RE: Norvel Engine FAQ
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Norvel Engine FAQ Page: <<   < prev  4 5 6 7 8 9 [10] 11 12 13   next >   >>
Login
RE: Norvel Engine FAQ - 2/21/2007 1:10:45 AM
thtoyman
Status: offline
yes is a conversion, you should get them a LHS. Or check the web site for the heli.
(in reply to Husky)
       Post #: 226
RE: Norvel Engine FAQ - 6/15/2007 12:57:21 AM
burtcs
Status: offline
All:
About a week ago I got two NIB Big Mig CL Startups. I finally got a chance to run them today. After the 100 turn & oil ritual I put them on the bench and started them up. Each ran 15% nitro, three head gaskets and a Norvel glow head and got about 4 onces of fuel each. They were run on 5.7-3 and 6-3 props. They are both comfortably doing 19.5k and I've seen them go to 21k. I suspect a bit more after more running. And I'll try Galbreath heads then too. I did have some problems with a tank and had to resort to a wedding bubble substitute but the startup tank is ok now.
Ultimatly I'll shoot for 8-4 or 8-5 props at about 9-10k , sort of hotrod texacos
for sport r/c work.
I'm still looking for two Norvel rc carbs.
regards - Steve B.
< Message edited by burtcs -- 6/15/2007 1:28:05 AM >
(in reply to thtoyman)
       Post #: 227
RE: Norvel Engine FAQ - 6/15/2007 1:33:43 AM
N1EDM
Status: offline
With all this talk about Norvel's, where is the best place to get a good deal on a new .074?
Bob
_____________________________
An expert is someone who has been doing it for 15 minutes longer than you.
(in reply to burtcs)
       Post #: 228
RE: Norvel Engine FAQ - 6/15/2007 2:30:17 AM
Andrew
Status: offline
quote:
ORIGINAL: N1EDM
IMHO, there is none!
Unless, you can run across one in a garage sale where the seller does not have an idea what they're currently bringing.
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
(in reply to N1EDM)
       Post #: 229
RE: Norvel Engine FAQ - 6/15/2007 6:32:16 AM
N1EDM
Status: offline
So, they're not available any more, I take it. Hmmm, better get some spare parts for the one that I already have then - I see that Sig still has them.
What are people's opinions on an OP Hornet -09? Or, is there something that will bolt in for the Norvel? I want to build up a Herr Engineering mini-SE.
Bob
(in reply to Andrew)
       Post #: 230
RE: Norvel Engine FAQ - 6/15/2007 5:10:40 PM
Andrew
Status: offline
quote:
ORIGINAL: N1EDM
I wouldn't count on SIG having many parts available -- even though they list them on their web page, they likely don't have any in stock. Good luck!!
the "other" andrew
(in reply to N1EDM)
       Post #: 231
RE: Norvel Engine FAQ - 6/15/2007 10:13:56 PM
N1EDM
Status: offline
So, this is to say that the Norvel is no longer being sold or serviced here in the USA.
Has anyone got any recommended substitutes? Getting one that bolts in to the Norvel bolt pattern would be nice, if it's available.
Bob
       Post #: 232
RE: Norvel Engine FAQ - 6/16/2007 12:16:50 AM
PlaneKrazee
Status: offline
The Norvel .074's are gone. You can get them on ebay at really high prices ($100.00+), purchase Lite Machines .074 heli engines and try to convert them to plane use or you can go electric and be clean and happy. I don't have any experience with the AP .09 or a Thunder Tiger .07. If you get one you can tell us how it goes.
The Norvels made me think about 1/2a in a whole new light. I hated cox engines when I was a kid. The Norvels act much like a modern .40 size engine, even on 5% nitro
Steve B., I don't think your Norvel's will be happy at 8000 rpm. They are not timed to run at that rpm under load and may overheat. I am interested in how you do.
KB1DTB
AMA11123
(in reply to N1EDM)
       Post #: 233
RE: Norvel Engine FAQ - 6/16/2007 2:21:03 AM
N1EDM
Status: offline
Thanks for the update, Skypilot. I haven't been paying attention to them.
As it is, I have a Norvel .074 and a TT GP.07. The Norvel is in a home-brew glider and the TT is not being used in anything. maybe I'll replace the Norvel with the TT and then drop the Norvel into the Herr Mini-Somethin' Extra.
I've run both engines and the TT is not at all as strong as the Norvel. The TT is for glider assist and light duty. It just means that I will have to re-build the front end of my glider to take the TT GP-07 (narrower mounting dimensions).
I don't have any experience with the Hornet .09. I just happened to come across it on the TH website.
Bob
(in reply to PlaneKrazee)
       Post #: 234
RE: Norvel Engine FAQ - 6/16/2007 1:48:59 PM
PlaneKrazee
Status: offline
TH doesn't give a weight on the .09. I would like to know how much it weighs.
KB1DTB
AMA11123
(in reply to N1EDM)
       Post #: 235
RE: Norvel Engine FAQ - 6/16/2007 3:06:13 PM
N1EDM
Status: offline
Good point....
Bob
       Post #: 236
RE: Norvel Engine FAQ - 6/17/2007 3:34:00 AM
AndyW
Status: offline
I've found that, for some reason, the Norvels actually tolerate a wide range of props. Here, http://www.youtube.com/watch?v=af4dQNa60_w we have the .074 doing 11.7K on diesel on a Cox 8 X 4 prop. This IS on diesel though, so that may have something to do with it.
Here, http://www.youtube.com/watch?v=PRn5i6Knisw in a similar fashion, we have a dieselized, .06 doing 10.5K on the same prop, on diesel. No issues with idle and transition.
However, here, http://www.youtube.com/watch?v=_pN6-rgXEFk we have a glow .15 doing 10.5K on a Grish, Tornado, 10 X 4. No real issues with idle or transition or top end. Smooth and steady. Note that with the larger prop, we were not overcompressed as you might think we would be. Generally, when you put on a bigger prop, you need to retard ignition timing by reducing the compression ratio. Despite the larger prop, we saw benefit by increasing the CR. We've taken stock head buttons and shaved them down for similar gains on large props.
The Norvels somehow, manage to break all the rules.
The LiteMachines Norvel .074s have some neat, desirable features. Short block with brass bushings on both ends of the crank. However, for some inexplicable reason, they don't throttle as well as stock, .074s even with the addition of a throttle with an adjustable airbleed. They DO throttle very well with LM's exhaust throttle. Why all this is so will be looked into in due course. The upside is that you can get new piston and cylinders from LM by buying the whole engine at the same price as a PL set. That is, if they have any left.
< Message edited by 1705493-AndyW -- 6/17/2007 3:43:26 AM >
Andy Woitowicz
       Post #: 237
RE: Norvel Engine FAQ - 6/17/2007 4:33:27 AM
N1EDM
Status: offline
I really liked the Norvel's. I'm sorry to see them disappear from the USA.... but I do have to say that one should not stick one's finger into the prop of one of those beasts when running an SPC prop. Absolutely perfect lacerations (I didn't blunt the edges with sandpaper like I should have). If I had had a wood prop on there, my fingers would have only been bludgened instead of lacerated :-D
Hopefully my LHS will have one left over in his stock for me. I'll find out tomorrow. yeah, I liked the Norvel - and also learned to respect it as well
Bob
(in reply to AndyW)
       Post #: 238
RE: Norvel Engine FAQ - 6/22/2007 6:22:37 PM
Sergei
Status: offline
Sorry for a beginner question -
I have BigMig 0.061 with standard glow plug and head (I think it is called Freedom something) -
now I lost my glow plug clip for it and local shop does not have them.
1)Are they the same as Cox Black Widow ones?
2)Anyone knows where I can find them online (preferrably UK but not mandatory).
Thanks!!!
Sergei
Glasgow UK
Sergei, Glasgow.
       Post #: 239
RE: Norvel Engine FAQ - 6/22/2007 7:00:39 PM
rainedave
Status: online
Sergei, I don't know if you can get these in the UK, but they always work great for me. I like them because they simply attach to your standard Ni-Starter:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBWL9&P=7
David
(in reply to Sergei)
       Post #: 240
