consultjdm
CA, USA Status: offline
Guildgtar, set both knobs to 12:00 (straight up) Switch dip switch 8 to the left, unlock. put the throttle to mid stick or just befor lift off. Should be either mid or just below mid stick Then try moving the right knob to the left till you hear the head speed increse, you shouild see the heli start to lift up if not stop when your at 11:00. Then move the right knob to the left. now you should see the heli start to lift. Stop there and try flying it. see if you get good lift. maybe end up around 11:00 on the left and 1:00 on the right knob. You can play with it for fun, turn the left knob all the way to the left and you should see the blades go to negative pitch, the heli presses down on the ground, easy to see with training gear on. Turn to the right and you get positive pitch and the heli lifts up. Go to far to the right on the right knob and you get to much pitch for the head speed and you actually lose lift. So try to maintian good head speed and a little positive pitch. I hope that helps. JD
