AndyW
Joined: 1/17/2003 From: Timmins, ON, CANADA Status: online
Strykass, As far as I know, yes, Norvel is not going to be making any more engines. I've been in touch with Justin at Sig all along and the word is pretty final. Only if someone came along and bought the rights, tooling etc. The Chinese might do that but till then,,, However, I was lucky enough to snap up a good selection of old and new inventory that I plan to offer for sale this winter. The intent is to make up diesel heads for the entire line. I have threaded head blanks of the right size for all the Norvels from the .15 to the .40 and finally, I'll be able to make proper heads. Early designs used a contra-plate instead of contra-piston. It worked OK and allowed some experimentation but eventually caused problems. My entire year has been spent with personal/health issues that are coming to a close. I hope to be back up to full speed by the New Year and by next spring, a few Norvels of all sizes will be available,, at least for those that want one. The problem of plugs for 1/2A, including Norvel, has been solved with my article on RCU last year on how to make and adapt to take, turbo plugs. Unlike stock plugs, turbos give you back all the original power that you got with the original plug be it Cox or Norvel. I'll be making a small batch of these units, again, for those that need REAL engines for their small planes.
_____________________________
Andy Woitowicz
