RE: Night Ranger 3D Gallery
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Night Ranger 3D Gallery
Page: <<   < prev  33 34 35 36 37 38 [39] 40 41 42   next >   >>
Login
RE: Night Ranger 3D G... - 3/23/2006 4:26:33 PM
consultjdm
Status: offline
MCRC shrike,
You need to rename it now! LOL
So many modifications it's a new model.
JD
(in reply to mcrcshrike)
       Post #: 951
RE: Night Ranger 3D ... - 3/23/2006 10:46:21 PM
Guildgtar
Status: offline
how do u all set ur head block? im kidna haveing trouble settin mine so i can get up high off the ground.
(in reply to consultjdm)
       Post #: 952
RE: Night Ranger 3D ... - 3/23/2006 11:15:10 PM
consultjdm
Status: offline
Guildgtar,
I just have it up near the head as high as possible I think.
but the real issue is the blade pitch maybe.
Dennis could tell you cause he has his with him, but when i am home tonight and if you are still having a problem I will check mine and let you know since mine is working fine.
JD
(in reply to Guildgtar)
       Post #: 953
RE: Night Ranger 3D ... - 3/23/2006 11:54:10 PM
Guildgtar
Status: offline
ok thanks ill just wait for u. like where do u have ur head block when it is at half throttle.
       Post #: 954
RE: Night Ranger 3D ... - 3/24/2006 5:12:42 AM
consultjdm
Status: offline
guildgtar
My head block is between an 1/8 and a 1/16. barely moves from zero to half. Almost touching the head when at full throttle.
My Walkera is slightly lower than my VNR3D, they are the same heli with different names.
The venom is at 1/16 at off touching at full throttle.
The walker is at 1/8 at off maybe 1/32 or 1/16 at full throttle.
So they are pretty high. The VNR3D has more lift I think. And both seem to have more lift in 3D mode.
       Post #: 955
RE: Night Ranger 3D ... - 3/24/2006 7:34:24 AM
freeonthree
Status: offline
My head block is tightened down at the top of the flat spot as Venom suggested, and it works great. When the PIT/PZT knob is at 12:00, the blades are at zero pitch. Also, I now run my knobs at PLT=2PM and PIT/PZT=10pm, but tomorrow im gunna give 12 and 12 a try. I still have no idea why it wouldn't take off before. Must be the Heli Gremlins...
_____________________________
I dont crash, I just land hard
       Post #: 956
RE: Night Ranger 3D ... - 3/24/2006 7:18:00 PM
Guildgtar
Status: offline
omg..hahaha, well i was just going to ask u guys if the Blade CP motor will fit in the venom Nr3d cause mine just died on me. or is there another motor that i can look for maybe. But now other then that, my G/f just sat on my antenna and bent it in half. SO!!! lol, i haft to either find a antenna or something....
< Message edited by Guildgtar -- 3/24/2006 7:19:30 PM >
(in reply to freeonthree)
       Post #: 957
RE: Night Ranger 3D ... - 3/24/2006 8:59:26 PM
consultjdm
Status: offline
Guildgtar,
Girlfriend sat on antenna!
I think that is grounds for divorce in most Heli forums!
JD
       Post #: 958
RE: Night Ranger 3D ... - 3/25/2006 12:35:18 AM
krisma
Status: offline
quote:
ORIGINAL: consultjdm
Dennis,
Glueing nipples does not sound safe. I just srew in the LOSI balls when I break them.
JD
RCEXPERT in Hong Kong has already responded but they could not understand, language barrier.
Trying again with pictures.
What are theez losi ballz you speekz ofv??
they sound kewl for a replacement?
       Post #: 959
RE: Night Ranger 3D ... - 3/25/2006 12:54:05 AM
Guildgtar
Status: offline
So does anyone kno if the Blade Cp motor will fit the NR3d or if there at least the same size. They sell a high performance Blade Cp motor cheaper then the regular Night ranger 3d motor. I dont kno if theres a difference.
(in reply to krisma)
       Post #: 960
RE: Night Ranger 3D ... - 3/25/2006 1:51:50 AM
consultjdm
Status: offline
Krisma,
Part #LOSB1051.
Replacement balls that come with their oown screw, one piece.
When a little ball connector breaks off we drill a whole and screw in the LOSB so we don't have to buy a new part. They are a tad smaller and some of us cut the ball ends off the bladed holders/grips and then drill them and put in the LOSB balls. They disconnect a little easier so when you crash you don't break the blade grip
JD
       Post #: 961
RE: Night Ranger 3D ... - 3/25/2006 1:54:25 AM
consultjdm
Status: offline
Guildgtar
you would probably have to check the pinion gear. if it is a 370 size motor it will fit, but the gearing may be different.
JD
       Post #: 962
RE: Night Ranger 3D ... - 3/25/2006 2:01:04 AM
freeonthree
Status: offline
I tried to test fly my VNR3D a while ago, the speed control went full throttle, and it was completely totaled !!! I salvaged what screws and things I could, but there wasn't much left.
       Post #: 963
RE: Night Ranger 3D ... - 3/25/2006 3:35:23 AM
krisma
Status: offline
J D
Thanks for the heads up on those ball connector replacements... kewlness
i'm new to the rc hobby world so all of this is new to me.
       Post #: 964
RE: Night Ranger 3D ... - 3/25/2006 4:30:22 AM
