scale size prop. My plane is going to way out @ 12 lbs. Will this engine fly the model in a scale manner? : I'm not crazy about (unscale) speed.
       Post #: 1
P-51 scale speed - 11/20/2002 7:19:30 AM
Otto Kudrna
Status: offline
I think that a 120 with a Zinger 18x14 or 20x12 or 18x16 will give you what you are looking for and than some. you will probably be flying at 3/4 throttle or less most of the time if you want to fly scale. I was flying a 74' Corsair art about 9+ Pounds with a RCV 60SP it flew very scale, considering that the gear was hanging out at all times.
Otto
(in reply to FalconWings10)
       Post #: 2
RCV 1.20 for my Mustang - 11/20/2002 7:26:10 AM
FalconWings10
Status: offline
Thanks! I think that I go with the 20x12 so that it gives me a more scale look in the air. This engine runs wonderfully (and strong). I'm not afraid to swing this size.
       Post #: 3
RCV 1.20 for my Mustang - 11/20/2002 5:04:34 PM
rc34074
Status: online
you should check your ground clearance with the prop you are thinking of using.
_____________________________
"there are fighters and there are targets"
       Post #: 4
20x12 on Mustang - 11/20/2002 6:07:51 PM
Otto Kudrna
Status: offline
Hello
You may have to try more than one size to get the performance you are looking for. Just remember this, What ever prop you use load the engine down to about 4400-4800 rpm Maximum, And For heavens sake use the right fuel. Do not over lubricate the engine.
Otto Kudrna, RCV Tech Support Americas
       Post #: 5
Over Lubrication? - 11/20/2002 7:23:32 PM
FalconWings10
Status: offline
What do you mean by over lubrication? I've never had that problem before? Is there sometime that I don't know about this engine?
       Post #: 6
Overlubrication - 11/23/2002 5:40:36 PM
Otto Kudrna
Status: offline
If you read threw this section, specially the part called, Fuel is not fuel is not fuel. You will find that these engines like fuel that contains LESS THAN 16% oil I prefer 14% (always caster, Synthetic blend ) You can over compress these engines with too much oil. Resulting in loss of power and vibration.
Thank You
Otto
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
