RE: Yet Another Yak!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aerotech R/C Models Support >> RE: Yet Another Yak!
Page: <<   < prev  1 2 3 4 5 6 7 [8]
Login
RE: Yet Another Yak! - 12/11/2006 3:29:16 AM
pcastine
Status: offline
Thanks Mike! And thanks for helping me out with the final checks and getting the plane in the air.
FLIGHT REPORT: I was very surprised that despite looking like a lumbering plane, this one handles very well. Took off after range check, and the plane needed only a little up elevator trim for straight & level; no aileron or rudder required. I think the extra servos were worth it; the plane feels very locked in. Snaps had no over-rotation, and rolls were generally axially. Looking at the ailerons, it seems like the left (aux3) is not tracking exactly with AIL, so I'll have to look into that a little. Very little effect on flight.
The plane balanced perfectly; no down elevator required in inverted flight. This is actually a little too tail heavy for me mostly, as I prefer pattern (IMAC) over 3D, and usually snaps are a little more locked in (for me at least) when the plane is a little nose heavy. The motor has a little too much right thrust (I used the SWB 3 degree mount, probably 2.5 is fine); left rudder is required on the way up.
The plane tracked well, point rolls required almost no rudder. The rudder, btw, is very strong. I did a knife edge loop on low rates with confidence. (Now I get to turn down the rudder more!) There was a little pitch coupling with the rudder, but much less than my Comp-ARF Extra. I'm guessing about 3-4% mix ought to cure it. The elevators, oddly, were not very effective at low deflection until you really moved them off center. I need to take some expo out of my radio; speeding up the elevators off center should help. On 3D rates they performed fine.
Uplines are not a problem (except for the left rudder). Power is very good with the DA-150 & K&S tuned pipes. If you see Mike's video, its kind of hard to judge, but the uplines were very authoritative, with rolls & a snap on the way up not being a problem. Unfortunately, the motor quit about 6 minutes into the flight, and I had to dead stick it. The final was down wind (never good) and the plane came in very hot, which was surprising; I thought it would slow down better. It ran off the end of the runway, but no damage. Turns out the diaphragm on the carb was leaking. This DA has been in storage for over a year, the diaphragm must have dried out.
So, looks like I get to wait until next weekend to start trimming out the plane, after my carb rebuild kit arrives.
But for now, some more photos...
Pete
(in reply to airriley)
       Post #: 176
RE: Yet Another Yak! - 12/11/2006 3:31:04 AM
pcastine
Status: offline
The plane before the first flight....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by pcastine -- 12/11/2006 3:32:45 AM >
(in reply to pcastine)
       Post #: 177
RE: Yet Another Yak! - 12/11/2006 3:34:53 AM
pcastine
Status: offline
I plan to order a 6" Pete's Model CF spinner. I wanted to wait until I knew roughly what the CG would be before choosing a spinner. If I really had needed the nose weight (which thankfully I don't) then I would go with a Tru-Turn.
Click for fullsize
Click for fullsize
       Post #: 178
RE: Yet Another Yak! - 12/11/2006 3:36:24 AM
pcastine
Status: offline
Some pics of the setup...(since I had to take the cowl off anyway to work on the motor ).
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 179
RE: Yet Another Yak! - 12/11/2006 3:38:18 AM
pcastine
Status: offline
The joy of model planes! (90% maintenance, 10% fun)
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 180
RE: Yet Another Yak! - 12/11/2006 4:13:55 AM
Leardriver
Status: offline
Hey Pete,
Congrats on the maiden flight! Looked good from the video! Long time coming..I'm sure it was very nice to see it fly. Good luck with new ride!
PaulP
       Post #: 181
RE: Yet Another Yak! - 12/11/2006 3:19:03 PM
OnTheEdge
Status: offline
Congrats Pete! Looks great. Looks like you have a lot nicer flying temps this time of the year down there (no jacket) . From the video, the rolls looks very axial. Waterfalls look tight too.
Was your final weight as flown, or did you factor in the paint and spinner? Glad you got the motor issue figured out so quick. Nice job on the dead stick. That barn looks, rather challenging .
Best of luck with the new plane.
.........Mark
_____________________________
Avoid zen aerobatics...when the ground........and the plane.......become as one.
(in reply to Leardriver)
       Post #: 182
RE: Yet Another Yak! - 12/11/2006 10:45:21 PM
pcastine
Status: offline
Mark,
The weight was as flown; without cowl paint & spinner. I just order a Mejzlik 6" Bullet CF spinner from DA today (along with a carb rebuild kit). I'm guessing with the paint & spinner the plane will be just about 44 lbs (dry).
Yeah, the weather has been pretty good - 60 on Sunday and 64 today (work sucks!!!!) I'm sure it will cool right down again the day after my carb is fixed.
The runway is very fun - you get to make your final approach between a barn and a huge tree (about 30 feet wide) or over a huge line of trees. I prefer the barn.
Pete
(in reply to OnTheEdge)
       Post #: 183
RE: Yet Another Yak! - 12/12/2006 3:36:13 AM
DMichael
Status: offline
Pete,
I haven't checked the vid yet but the plane looks good. Can't wait to see it fly in person.
Get some baffling in there.
Dave
Team ZDZ
www.rcshowcase.com
       Post #: 184
RE: Yet Another Yak! - 12/12/2006 3:42:44 AM
DMichael
Status: offline
OK, I just watched the vid:
"....when that engine cut out. That wasn't me"
"It's definitely the servo."
That approach is wicked....
Team ZDZ
www.rcshowcase.com
(in reply to DMichael)
       Post #: 185
RE: Yet Another Yak! - 12/12/2006 4:32:57 AM
pcastine
Status: offline
I don't know if I was getting a radio glitch (failsafe is set to hold every surface but bring throttle back to idle) or if it was due to the diaphragm leaking. Sure sounded like a radio glitch, but I got an excellent range check.
Yeah, it's a lot of fun flying between the barn and the trees, come on down and give it a try....you like trees just as much as I do, don't you Dave?
       Post #: 186
RE: Yet Another Yak! - 12/12/2006 4:36:03 AM
OnTheEdge
Status: offline
quote:
ORIGINAL: pcastine
Sounds like a good place to hold an Imac contest.
       Post #: 187
RE: Yet Another Yak! - 12/12/2006 10:56:49 AM
vatechguy3
Status: offline
nice looking plane pete.
any plans to baffle the cowl??
tony
       Post #: 188
RE: Yet Another Yak! - 12/12/2006 10:26:58 PM
