RE: Night Ranger 3D Gallery
Tower Hobbies
Logged in as Guest
  Printable Version
Miniature Aircraft USA Ion-X - RTF
Seller:  1surfer
Details:   $5,000.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Night Ranger 3D Gallery
Page: <<   < prev  33 34 35 [36] 37 38 39 40 41 42   next >   >>
Login
RE: Night Ranger 3D Ga... - 3/20/2006 4:36:08 PM
consultjdm
Status: offline
Dennis,
That's why I have so many.
Looking for the ones that break the least.
Going parts store today.
oh well.
JD
(in reply to freeonthree)
       Post #: 876
RE: Night Ranger 3D Ga... - 3/20/2006 4:38:57 PM
consultjdm
Status: offline
Dennis, I am burning main motors.
and Tail motors.
your lucky just tail motors.
Oh, I took my tail motor apart and fixed it. What has it come to? the damn little brushes needed to be push back toward the rotor..
JD
       Post #: 877
RE: Night Ranger 3D G... - 3/20/2006 7:43:07 PM
Nitrofever3D
Status: offline
Hey use some 3-1 oil or bearing oil on your main motor and tail just put a drop or two in front of the brass bushing and the back and work it in by spooling the motor up just one click and the tail just one drop on the fron of the shaft by the case and work it in. U will notice a big diference and lube your bearing on your tail 2 by diping them in oil for like 20min and i used grease for the main shaft bearings i havent had a problem with my main motor in a while now since that squealing last time and it was a dry bushing i havent replaced it yet!! nock on wood
_____________________________
Gabe.
(in reply to consultjdm)
       Post #: 878
RE: Night Ranger 3D G... - 3/20/2006 8:31:16 PM
consultjdm
Status: offline
Nitro,
I have read about people running their motors under water to break them in. Doesn't that short them out?
It sounds like your dunking your motors in oil.
My real question is, does that mean I can get oil anywhere on the wires and inside the motor and anywhere and it won't hurt the motors? Does that go for the brushless motors also?
JD
(in reply to Nitrofever3D)
       Post #: 879
RE: Night Ranger 3D G... - 3/20/2006 9:18:37 PM
freeonthree
Status: offline
I have been oiling my motors and main shaft, and I think it's a must do also...
I dont crash, I just land hard
       Post #: 880
RE: Night Ranger 3D G... - 3/20/2006 9:56:20 PM
consultjdm
Status: offline
Dennis,
The tail motor only has the shaft next to the gear right,
And the main - do you squirt oil in through the holes on the sides?
       Post #: 881
RE: Night Ranger 3D G... - 3/20/2006 10:03:51 PM
freeonthree
Status: offline
Put a 1/4 drop of oil at the shaft at each end of the main motor, and turn the main gear to let the oil get into the bushings. Also hold the heli sideways, and let a tiny bit of oil run down the shaft and into the bushing of the tail motor (below the gear). The rear bushing of the tail motor is sealed, so you can lube that end. Be careful not to use too much oil, you don't want it to get on the brushes or anywhere but in the bushing on the end.
       Post #: 882
RE: Night Ranger 3D G... - 3/20/2006 10:13:35 PM
consultjdm
Status: offline
Dennis, okay
       Post #: 883
RE: Night Ranger 3D G... - 3/20/2006 10:21:12 PM
freeonthree
Status: offline
No prob JD. Oil is a good thing. I forgot to mention, occasionally put a drop of light oil under the top mainshaft collar and let it run down into the bearing housing, I also put a drop of oil in the center bushing of the swashplate too... I may not be a good pilot yet, but at least I crash a well lubricated heli. hahahahaha I'll be flying the VNR3D for a couple of weeks while I wait for the new 4 in 1 to get here, so when the BCP gets back up, im sure it will put me to sleep. Don't forget to let your friends know about our group. http://groups.yahoo.com/group/venomnightranger3dgroup/
       Post #: 884
RE: Night Ranger 3D G... - 3/21/2006 5:03:01 AM
consultjdm
Status: offline
Dennis,
I think the battery I have has too high a C burst. I think it is 20C.
I ordered the brushless motor. and a 30amp esc.
Lets see if I stop burning motors.
But my new one is all lubed up so Im ready. I think all my heli's are running.
Well I have two I havent fired up yet (a brushed showgun I built Sunday, and my logo 10). My Brushless showgun has a new motor in it but not run yet. The walkera 22E is chargeing, my NR3D is ready, my helimax is ready and my sabre is charging. And its raining.
I Still need to build my new TREX. I need to try out my heli camera and I have two new helicopters (a brushed and non brushed #60 walkera's) showing up by next Monday or sooner.
I'll be flying a little more tonight in the living room. But I am ready.
JD
       Post #: 885
RE: Night Ranger 3D G... - 3/21/2006 5:22:26 AM
freeonthree
Status: offline
Im gunna do that right now too. Lacey had me oil my tail rotor bearings and loosen the axel so it would wiggle a little, and my tail problems seem to have gone away !!! Im going to give it a good test right now. Im talkin bout my Blade CP !!! Very cool !!! Sounds like ya got the whole fleet comin together !!! Time to open a small RC Airline... LOL Back with a report soon. Meet me on the group...
       Post #: 886
RE: Night Ranger 3D G... - 3/21/2006 5:50:35 AM
freeonthree
Status: offline
I thought it was fixed, but it still swings the tail intermittantly. I'll send in the 4 in 1... Oh well, I tried... LOL
       Post #: 887
RE: Night Ranger 3D G... - 3/21/2006 3:41:18 PM
Guildgtar
Status: offline
i called venom about the 4-1 and they said to eye it out to 12:00 for both. So i did that n with alittle tiny adjustments after that it cleaned up.
       Post #: 888
RE: Night Ranger 3D G... - 3/21/2006 3:58:27 PM
consultjdm
Status: offline
Dennis,
All you can do is keep figiting until you find what works.
But I believe to some extent that there are electronics and motor that just last longer. The luck of the draw. But of course the oil and loosening of the parts should help even a bad motor.
I oiled every ball bearing adn moving part while I had the oil can in my hand. What the heck
See ya,
JD
