RE: Yet Another Yak!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aerotech R/C Models Support >> RE: Yet Another Yak!
Page: <<   < prev  1 2 3 4 [5] 6 7 8   next >   >>
Login
RE: Yet Another Yak! - 4/3/2006 4:40:26 AM
pcastine
Status: offline
Cool looking anti-rotation plate...too bad it will be painted over.
Click to see fullsize image.
Click for fullsize
(in reply to pcastine)
       Post #: 101
RE: Yet Another Yak! - 4/7/2006 5:42:08 AM
pcastine
Status: offline
More work...lightening holes in the gear plate (2 oz out of the plane). Gear was bolted in with 8-32 bolts. Glued on foam formers to complete fuse.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 102
RE: Yet Another Yak! - 4/7/2006 5:44:17 AM
pcastine
Status: offline
Started on the cowl. This cowl is a monster! Mine weighed over 2 lbs!!!
I notched the cowl ring where the two cowl pieces overlap in order to keep a smooth seam on the outside. Cowl ring is bolted to the fuse with 6-32 bolts.
Click for fullsize
Click for fullsize
< Message edited by pcastine -- 4/7/2006 5:48:20 AM >
       Post #: 103
RE: Yet Another Yak! - 4/7/2006 5:46:43 AM
pcastine
Status: offline
Also started the hatch. Installed the LE of the foam former, and put in balsa/plywood blocks to hold the retaining pins. The hatch will be bolted down with four bolts through the fuse sides into blind nuts in the hatch bottom. Will probably remove some wood from the hatch bottom to save weight.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 104
RE: Yet Another Yak! - 4/7/2006 11:55:34 PM
OnTheEdge
Status: offline
Looking good Pete! How do you get the cowl off? I assume a very long ball driver or do the cap heads remove from the hatch side?
.........Mark
< Message edited by OnTheEdge -- 4/7/2006 11:56:53 PM >
_____________________________
Avoid zen aerobatics...when the ground........and the plane.......become as one.
       Post #: 105
RE: Yet Another Yak! - 4/8/2006 5:01:38 AM
pcastine
Status: offline
The screws come out the cowl side, not the hatch. But there's plenty of room to reach in and pull them out. I've had the cowl off a hundred times already, sanding the ends in order to get it to line up with the fuse. Right now it's only screwed in place temporarily with small servo screws. Once I get the alignment right, I'll glue it in place and fill the holes.
(in reply to OnTheEdge)
       Post #: 106
RE: Yet Another Yak! - 4/14/2006 2:06:09 AM
jmiracle
Status: offline
My Yak build has completed another milestone......the covering is complete!
I'm working on filling all the pinholes/weave of the cowl now so I can prep the hatch/cowl/pants for paint.
I'm hoping to have this finished by early May......but we'll see.
Click for fullsize
Click for fullsize
       Post #: 107
RE: Yet Another Yak! - 4/14/2006 1:19:08 PM
40%plane
Status: offline
Looking good, you will love this yak once it flies. I was surprised with mine on the first landing because I keeped thinking it would fall out of the air, but it flies so slow I quickly got over that and went into the mode of man this thing flies real slow.
If it has a motor a radio and fuel I will fly it!!!!
Aerotech R/C Models Sponsored pilot
(in reply to jmiracle)
       Post #: 108
RE: Yet Another Yak! - 4/26/2006 2:34:09 AM
pcastine
Status: offline
Haven't had much time to work on the plane, much less update the thread. But, I have gotten some stuff done.
Click for fullsize
Click for fullsize
(in reply to 40%plane)
       Post #: 109
RE: Yet Another Yak! - 4/26/2006 2:37:15 AM
pcastine
Status: offline
I'm going to use Composite-ARF phenolic horns for the control horns. So I'm sinking a balsa block into each elevator to glue the horns into.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 110
RE: Yet Another Yak! - 4/26/2006 2:38:43 AM
pcastine
Status: offline
Motor & cowl is on. Just waiting for new headers to mount the tuned pipes.
Click for fullsize
Click for fullsize
       Post #: 111
RE: Yet Another Yak! - 5/20/2006 5:07:54 AM
pcastine
Status: offline
Bet you though this thread was dead!
Pipes are in, and now belly pan is drying.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 112
RE: Yet Another Yak! - 5/20/2006 12:40:53 PM
whaturi
Status: offline
nice pete. are you going to take off over the fence with this one?
       Post #: 113
RE: Yet Another Yak! - 5/25/2006 3:30:06 AM
vatechguy3
Status: offline
on a scale of 1-10, just how hard would you guys say building one of these yak kits is??
thanks
tony
(in reply to whaturi)
       Post #: 114
RE: Yet Another Yak! - 5/25/2006 3:56:53 AM
