consultjdm
CA, USA Status: offline
Guildgtar, I agree with Nitro, get that tail under control, That may not mean perfect but close to perfect. Although, I have had heli's that have a lot of ground spin and as soon as u lift up an inch it stops. but until you lift up an inch, you have to hold the stick way over to the left. Then you can release it to center as soon as you lift up an inch. But if it is not holding once you lift; land. I crash every time, almost, when my tail goes out of control and I'm up a couple feet. A few inches and I can get it back down without damage. Best of Luck JD
