RE: Norvel Engine FAQ    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Norvel Engine FAQ Page: <<   < prev  12 13 [14] 15 16 17 18 19 20 21   next >   >>
Login
RE: Norvel Engine FAQ - 9/9/2008 3:33 AM
Entropy
Score: 100
Last Login: 3/26/2013
Status: offline
Is there Galbreath/Nelson head/plug combo for the Norvel .074? Or what do you guys recommend?
Hide Signatures
(in reply to AndyW)
       Post #: 326
RE: Norvel Engine FAQ - 9/9/2008 4:44 AM
Andrew
Score: 105
Last Login: 5/22/2013
Status: offline
The Galbreath/NELSON is available for the COX .049, NORVEL .049 and NORVEL .061. There is not a corresponding Galbreath head for the .074 .
Your options are an adapter button for long standard plugs from MECOA or the Turbo Plug adapter from COX_HYPER_SPEED on thebay. The turboplug generally gives better performance than an adapter head with the standard plugs.
However, the MECOA button is currently listed for 3.99 - add to that a standard plug for $5.00 to $6.00, and you're out less than 10 bucks. The turboplug adapter for the .074 from thebay is $17.95 (free shipping) plus an OS turboplug for $10 and you're out nearly $30.
Sooo, is improved performance worth an additional $20 for your applications? That's a question you'll have to answer for yourself.
< Message edited by Andrew -- 9/9/2008 4:45 AM >
_____________________________
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
(in reply to Entropy)
       Post #: 327
RE: Norvel Engine FAQ - 9/9/2008 6:28 PM
Entropy
Score: 100
Status: offline
Thanks Andrew. Another question: For the .061 Galbreath head; which Nelson plug is better? The HD or the Hot? What are the different running characteristics?
Also will the Nelson plugs work in the COX_HYPER_SPEED turbo head for the .074? (By the way didn't see one listed on thebay, just: .15, .049 / .051, .09)
< Message edited by Entropy -- 9/9/2008 6:32 PM >
Hide Signatures
(in reply to Andrew)
       Post #: 328
RE: Norvel Engine FAQ - 9/9/2008 9:57 PM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: Entropy
I have not run the NELSON hot plug, but the primary difference between the two is the element composition and element hole size - the hot plug has a larger element hole. Because of the small displacement of 1/2A engines, any plug that can help maintain the compression ratio should probably be used. For that reason alone, I use the HD.
The NELSON plug cannot be used with Valentine's turbo head. NELSON plug threads are 11/32" x 32.
EDIT: See following post for turbo thread size.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Andrew -- 9/10/2008 3:03 AM >
the "other" andrew
Hide Signatures
       Post #: 329
RE: Norvel Engine FAQ - 9/10/2008 2:08 AM
SGC
Score: 100
Status: offline
Turbo plugs are M8 X 0.75 not 1/4"32
Stewart
Hide Signatures
       Post #: 330
RE: Norvel Engine FAQ - 9/10/2008 3:20 AM
Entropy
Score: 100
Status: offline
Well I bought some of each on the Nelson plugs for the .061 so maybe I can test the two and report back on any differences. The Hot plug was advertised as: " If you are running a 1/2A engine with a throttle you may want to try this plug for better throttling."
For the .074 I went with the Jon Valentine Turbo head and will be getting some "O.S. P3 Turbo Glow Plug Super Hot" for it.
Hmmm...maybe I should've got some cold or medium glow plugs since I'll be running Sig 25% fuel. Should've researched this before I ordered them.
< Message edited by Entropy -- 9/10/2008 4:00 AM >
Hide Signatures
(in reply to SGC)
       Post #: 331
RE: Norvel Engine FAQ - 9/10/2008 6:58 AM
PlaneKrazee
Score: 205
Last Login: 6/21/2012
Status: offline
What would be the best temp plug for 5% nitro use?
a never-ending battle for truth, justice and the American way
Hide Signatures
       Post #: 332
RE: Norvel Engine FAQ - 9/10/2008 7:22 AM
Andrew
Score: 105
Status: offline
Some recommendations from OS.
Plug descriptions from OS.
the "other" andrew
Hide Signatures
(in reply to PlaneKrazee)
       Post #: 333
RE: Norvel Engine FAQ - 9/10/2008 9:18 PM
PlaneKrazee
Score: 205
Status: offline
Looks like a P3 would be the best for small engines and low nitro followed by the P6.
I'll purchase a P3 and compare it to a stock plug.
< Message edited by PlaneKrazee -- 9/10/2008 9:22 PM >
Hide Signatures
       Post #: 334
RE: Norvel Engine FAQ - 9/12/2008 7:32 PM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
OK, anybody know where to get a piston hard anodized? I have an OS .25 FP piston and liner that are worn to the point of having poor compression but the plating is still intact. And how would I retain the wrist pin hole dimensions? OK it ain't Norvel but the technology is still the thing.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to AndyW)
       Post #: 335
RE: Norvel Engine FAQ - 9/16/2008 1:56 AM
Entropy
Score: 100
Status: offline
I have the break in instructions for the .061 Revlite engine I have. Are these the best to follow or or there any tips/tricks I should know? Also I have a pre-Revlite engine and I don't have any instructions on breaking it in. Can anyone help here?
Hide Signatures
(in reply to jeffie8696)
       Post #: 336
RE: Norvel Engine FAQ - 9/17/2008 2:06 AM
redbird340
Score: 100
Last Login: 3/14/2009
Status: offline
Entropy, pm me your email address and i will forward you a bunch of articles that i copied off the old Norvel webpage. They all tackle a range of problems, from breaking-in to fine tuning. I also recorded the engines sounds in mp3 format as well, which may also be of assistance.
Regarding the non-revelite engine, if the break-in instructions are different than the revelite, i will scan the instruction sheet for you.
Hide Signatures
       Post #: 337
RE: Norvel Engine FAQ - 9/17/2008 3:10 AM
Andrew
Score: 105
Status: offline
redbird340
Since the original links to these articles are now broken, if you have them in an easily postable format, please go ahead and list them here on the forum.
the "other" andrew
Hide Signatures
(in reply to redbird340)
       Post #: 338
RE: Norvel Engine FAQ - 9/17/2008 3:20 AM
Entropy
Score: 100
Status: offline
Thank you redbird340. I PM'd you. If you can, try to respond ASAP. Tomorrow is my day off and I plan on having a Norvel Breakin' In Party!
Hide Signatures
       Post #: 339
RE: Norvel Engine FAQ - 9/17/2008 5:01 AM
redbird340
Score: 100
Status: offline
quote:
ORIGINAL: Andrew
redbird340
Andrew,
I will have all articles posted within the next few days; i just need some time to organise them, so that access is as convenient as possible. All are stored in MS word, but i don't know if .doc is supported here. I will try a test message right now.
Hide Signatures
       Post #: 340
RE: Norvel Engine FAQ - 9/17/2008 5:08 AM
redbird340
Score: 100
Status: offline
Unfortunately, .doc or .mp3 is not supported here, so i will copy and paste all the articles over the next few days. The engine sounds will need to be hosted on some other website, though.
Hide Signatures
       Post #: 341
RE: Norvel Engine FAQ - 9/17/2008 8:06 AM
redbird340
Score: 100
Status: offline
NORVEL Glossary of Model Engine Terms
AAO Ceramic Seal
A new cylinder/piston technology used on NORVEL .15 engines. AAO means (Aluminum piston, Aluminum cylinder, coated with Oxide). Oxide is a ceramic structure that is harder than chrome, nickel, or steel. It is porous, so it holds oil and creates a ceramic seal between the cylinder and the piston. This improves combustion efficiency and power from 20-40%.
Carburetor
The chamber which mixes air from the venturi and fuel from the fuel jet. The carburetor in a NORVEL engine is pressure fitted into the crankcase, and are sold as a unit
Cone
The purpose of the cone is to hold the drive washer onto the crankshaft. The cone fits onto the crankshaft, and is held on by tightening the propeller screw.
Connecting rod
The connecting rod connects the piston to the crankshaft. As the piston travels back and forth, the connecting rod turns the crankshaft in a rotary motion.
Coverplate
Also known as a "rear cover" or "back plate", it is a cover which screws into the back of the crankcase. The coverplate is easily removed with a NORVEL wrench, or even a nickel.
Coverplate Gasket
This is an aluminum gasket which fits between the crankcase and the coverplate. Do not be alarmed if your NORVEL engine did not come with one of these gaskets: depending on tolerances, the manufacturer includes or omits this part.
Crankcase
The casted aluminum "body" of the engine. In NORVEL engines, the carburetor is pressure fitted (or epoxied, depending on the age of the model) into the crankcase at the factory.
Crankshaft
The crankshaft turns back-and-forth motion into rotary motion, It is attached on one end to a connecting rod and turns the propeller screw on the other. Also, the crankshaft contains a rotary valve, which takes fuel from the fuel jet, and air from the venturi, and injects it at timed intervals into the combustion chamber. This rotary valve also creates a partial vacuum which draws air through the venturi, and fuel from the fuel tank.
Cylinder Head Gaskets
Cylinder head gaskets are inserted between the cylinder head and the crankcase. Adding more head gaskets will make the timing more critical, which is a complex procedure performed mostly by competitors.
Cylinder Head Screws
These four screws attach the cylinder head to the crankcase.
Cylinder/Piston Set
The piston travels up and down inside the cylinder. The type of cylinder/piston set found in a NORVEL .049 or .061 is known as AAN: Aluminum piston, Aluminum cylinder, inside of which is a Nickel-plated piston sleeve. The cylinder/piston set includes the connecting rod and wristpin.
Drive Washer
The purpose of the drive washer is to engage the propeller, using little grooves on its forward surface which fit into grooves on the rear side of a propeller hub. The drive washer fits onto the cone and is therefore driven by the crankshaft .
Freedom XL Glow Plug
The new hot glow plug from NORVEL. Can be used with most standard ni-cd glo-ignitors and clips. Requires glow head 110131
Fuel Jet
Included in the needle valve assembly, the fuel jet (or "spray bar") is bar containing the aperature through which fuel is injected into the carburetor. This aperature is made either larger or smaller by screwing or unscrewing the needle valve, respectively.
Glow Head for 100138 Plug
The NORVEL glow head is a two-piece unit. The high performance glow plug inserts into the head as shown in the engine schematic. Instead of using a NORVEL glow plug, one can insert a Standard Short Plug Head Adapter into the head to accommodate a standard short glow plug.
Glow Head Gasket
The glow head gasket is a copper ring which sits underneath the glow plug. This is an important gasket, as it is used to adjust the compression in the compression chamber. Adding glow head gaskets will reduce the compression, and removing gaskets will raise the compression.
Glow Plug (Cold)
The purpose of a glow plug is to provide the heat necessary for combustion. The NORVEL glow plug inserts into the Glow Head from underneath, and the head is then screwed down onto the crankcase. Heating the plug is accomplished with a Ni Cad Starter using 1.5 volts.
Grid liner
The grid liner holds the wire net onto the venturi.
Muffler Assembly
Every NORVEL engine comes equipped with a muffler, the purposes of which are to (a) quiet the engine, (b) direct the exhaust, and (c) in the case of a pressure tapped muffler, to provide pressure for a pressurized fuel system. The muffler assembly on all 1997 NORVEL engines is easily removable by taking off the muffler spring. It can be rotated, so that it emits exhaust forward, and the emission can be rotated 360 degrees around the axis of the muffler body. For minimum weight in a competitive environment, the muffler can be left off entirely.
Needle Valve Assembly
The needle valve controls the amount of fuel which is allowed into the carburetor. Adjustment of this valve is critical to your success in starting and running an engine.
Pressure Tapped Coverplate
This plate has a pressure tap, consisting of a 3mm hole, and a hose fitting used to pressurize the fuel system. It screws onto the crankcase just like the standard coverplate.
Pressure Tapped Muffler
All NORVEL R/C engines come with pressure tapped mufflers: R/C engines use muffler pressure because they cannot be used with crankcase pressure. These mufflers are removable by taking off the muffler spring. They can be repositioned to emit exhaust forwards, and the emission can be rotated 360 degrees along the axis of the muffler.
Propeller Spinner and Screw
The propeller spinner holds the prop against the drive gasket. Be sure to tighten the propeller screw securely into the crankshaft after affixing the propeller.
This adapter fits into the glow head in place of a NORVEL High Performance Glow Plug. It has threads to accommodate a standard short glow plug.
Throttle Barrel
The throttle barrel opens and closes the air aperature in the carburetor. From the carburetor, the fuel and air mixture travels through the inside of the crankshaft to the combustion chamber. Proper needle valve adjustment is essential for good carburetion.
Throttle Lever
The throttle lever turns the throttle barrel, exposing either more of the aperature or less of the aperature, to let in more or less air, respectively, into the carburetor. The motion of the throttle lever is controlled by a servo and rod.
Throttle Lever Stop Screw
(also known as the idle set screw) This screw has two functions: to adjust the idle, and to act as a governor for the throttle lever: as you turn the screw, the eccentric head of the screw gets closer to the throttle lever, which therefore shortens its path.
Throttle Lever Stop Spring
The stop spring holds the correct setting for the throttle lever stop.
Venturi
see "carburetor"
Wire Net
The wire net acts as a filter and diffusor for air entering the venturi and is held in place by the grid liner.
Wrist pin
The wrist pin holds the connecting rod to the piston.
< Message edited by redbird340 -- 9/19/2008 9:14 AM >
Hide Signatures
       Post #: 342
RE: Norvel Engine FAQ - 9/17/2008 8:14 AM
redbird340
Score: 100
Status: offline
Starting a NORVEL .049-.061 Engine
Introduction
Starting and running a brand new model airplane engine for the first time can be a frustrating experience, especially if you don't know the basics of engine operation and starting. New engines always require break-in before they are ready to produce reliable power for flight. The sections below will tell you how to best deal with setup and starting of a new NORVEL .049-.061 engine.
A. Getting Ready for Engine Starting
To run an engine properly, you will need a mounting stand, a fuel tank, fuel filler, fuel, propeller, battery and glow plug clip. Instead of a stand, you can use the airplane you intend to fly. Whether you use a stand or your model, be sure to work on a bench with the engine several feet off the ground. Dust and dirt WILL ruin your engine.
Never clamp an engine in a vice. The pressure required to hold the engine will distort or even crack the cast crankcase, and there is a good chance that the running vibration will make the engine slip loose!
A .049 or .061 engine must be mounted on its lugs by four screws of at least #2 size; although #3 size is preferred. A piece of 1x2 board with a slot cut in the end for the engine can be a good mounting stand. Note that the grain must be parallel to the rotating axis of the engine; if it goes across, the wood may crack. The stand may be clamped in a vice well behind the engine, or clamped to a workbench, sawhorse, etc. You can also buy a mounting stand which is specially designed for model engines.
Do not attempt to break in an engine while holding the mount in your hands. Set up a fuel tank so that the center-line of the tank is between ¼-inch and ½-inch below the needle valve level. This will prevent fuel from flooding the engine.
Next, you need a starting battery. The two best solutions are to solder a pair of fresh alkaline D cells in parallel, or to use a single NiCd cell of at least 1500 mAh capacity. The battery should be connected to a suitable clip by standard lamp cord of no more than two foot length. If a lead-acid or gel cell is used, a suitable resistor must be installed to prevent glow plug burnout. Also, if you are using an .049 or .061 engine with the Freedom XL™ #110138 glow plug, you can use a hobby battery/power panel/glow plug clip combination. The Kwik-Start from Du-bro is a convenient Nicd battery/glow igniter that attaches directly to a Freedom XL™ #110138 plug for ½-inch A engines. We recommend the Kwik-Start as the most convenient, successful starting battery for a NORVEL engine when using the #110138 plug.
Finally, and VERY important! Use protection for your hearing. Suitable ear plugs or protectors are available at any gun store, hardware store, or most drug stores. Beware, hearing damage is usually PERMANENT.
B. Starting Techniques
There are three main techniques for starting an engine.
First, and oldest is to flip the prop through its stroke by hand. You can use your finger or a chicken stick . For safety, the chicken stick is preferable. This is a stick with rubber or vinyl hose stuck over it to prevent damage to the propeller. If you do use your finger, wrap it well with a cloth or wear a leather glove to prevent propeller cuts.
Many people prefer to use an electric starter, though. This is safe for the user, but unless done carefully, can be damaging to an engine. There are a couple of ways the damage can happen. If the engine has too much fuel in it (flooded), the top of the cylinder can become completely full of the fluid. The resulting hydraulic lock will cause severe damage to the engine (usually by bending or breaking the crankshaft) if the strong force of the electric starter is applied to the propeller when the piston/conrod/crankshaft cannot move through an entire cycle. In some cases with a NORVEL .049-.061, the prop screw will spin off if the engine is flooded when the electric starter is applied. In fact, well-tightened prop screws will spin off only if the engine is flooded.
To avoid this, always be sure the engine does not have a lot of fuel draining into it (flooding) from the fuel tank and that the propeller may easily be turned over by grasping it firmly and pulling it through the compression stroke.
Another possible way to cause damage to an engine with an electric starter is to hold the starter hard against the propeller or spinner and just let it grind away.
The correct technique for electric starter use is to let the starter rev up to full speed, and just touch it to the spinner briefly to spin the prop rapidly. Just a touch will give the prop several rotations; if the starting conditions are correct, the engine will catch on its own.
The third technique for starting a model engine is with a starter spring. This third starting method is safe, reliable, and inexpensive. Your fingers are easily kept away from the propeller's cutting edges, and no expensive starter motor and battery are needed. In addition, the propeller will get a much better kick than you can provide by hand.
To use this method, engage the spring to the propeller, wind the prop backwards one (and ONLY one) full turn, and then release it. The release should be done by pulling your hand straight away from the engine. This will ensure that you are completely clear when the next blade comes around.
There are relative advantages to each starting technique. Finger starts can be the very fastest way to start an engine, if you have your technique perfect on a well broken-in engine. Electric starters are wonderful for dealing with new engines that are still too tight or old ones that are nearly worn out. Spring starters are very good, but add some weight to the engine, and not all engines have them.
C. Starting
For first runs, it's a good idea to add an extra glow head gasket or two under the glow plug of a Norvel engine. The first runs on any engine are most easily accomplished with the muffler off. This allows you to easily port prime the engine for easiest starting, and allows the break-in runs to be a bit cooler running.
Before starting your engine the first time, be sure to read "Breaking-in a Norvel Engine".
Here is the easiest technique for starting a brand new engine:
On a completely new engine, start with the fuel tank empty. The technique is to get initial firing with just a port prime, then find the correct fuel setting for sustained running. To port prime an engine, turn the propeller until the piston closes the exhaust port completely.
You can see when it is closed by looking in the exhaust port as you turn the propeller counter-clockwise. The muffler must be removed for you to see into the exhaust port.
Note: having the piston close the exhaust port is very important! Squirt a few drops of fuel onto the piston side-wall (through the exhaust port), and rotate the prop through two times. Now, hook up the battery to the glow plug, and flip the prop over as fast as you can (or, use a spring or electric starter).
It will take a few flips of the prop to get the fuel distributed, but then the engine should fire up and run a very short burst of perhaps 1/2 second or so. If the engine fails to fire after 10 flips or so, repeat the port prime.
Repeat this short run a couple of times, to get the feel of it.
Next, prime the port as above, but also put one (and only one!) drop of fuel on the intake screen. This should make the engine run a bit longer, and get some fuel vapors into the crankcase. At this point, fill the fuel tank. Set the needle valve open according to your engine instructions. Repeat the starting procedure above, and the engine should soon start running.
D. Trouble Shooting
The main problems that cause difficulty in starting an engine are:
•Bad or weak batteries, frayed wires, dirty glow plug clip. These problems all show up as a very weak glow from the glow plug.
•Old or dirty fuel. Fuel must always be kept in sealed containers, and should be filtered as it is put into the fuel tank or between the tank and engine. If the fuel is old or not sealed well, it can absorb water into the alcohol base, and this will cause poor running. Any dirt in the fuel can clog up the needle valve and cause erratic running or no fuel supply at all. The fuel must be an approved model engine fuel consisting of a mix of methanol (methyl alcohol), oil (castor oil preferred), and nitromethane. Gasoline, kerosene, cigarette lighter fluid, etc. will NOT work, and can be very dangerous.
•Unbalanced propellers. A propeller is a precision device. Your NORVEL engine is capable of turning a propeller at over 25,000 rpm. That is ten times the speed of an average car engine! If your propeller is unbalanced, the vibration can prematurely wear out the engine, and at least will cause erratic settings because of the vibration induced foam in the fuel line. Of course, any propeller that has been damaged should immediately be thrown away as an extreme safety hazard.
•Improper tank height. Too low will not allow the engine to draw fuel properly, and the needle will be very hard to set correctly. If the tank is too high, the engine will be flooded with fuel, and become hard to start.
•Air leaks. Check that all the screws holding the cylinder to the crankcase are tight, the glow head is tight, the coverplate is tight, and that all the fuel hoses are free of holes. Air leaks will, at the very least, cause an engine to have low power, and at worst, make it impossible to run. If you see bubbles coming out of the head or coverplate during running, the engine has an air leak.
•Burned-out or contaminated glow plug. Check the glow plug for black or brown spots on the filament coil. If you are using a non-recommended fuel or a rubber filler bulb or syringe with rubber stopper, the plug can become fouled and will not heat enough to start or maintain engine combustion. Plugs should glow very bright white-orange when good. Hearing a sizzle as you try to start the engine does not always mean the plug is hot enough to start combustion.
Hide Signatures
       Post #: 343
RE: Norvel Engine FAQ - 9/17/2008 8:20 AM
redbird340
Score: 100
Status: offline
NORVEL Engine feels too tight
NORVEL engines are well known for tightness when new.
First, it's important to be sure the engine is well lubricated. Since time elapses between factory shipment and arrival in your workshop, the special Revlite ceramic coating sometimes absorbs all the oil applied at the factory. You should remove the glow plug head and lubricate cylinder/piston with castor oil, high quality machine oil (3-in-1 oil is too thin), or light weight motor oil. If possible, let oil cure in cylinder 24 hours with piston at bottom of cylinder.
*COLD FUEL IS NOT A LUBRICANT*
Alcohol in cold fuel washes away most oil contained in the fuel. Often trying to lubricate with cold fuel will make matters worse.
If you have an electric starter, you can cold run a well-lubricated engine backwards (clockwise) with the starter by reversing polarity and keeping glow plug removed from engine. One minute of cold running with lots of oil will loosen up a motor a lot.
If you're starting by hand or spring, turn the propeller quickly through the tightness clockwise , so the prop doesn't spin off, 1oo times or so. (Do this with glow battery OFF!). You will feel the motor loosen up. When it feels looser, begin normal staring procedures again.
You'll notice that, when turning the propeller slowly, the engine will feel very tight. But, when turning the propeller rapidly, it feels looser.
Also, you may notice that the propeller will "rock" between two points at top dead center (when piston is at top position in stroke). This is totally normal.
Remember, you need all the power you can get to power small airplanes. NORVEL engines are optimized for maximum compression and power. Our impeccable reputation for long engine life is in no small part due to the tight cylinder/piston fit.
Hide Signatures
       Post #: 344
RE: Norvel Engine FAQ - 9/17/2008 8:22 AM
redbird340
Score: 100
Status: offline
Selecting Fuel and Propellers for .049 and .061 NORVEL Engines
The basics of fuel and propeller selection are that the .049 and .061 NORVEL engines are optimized for running in the range of 16,000 to 25,000 rpm at full throttle. Above or below that range, and the power will be probably be reduced and wear increased. Select a combination of fuel and propeller that run in that range, and you will have great success with your NORVEL engine.
A. Fuels
Model glow fuels all use methanol (methyl alcohol) for the fuel base. That is the main burning ingredient. Added to that are oil and nitromethane. The engines have no lubricating system, so the oil is carried by the fuel, and a constant supply is needed.
Nitromethane is an igniter that also liberates oxygen. It increases power, but also increases the heat and wear rate, while reducing fuel economy. You need to seek a combination that best suits the needs of your flying style. NORVEL recommends that you use fuels with 16% to 20% oil content.
In addition, some of the oil should be high quality castor oil. Synthetic oils have better lubricity and lower viscosity than castor oil, but the castor will protect an engine up to higher temperatures, and also form a barrier against moisture when the engine is in storage.
If you choose to use less oil, and/or, all synthetic oils in an attempt to maximize engine performance, be very sure to never let the engine run at an over lean setting, and follow up a day's flying with a good anti-rust after-run oil. Marvel Mystery air tool oil is an excellent choice, or there are several brands of after run oils available through the hobby shops. NORVEL uses and sells After-Run Oil, which also works very well.
The ideal nitromethane content is somewhat difficult to nail down. Lower nitro content fuel can run very fast, but finding the correct needle setting is more difficult, and a higher compression ratio is needed. The NORVEL engines were designed in Russia where nitromethane is extremely difficult (and illegal) to buy. As a result, the engines run perfectly well with no nitro at all or very little nitro.
Nitro gives you ease of starting, especially in cold weather, and generally, a broader range of acceptable needle valve settings. For racing situations, there is no question that more Nitro means more power. Generally, 10% to 15% nitro is good for sport flying and general purposes.
As your applications become more critical, the nitro content should be raised. As a practical limit, stay below 35% Nitro, or the wear rate and potential for damage to the engine become excessive. We know that competitors use up to 65% nitro fuels, but they are willing to replace an engine each flight if that is what is needed to win.
NORVEL now offers NVX-brand fuel. It is available as NVX15 (15% nitro), NVX25 (25% nitro), and NVX35 (35% nitro). NVX fuel is specially blended to maximize performance of small engines and to protect them from high rpm. We have tested this fuel, and we guarantee it works perfectly with NORVEL .049-.061 engines.
There are other brands of fuel that we recommend. Omega from Morgan fuels, K&B 500 or 1000, Sig Champion, Wildcat 1/2A, Byron's 1/2A, and Cox fuel all seem to work well.
Some fuels have been reported by our customers to foul the glow plug of a NORVEL engine. NORVEL .049-.061 engines run quite cool, so contaminants in fuel will affect a NORVEL engine's plug faster than in a Cox engine or other larger engine. Coolpower from Morgan fuels, Byron's non- 1/2A fuel, and Powermaster fuels have been reported by some customers to cause problems with our engines. If you are using a brand of fuel not listed in this article and are experiencing problems with engine performance, try NVX-fuel or one of the recommended brands.
One additional tip regarding fuel contamination. Dissolved rubber will build-up on a glow plug in a NORVEL engine, causing premature burn-out or erratic engine performance. Do not use a rubber fuel bulb or a syringe with rubber stopper for fueling and defueling your airplane. Use a hand pump, electric pump, all-plastic bottle, or all-plastic syringe such as the NORVEL NO-RUB fuel filler, available on our website.
Once a glow plug has been contaminated, it cannot be cleaned or repaired. If you have defueled into a bottle of fuel with a rubber syringe or rubber fuel bulb, it is likely that the remaining fuel in the bottle is already heavily contaminated with dissolved rubber. As the fuel level in the bottle gets lower and lower, the concentration of dissolved rubber will get higher and higher.
B. Propellers
Selection of a propeller is a function of the type of model, the speed it will fly, its weight and drag factor, plus the fuel nitro level you plan to use. Running an engine in its ideal speed range tends makes it easier to operate, and it will last longer. Higher engine speeds equate to more power output, at least up to 20,000 rpm or so.
NORVEL sells the popular Grish Tornado line of small propellers. 5x3 to 6x3 are the best sizes for NORVEL .049-.061 engines, although some customers with special needs will use 6x4 or 7x3 props. If using a 6x4 prop or larger, you will need to do extra break-in, and even then the engine may overheat if run too lean.
To select a prop, generally, select an rpm range you want to operate, the nitro level of the fuel you intend to use, then look at the likely speed of the model. Examine the engine/prop rpm charts below to pick a prop that will put you in your desired speed range with the pitch you need. After this, you can only optimize the propeller selection by actual flight testing.
I will be posting a chart later, having some difficulty right now.
Breaking in a NORVEL Engine
All engines need some break-in. This is a process where the metal parts of the engine are heat-cycled by running to find a final fit. The fit can not be machined in ahead of time because then the metal drift would be away from the ideal, not toward it. In addition, the correct final fit of an engine is partly determined by how the engine is to be used.
New engines are fitted tightly to allow for break-in, and will not run fast or hold their speed setting until the break-in is completed. It requires some careful break-in to get the very best performance. Improper break-in will give you a less powerful engine that won't last very long. The way NORVEL engines are fitted at delivery will work in to become an ideal fit after break-in.
NORVEL engines are made with an aluminum piston, and nickel plated (or ceramic coated) aluminum cylinder. This combination allows very high speed running with minimum friction. On a new NORVEL, it is proper for the piston to nearly seize at the top of the stroke. This should never quite go away, but it will smooth out.
By the way, the information contained in this article is intended for general users of NORVEL engines. Break-in procedures for specialized racing and competitive events may be different than those presented in this article.
You should break-in a NORVEL engine with the same fuel you intend to use for flying. When higher nitro will be used (e.g. 35%), it is better to break-in the engine with lower nitro, then progress up to higher nitro contents when more power is required. The propeller should be the next size smaller, and you should start with lower compression (more head gaskets) than you expect to fly with. When in doubt, use three gaskets at first. The entire break-in procedure can be done in an afternoon.
Break-in is very easy, generally taking fewer than ten runs of five minutes each. With the engine mounted on the test stand, start it, and immediately set the needle valve to a point where the engine breaks back and forth between two and four cycle running. Listen to our sound files if you would like to hear how a NORVEL engine sounds in this running mode. You will need to stay by the engine and keep readjusting it through the run to achieve this. Run only for three to five minutes. Allow the engine to cool completely between runs.
After the first run, install the muffler if you plan to use it when flying. Three runs in this configuration are all you need, then it is time to switch to the propeller you plan to fly with. Another two runs at the 2-4 cycle break point are needed. Now on each succeeding run, lean out the engine to go faster and faster. You should be up to full speed after three or four runs.
When the engine will hold its settings, try reducing the number of head gaskets. At some point, the engine will be hard to start, and won't hold its needle setting properly. At this point, add one gasket back in. When an engine will run out a full five minutes at full speed, it is broken in. During the whole break-in period, stay by the engine and do not let it sag due to overheating.
Be ready to richen up the mixture and cool the engine down if it sounds as though it is slowing down by going too lean. The only way to tell if an engine is broken-in is by seeing (and hearing) how it runs. If it holds a steady peak setting, it is ready to fly.
< Message edited by redbird340 -- 9/17/2008 8:31 AM >
Hide Signatures
       Post #: 345
RE: Norvel Engine FAQ - 9/17/2008 8:25 AM
redbird340
Score: 100
Status: offline
Setting the Needle Valve
It is important to learn how to set the needle valve correctly on any engine. An understanding of how an engine is running, and what the needle's effects are is vital to both proper break-in and peak flying performance. The needle valve sets up a resistance to flow of fuel into the engine. The fuel is either drawn into the engine by the airflow through the venturi, or pushed into the engine by a pressurized fuel supply. Whichever is the case, the needle is the only control to get the air/fuel mix correct.
The range of mixture goes from too much fuel (rich) to too little fuel (lean). As you screw the needle valve in (clockwise), the needle valve lets less fuel into the venturi. With less fuel in the fuel/air mixture, the engine is running "leaner" than it does with more fuel in the fuel/air mixture.
First, as a general introduction to the concepts of "rich and lean" needle valve settings, listen to the engine as it is adjusted from rich to lean, and back to rich.
Rich to lean, lean to rich. AIF
The next three sounds demonstrate how the engine will run at three degrees of richness. When the NORVEL .061 engine runs rich (although it is a "2-cycle" engine) it does not operate in a true 2-cycle mode, and it is said to run in 4-cycle mode.
4-Cycle slow running/Very rich AIF
4-Cycle medium running/Medium rich AIF
4-Cycle fast running/Slightly rich AIF
The next sound demonstrates how the engine will run when the needle valve is set for 2-cycle optimum mode, which should attain maximum rpm. As you turn the needle clockwise (very slowly) from a "slightly rich" setting, you will reach 2-cycle optimum mode.
2-Cycle Optimum/Maximum rpm AIF
Finally, if you turn the needle valve too much clockwise, you will set the fuel/air mixture as too lean. The engine will not continue to operate if it is too lean, but it will run a little bit and gradually die out from lack of enough fuel in the fuel/air mixture.
Too lean, engine dies out AIF
The ideal needle valve setting varies with fuel and propeller choices, the compression ratio you have chosen, weather, and fuel tank setup. You can only find the correct setting by experiment.
The best tool to use in setting your needle valve is a good tachometer for accurately measuring the engine speed and evaluating where it has peaked. Your ears will do for a rough measure, but they are not as accurate as a tachometer, and will not give you a good comparison from run to run.
The perfect needle valve setting on the ground will not be the ideal one when the model is in the air. As the propeller unloads with airplane speed, the engine setting requirements change. Other factors that effect needle setting in flight are the way the tank is vented, and the tank position in the model, and the type of flying you do.
The point here is that you need to experiment with needle adjustments away from the peak on the ground that will provide the ideal setting for peak performance in the air where you need it. Generally, the engine needs to be set richer on the ground to reach peak in the air.
Hide Signatures
       Post #: 346
RE: Norvel Engine FAQ - 9/17/2008 8:35 AM
redbird340
Score: 100
Status: offline
Fuel Tank Systems for .049 and .061 NORVEL Engines
A. Standard fuel tanks
1. Metal tanks
Metal fuel tanks are still available, and work well in free-flight and control-line models. They are very compact, and relatively light weight because they are made of very thin metal. Two basic styles exist, the rectangular and wedge. The rectangular tank holds the most fuel for the overall size, but is not designed to run in any position but basically upright.
These tanks also work well in R/C applications like powered gliders. The wedge tank is designed to allow both upright and inverted flight when used in a control-line model. A variety of inlet and outlet systems have been developed to improve the fuel delivery when a pressure system is not used. Pressure can be used with any of these tanks.
2. Plastic tanks, clunk systems
These commercially available units function pretty well. They use a small weight on the end of a flexible fuel pick-up line to assure fuel draw no matter what the model's motion or attitude. They work well with muffler or coverplate pressure systems.
Unfortunately, in the small sizes required for NORVEL engines, they are comparatively bulky and heavy since they use the same hardware as the large size tanks. Still, most customers use plastic tanks such as the Sullivan 1 oz. and 2 oz. tanks offered by NORVEL. The setup of these tanks is familiar to experienced modelers, so installing one is simple, and getting help in installing and using one is usually not a problem.
3. Balloon tanks
These tanks are incredibly simple, inexpensive and lightweight. The only drawback is that they cannot be used with a pressure fuel system. Definitely an easy do-it-yourself project. Standard balloons from the toy store work perfectly, and are very resistant to fuel degradation. The only caution is that the part of the model where the balloon is contained must be epoxy coated, and there can be no sharp points like screw ends sticking into the chamber.
B. Pressurized fuel systems
In many situations, the way to get the most reliable engine runs is to use a pressurized fuel system. Although there are many models where you don't need to run pressure, the engine will always be easier to run at optimum if the fuel supply is pressurized. Note that pressure does not increase power. The engine will run more consistently at peak power with pressure, but not one rpm will be gained over the best it will do without pressure. Several systems are available to provide pressure to the fuel. Let us start with the mildest and simplest.
1. Airstream pressure
This is simply a case of aiming the fuel tank vent into the incoming airstream. This will provide a slight pressure to push fuel to the engine, but not very much. At 50 ft/sec velocity you get 0.02 psi boost.
2. Muffler pressure
A muffler pressure tap provides a mild boost with the added benefits that it varies with engine rpm, and is remarkably uncomplicated. The pressure is peaked with high rpm, and drops to near zero at an engine idle. This is a perfect match for the needs of a throttled engine. Norvel sells a pre-tapped muffler. This is the best system for throttled engines.
3. Coverplate pressure
The pressure inside the crankcase varies from slightly negative during the intake portion of the cycle to highly positive just before the bypass ports open. A coverplate pressure tap has a very small hole in it so that the pressure to the tank is an average of the whole cycle in the crankcase. That is a moderately positive net pressure and quite independent of engine rpm. As such, the needle valve setting becomes relatively narrow, but once set correctly, the engine will hold its setting very well despite speed and attitude changes of the model flight path. Coverplate pressure will only work with non-throttled engines.
4. Timed pressure
For very high-g maneuvering, and when the engine has been modified to have a larger than normal venturi size, high pressure is needed to assure consistent fuel delivery. Note that if you make this modification you will void your engine warranty. For competition, many people find that an acceptable price. The idea behind timed pressure is to install a pressure tap that comes out the right side of the crankcase in the location where the crankshaft inlet port is (right side as viewed from the rear of the engine). This tap is only uncovered at the point where the pressure in the crankcase is the very highest. This will give you the second highest level of pressure of any of the systems, but has the benefit of easier handling than the bladder system described below.
5. Bladder pressure
The ultimate in simple, reliable pressure systems is the bladder tank . This is simply a rubber container that is inflated with fuel to provide high pressure fuel delivery. We are talking pressures that will squirt fuel for many feet straight up. There is NO variation in engine run with airplane attitude or g-loading beyond that resulting from the varying drag load on the propeller. This is the ultimate for combat and racing.
The usual tank is a length of surgical rubber tubing (amber natural rubber) which is blown up to about 5 times its normal diameter and double its length. The tank will run very consistently until the last moments when it generally will go rich for a fraction of a second, then cut off lean as the fuel is exhausted.
Bladder systems require some special coordination in starting, as the fuel must be blocked until the engine is actually running out a prime. If the needle is incorrectly set, the engine can flood out or run way too lean for a long time. If the engine stops, the fuel keeps flowing and flowing, so the engine will get seriously flooded.
Hide Signatures
       Post #: 347
RE: Norvel Engine FAQ - 9/17/2008 8:48 AM
redbird340
Score: 100
Status: offline
Troubleshooting
Troubleshooting: .049 - .061 Engine Won't Even Pop
You own a NORVEL .049 or .061 engine, and you are having trouble getting the engine to pop or to show signs of starting. (Popping is when the engine runs for a split-second then stops).
First of all, you should read the technical article in this web site entitled, "Starting a NORVEL Engine." If you've read this article and still can't get the engine to pop, then read on.
All NORVEL engines are individually started and run at our manufacturing facility, so it is almost certain that your new NORVEL engine will pop if properly started. Technically, popping occurs when the glow plug is hot enough to induce combustion in the combustion chamber, and when there a small amount of fuel/air mixture in the combustion chamber. The result is that the fuel/air mixture explodes, the engine runs for a split second, then stops.
This would be a good sign. When the engine is popping, it means that your glow plug is hot enough, your fuel is good, and the engine is ready to run. Just open the needle valve incrementally, keep popping the engine, and, when the needle is set to the right place, the motor will keep running.
Unfortunately for you, your NORVEL engine won't even pop. There's really only three possible explanations for this. Either no fuel/air mixture is getting into the combustion chamber from your priming, the glow plug is not hot enough, or your fuel is old or bad.
For the most effective priming procedure, read the article "Starting a NORVEL Engine." If you think you're priming the engine right, you probably are.
So turn your attention to the glow plug. If your NORVEL engine came equipped with the #100138 plug, you may need a stronger battery to heat the plug. You can check which plug was shipped with your engine by looking at the exploded diagram on your instruction sheet. If you still can't tell which plug shipped with your engine, call NORVEL at (330) 425-3631 for technical assistance.
The cold glow plug #100138 is really cold, which means that it requires a lot of battery power to get hot enough to make combustion. If you are using 2 D-cell batteries, or a standard 1.5 volt hobby battery with a #100138 NORVEL glow plug, chances are your plug is not getting hot enough.
You can check this by removing the muffler and looking in the exhaust port while the power supply is attached to the glow plug. It should radiate bright orange, visible even in daylight. Don't stick your eyeball up to the exhaust port!
Hearing a sizzle doesn't mean the plug is hot enough for combustion. It really needs to be hot, and checking for the brightness of the glow, from outside the motor, is a good check.
If your plug is barely glowing, then you need either to increase the power supply to the glow plug (with a hobby power panel turned up to 3-4 amps) or to use a "hot" glow plug. Hot plugs are available from NORVEL; they're called the #110138 Freedom XL‘ plugs. Also, you can use a Cox glow head if available.
A #110138 Freedom XL‘ plug will get hot enough to make combustion with even a hobby battery or D-cells. Make sure your hobby battery or D-cells are fresh, though, because weak batteries won't work even with a hot plug.
The best solution for the long run is to use a Freedom XL‘ plug with a Du-bro Kwik-Start rechargeable NI-CD glo- ignitor. These glow plug ignitors are compact, powerful, rechargeable, and inexpensive when compared to the price of battery purchases over time.
Troubleshooting: Problems with the NORVEL #102100 Fuel Tank Mount
The NORVEL fuel tank mount was designed as a multi- use fuel tank mount for R/C and control line. As such, it should be a strong, vibration-free mount, a leak-free fuel tank, and a steady source of fuel in tight manuevers and inverted flight. The fuel tank mount should have external dimensions that allow for use of NORVEL and Cox engines on the thousands of kits already designed for Cox reed valve engines: RTF's, sailplanes, control-line planes, etc. The CG cannot be changed too much when upgrading a Cox reed valve .049 to a NORVEL .049 with fuel tank mount. The tank should hold as much fuel as possible. And, of course, the engine with tank mount should fit inside a common canopy of 1/2A airplanes.
As you can see, a lot is asked of our little fuel tank mount. For the most part, it does its job extremely well. It only holds 0.5 oz. of fuel, enough for 2-3 minutes of flight with an .061 and 3-5 minutes of flight with an .049. But it is sturdy, vibration-free, and leak- free.
The biggest problem customers have with the tank is filling it. Because there is not enough volume in the tank for a clunk system, some design compromises have to be made to provide for fuel suction during manuevers and inverted flight. Instead of using the two-pickup system employed by other manufacturers, NORVEL uses a single brass pick-up tube that sucks from the CENTER of the rear part of the tank.
Upon first glance, some customers are confused how this will work during inverted flight. Well, the air ram vent partially forces the fuel to the rear of the tank, and the rest is handled by physics. Remember the physics lesson where a bucket is swinging in a vertical loop, yet the water stays in the bucket? Well, the NORVEL tank mount uses this same principle to keep fuel in the small cup at the rear part of the tank.
As long as fuel stays in the rear of the tank (which it will unless flight is very slow), it will be picked-up from the pick-up tube.
This is great, except when filling. If you use the vent tube for filling, fuel will pour out of the tank's pick-up tube as soon as the tank is half-full. But, if you point the nose of the airplane towards the ground, you can fill the tank to the top without a problem. And that's the solution.
Some customers who use the tank mount on sailplanes find that the pick-up system will not suck all the fuel from the tank. In this case, it is best to remove the pick-up tube gently and bend it so it will pick-up from the bottom of the tank. This modification will prevent sucking during inverted flight, but this is not a concern for sailplane pilots.
Another common complaint about the fuel tank mount is the position of the fuel pick-up tube. If you find the end of the pick- up tube to be too close to the mounting bolts of the engine, just bend it up a little. If you have a hard time putting fuel tubing onto the tube, you may want to try small fuel tubing. Medium tubing is sometimes too big to fit onto the tube as designed.
We hope you find these tips on the fuel tank mount to be helpful. We also hope that you will understand why any fuel tank mount cannot serve all needs perfectly. It may surprise you to learn that we actually recommend using an external fuel tank whenever possible when building or designing a model airplane. An external tank will hold more fuel and will work more reliably in inverted flight and for filling.
Troubleshooting: .049 - .061 Engine Cutting-Out
Cutting-out can occur when the engine is running at high rpm, or at idle. Cutting-out is defined as a very abrupt stopping of running just as it was running perfectly.
The most common cause for cutting-out is over-compression. The NORVEL cylinder/piston set is quite tight from the factory, and each NORVEL engine is set with one copper gasket underneath the glow plug. By adding the two additional gaskets supplied with your engine, you will reduce the compression. This will help eliminate sudden cutting- out.
Over-compression causes pre-ignition, which will stop the piston during its upward movement in the stroke. Cutting- out can happen at high or low rpm.
If you're using 25% or 35% nitro, you may even need to add more gaskets, since higher nitro will increase compression. This is one reason why lower nitro is better for breaking in your engine.
A good rule is to start breaking-in a new engine with 15% nitro (NVX15 fuel is recommended), the #110138 Freedom XL glow plug, and all three copper gaskets #110117 supplied with each engine. One .2 mm gasket is installed in each engine, and two .1 mm gaskets are taped to the instruction sheet. Be careful when removing the gaskets from the instruction sheet so as not to bend them.
Troubleshooting: .049 - .061 Engine Overheating
How do you know if a NORVEL engine is overheating?
If you have run model engines before, you probably have some idea of how an overheated engine behaves. When started cold, the engine runs fine. Then, after a minute or two of running, the engine begins to sag in power. Leaning out of the needle valve temporarily fixes the problem, but the engine just sags again after a few more seconds. It seems the needle valve won't adjust the engine. When the engine sags so much that it dies out, touching the engine will almost certainly burn a finger. Pouring fuel over the cylinder causes rapid boiling and evaporation of the fuel.
There are several causes for engine overheating.
First, if an engine is new, and hasn't been run much, it will overheat if leaned out for extended periods of time. This is most easily avoided by running a new engine rich, following the break- in procedures mentioned in the technical article "Breaking In a NORVEL Engine."
Second, if the fuel does not have enough oil content, or does not have enough castor oil in it, a NORVEL .049-.061 engine will overheat. Fuels with all-synthetic oil will almost always cause a NORVEL engine to overheat. Some large engine fuels work fine, and some do not. Read technical article "Selecting Fuel and Propellers for your NORVEL .049-.061 Engine" for more information.
Third, if the engine has an air leak, it will overheat. Air leaks are sometimes visible as bubbles coming-out from the glow plug area at the top of the cylinder or from the rear coverplate. Other times, air leaks are located at the needle valve threads, more difficult to detect because bubbles will not form on the needle valve screw.
Air leaks will make the engine very difficult to start, and it will run poorly even when running. Using a tachometer to test the engine at maximum rpm is one good way to check engine performance. A low tachometer reading can be the first indication of a problem with an engine.
If your NORVEL engine is overheating consistently even when you run a recommended fuel after 30 minutes of break-in, then the engine almost certainly has an air leak. Locating and eliminating an air leak can be a very simple matter, or it can be very difficult. If you are not experienced with modifying and servicing model engines, we recommend that you send your NORVEL engine to us for inspection and warranty service.
There are four places where an engine can develop an air leak. The #100117 copper glow head gasket seals the top of the cylinder against the glow plug. Putting some fuel on the head of a warm engine and turning the propeller will indicate leaking if bubbles are seen rising from the seam between the glow plug and the head. Similarly, soapy water can check for leaks on the coverplate and cylinder head gasket areas. As previously mentioned, air leaks on the needle valve cannot be identified easily. Placing a piece of small silicon tubing over the needle valve, sealing the threads may eliminate a leak. Success can only be determined by subsequent running and taching of the engine. Silicon sealant can be used on the rear cover plate area to eliminate small leaks.
In any case, leaks are very rare in NORVEL engines, but it may be helpful for you to know how to eliminate them, especially if you plan to disassemble or modify your engine. (These are the two most common causes for air leaks).
Hide Signatures
       Post #: 348
RE: Norvel Engine FAQ - 9/17/2008 8:58 AM
redbird340
Score: 100
Status: offline
Installation and Application of .049 and .061 NORVEL Engines
A. Introduction
Engine mounting is important. The engine must be firmly mounted to your model in a manner that will not come loose, distort the crankcase, or allow vibration. The relative position of the engine and tank are also key elements in achieving steady runs at full power. Finally, the precise angles up, down, and side to side at which the engine is mounted to the model are a significant factor in getting your model to fly the best it can.
NORVEL engines (except the BigMig Start'up .049 and .061) are beam mounted. This means that they are secured by screws that extend through the two lugs on the crankcase of the engine. The model must have two beams that extend from the nose, or, one of the commercial 1/2A engine mounts (such as the NORVEL #0506 mount) may be used to mount the engine on a flat fire-wall.
For control-line models, built in beams are very sensible. They are lighter than the plastic mounts, stronger, and provide the best damping of engine vibration. For free-flight and radio control models, the plastic mounts make a lot of sense. They are convenient, provide easy adjustment of thrust angles, and will break in the event of a crash; a feature that can minimize damage to both the engine and the model by sacrificing an expendable element.
Whichever type of mounting you use, it is vital to be sure that the surfaces are perfectly flat. Any twist or angle in the mounting surfaces will slightly distort the crankcase of the engine and reduce both its performance and life. It is recommended that you flatten the beams on plastic mounts by filing or sanding across both beams simultaneously until they are perfectly parallel to each other and flat across.
B. Control- line
1. 1/2 A Stunt (Precision Aerobatics)
This event requires moderate power, but an absolutely steady engine run for a minimum of 5 minutes. Over the years fuel tanks have been developed to provide this kind of performance. The best combination of NORVEL engine/prop/fuel tank we have found for 1/2A Stunt is as follows: The BigMig .049 engine with the pressure tap coverplate, a Tornado 5x3 propeller, 30% nitro fuel, three head gaskets, and a 1 ounce uniflow stunt tank.
This combination will run above 20,000 rpm, so that the model can fly on 50 ft. of .008 cable flying lines and still have a lap time around 4 1/2 seconds. Due to the uniflow tank and coverplate pressure, the run will be very consistent and powerful no matter what attitude the model has.
2. 1/2 A Combat
Here we need the ultimate power and speed. The way to achieve this is to use the NORVEL AME .049 and a pressure bladder fuel tank. Propeller should be 5x3 or 5x4; there are several popular brands. Again Tornado props seem to perform well, although there is a Cox 5x4 black prop that is popular because it is very rugged.
Fuel should be in the 30% nitro range. The fuel tank is generally a piece of surgical tubing with one end tied off. A syringe is used to produce enough pressure to blow up the tube to several times its regular diameter. A forceps is used to pinch off the fuel line until the engine is running.
3. Control-line Carrier
For carrier flying, it is required that a throttle be used. Since the event is based on the difference between high and low speeds, the NORVEL AME .049 R/C is the engine of choice. It is suggested that a 5x4 prop be used to maximize the speed, and a muffler pressure system be used for reliable fuel delivery.
4. Scale Model
Here it is typical to use a throttled engine, but since speed is not an issue, the BigMig .049 (or .061 if the rules allow) would be a good choice. Reliable idle and throttle performance are a key element in scoring function flight points. The propeller choice depends partly on the model, but aim for rpm's in the 16,000 to 18,000 range. Use 15% to 30% Nitro for reliability and power output. Work with the compression to get the best idle setting, probably three or even four gaskets.
C. Free-Flight
There are two high performance events in free- flight for which the NORVEL engines are ideal, AMA 1/2A gas and the international F1J class. For the first, an .049 is the limiting size, so the NORVEL AME .049 is a great choice. Fuel should be 35% Nitro. Experiment to find the highest compression (fewest head gaskets) that the engine can handle. The prop of choice seems to be the APC 5.5 x 2.
For F1J, an .061 is allowed, so select the AME .061 for this event. A larger prop can be used with this engine, and the APC 6 x 2 works well. The key here is to have massive pulling power to accelerate the model quickly, and pull it straight up as fast as possible. Free-flight power is like a vertical drag race. You want to get as high as possible in just a few seconds. The hole shot is where the race is won.
If you want to use a NORVEL engine for free-flight scale, or Texaco events, you can run the engines with large propellers if needed. We have actually had success turning propellers up to 8 x 3.5. The rpm's dropped to just under 9500, but the run was steady. Only a brief test was tried, and the optimum nitro level and compression ratio would probably cause some slight improvement. Care would be needed to assure good cooling of the engine, as high loadings tend to cause overheating.
Radio Control
Sport
For sport use, we recommended .061 size engines. There is no rule limit on engine size, and the power to weight of the .061 is 20% better than the .049. You can always throttle back if your model is overpowered. For the casual sport flier, the ease of operation and fuel economy of the BigMig engine is desirable. The propeller to use depends on the type of model.
For a basic trainer or for powering a glider, consider a Grish Tornado 6x3 or 6x3 Master Airscrew. For a sport aerobatic model, try either an APC 5.7 x 3 or a Tornado 5.5x4. Keep the nitro content of the fuel around 15% to allow cooler runs, better fuel economy and longer engine life.
As always, experiment with head gaskets, but it is likely that two will be the right number. When using an electric starter on a muffled engine with muffler pressure to the tank, try this: Begin with the engine completely dry of fuel. Attach the glow plug clip, and then put one finger over the muffler exhaust pipe. Touch the electric starter to the prop, and the engine will pump fuel to itself and kick off nearly instantly. Note that this takes more than two hands to accomplish!
Pylon Racing
The need for speed here is a balance between acceleration at the start, pulling power in the turns, and the highest speed on the straights. As with Control-Line Combat, a pressure bladder tank and 5 x 3 or 5 x 4 props seem to be the winning combination. Of course the AME .049 is the engine of choice here. Nitro content of the fuel should be 35%, and raise the compression as far as you can without compromising steady runs throughout the race.
Ducted Fan
The secret to success in Ducted Fan model power is high rpm's, so the engine to use is the AME .061. Since you are running in a duct, you probably want to run without the muffler. The duct will provide pretty good sound attenuation, and the added blockage of your duct by a muffler's frontal area would degrade the thrust produced.
Make a needle valve extension from some spring steel wire, and couple it to the engine s needle with some fuel hose. This will make the minimum hole in your duct wall, and the flexible coupling will reduce the possibility of vibration making your needle setting change.
High power output needs high nitro and the optimized compression level. Try to select a fan that allows the engine to run between 22,000 and 25,000 rpm.
Pusher Installations
When using NORVEL engines in a pusher configuration, it is important to remember that the engine does not receive any cooling flow when on the ground, and less than normal in the air. As such, use a tractor or standard prop of identical type and size to the pusher prop when making ground tests and adjustments. Again, due to reduced cooling, use a slightly smaller prop size than you would for normal in-flight use.
An important point in pusher installations is to make sure the tank will draw fuel correctly. As such, the clunk needs to be at the rear of the tank next to the engine. In addition, the engine will tend to go rich in a climb because the tank will be above it, rather than below. To compensate for this, be sure to use a muffler pressure tap to minimize the variation in fuel delivery.
If you are not using a throttle, the coverplate pressure tap would be an even better choice.
Accessories
When flying R/C, there are a few accessories that will make life a lot easier, and add to your flying enjoyment. First of all, get a good flight box . Make sure it is equipped with all the wrenches, screwdrivers, and pliers you need for on the field adjustments. Then stock it with spare glowplugs, gaskets, propellers, rubber bands, and similar disposable replacement items.
Some of the best accessories to have are the power panel , fuel pump and electric starter. To optimize performance of your engines, buy a tachometer. They cost about the same as a NORVEL engine, and will improve all your engine powered flying.
Keep a notebook with the results of every test run so that you can go back to what you need for a new situation without having to repeat the same experiments over and over. Record the exact engine configuration, number of gaskets, fuel type, propeller, etc. and the resulting rpm's and any handling difficulties.
Get a good set of ultraviolet blocking safety sunglasses. Your eyes cannot be replaced, and they are at a double risk in this situation. Prop blades have been known to separate, especially on high powered engines. In addition, the prop could pick up small pebbles and throw them; so safety glasses provide important protection. Finally, a good set of sunglasses will protect your eyes from UV radiation. Always wear hearing protection.
Hide Signatures
(in reply to redbird340)
       Post #: 349
RE: Norvel Engine FAQ - 9/17/2008 9:00 AM
redbird340
Score: 100
Last Login: 3/14/2009
Status: offline
The following few posts are reserved for additions in the near future; apart from a few other articles, they will contain sound files for norvel engines.
< Message edited by redbird340 -- 9/17/2008 9:16 AM >
Hide Signatures
       Post #: 350
Page:   <<   < prev  12 13 [14] 15 16 17 18 19 20 21   next >   >>
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Norvel Engine FAQ
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.031RCU1
